Question about Canon PIXMA MP780 All-In-One InkJet Printer
Creda dryer how to replace heat element
  • 163 Answers
I am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 26, 2008
Reset overtemp thermostat should be small round disk attached to drum with a little red button.. Press firmly should reset ..
Feb 28, 2011 | Dryers
How to replace of heating element of creda condenser dryer model t632cw? and where i can buy the heating elements?
Here are the major heating faults and we have loads more films in our video library on appliance repairvideo’s
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
You-Tube video "oYErKqR3LsY" placeholder (do not delete)
Dec 26, 2009 | Dryers
My creda t622cw dryer had no heat so I have replaced the thermostats, but when I tried it there is heat but the heating element gets very hot and turns red, is this normal or do I need to replace this as...
The fact that the element gets red hot, shows that there is nothing wrong with the element, it will get red, more so if you tried it without a cover or panel over it, as normally the fan blows the air over the element, make sure the drive belt is o/k, and the drum is turning.
Please rate my solution.
Nov 13, 2009 | Frigidaire Electric Dryer
Creda tumble dryer T632CW is not heating up. Any
Oct 18, 2009 | Dryers
Creda dryer not heating fitted new element but still no heat
If you have not replaced the thermostats, then I would suggest that you do so, as .it is usually the stats that cause the prob.
Aug 14, 2009 | Dryers
No heat from dryer
there are ways to the element disconnect the power, then get to the element from the back of the dryer. disconnect the 2 wires on the element and use a muti meter. find the ohm section on the meter(it will beep when you connect the test leads) . connect the test leads to the element, if the meter does not do anything the element is bad.
Apr 14, 2009 | Dryers
Creda Reversair Sensa Dry Tumble Dryer produces no heat.
There is only 1 heater element, and normally one thermostat.
they are located at the rear of the m/c, behind a removable panel.
If you are not sure whether it is the element or stat, join the two
wires togeher that go to the stat, if the heater then works, replace stat. if no heat, replace heater.
plz leave feed back for this solution.
Dec 17, 2008 | Dryers
No heat to tumble dryer
Check the thermal disc with an OHM meter. One will be next to the heat element (high limit) and another on the air exhaust area which is the low limit.
Dec 16, 2008 | Dryers
No heat in tumble dryer
Is this a gas dryer, if so check the thermal fuse, should be white plastic with 2 wire ports. These tend to bad first. Thanks Dave
Dec 16, 2008 | Whirlpool GEW9250 Electric Dryer
put it in the bin
Sep 12, 2008 | Dryers
Canon PIXMA MP780 All-In-One InkJet Printer Logo
136 people viewed this question
old marine
old marine
