Question about HP Deskjet D4260 Printer
Paper is struck in the printer and I can see it but can not get i
Can not get paper out that is struck in the printer
First, open the main cover and see if you can tug the paper out. If this does not work, look at the back of the printer. You should see a door with two latches on the side. Squeeze the latches to open (like you would open an old-fashioned window screen), and you should be able to tug the paper out from here.
Posted on Jan 16, 2009
Factory resetting
go to the printer properties and check the paper size you are using. It should be set to a4 and it will recognise that size paper . make it a default setting.
Jun 20, 2013 | HP LaserJet 1020 Printer
HP deskjet 3745 will not draw paper
>Check pick up roller trying to pick the paper?>Clean pick up roller.>Check any paper objects struck in side?
Dec 18, 2011 | HP Deskjet 3745 Inkjet Color Printer
No paper pickup problem in system printer (HPLaserjet 3050 models)
open back & side covers.. start diagnosys..
chech paper pickup unit trying to picking up the paper?..if yes.. clean/replace pickup roller..
No. check solonoid acting proprly,,
Paper passing little bit?..if yes..check paper sensor flag strucked?
check transfer roller gear properly engaging with the catride? 1.Replace catridge..2. Transfer roller check..
Good luck..
Sep 05, 2011 | HP LaserJet 3055 All-In-One Printer
There has struck in second paper when I printing more than one pages. Help me
Sometimes the paper, like money, will stick when printing. It's just the paper.
You may need to feed your printer the paper one page at at time until you get some new paper. The thinner the paper stock, the more likely it will stick to each other when printing.
Try getting some thicker paper (paper weight) when returning to the store.
Jan 21, 2011 | Canon LASER SHOT LBP-2900 Printer
A paper has struck in printer so its not printing how to remove the paper
1) Open the top cover
2) Remove the toner cartridge
3) Remove any paper from the multipurpose tray
4) If you can see the LEADING EDGE of the jammed paper slowly pull it out.
This may be easiest from either the multipurpose tray side or from under the toner cartridge
5) If you can see the TRAIL EDGE of the jammed paper slowly push it through the printer until it comes out
Dec 17, 2010 | Canon LASER SHOT LBP-2900 Printer
Paper jamming sign on but no trapped paper seen
hi there shuld be paper inside or may be when u removed jamed paper not proper way some pice of paper struck in the sensor thats why paper jamed lit up clear the whole paper path it will solve problem if not there is any path sensor not working good just clean the path sensors
thanks
May 14, 2010 | Office Equipment & Supplies
I have a red flashing light
may be the cartridge eror or the paper is stuck in side just try withe cleaning the catridge with tissue paper and make sure ther is no pending job for printer to print.
have a nice day dont froget to give rating please..
Feb 05, 2010 | HP DeskJet F380 All-In-One Printer
Hi i have a problem during printing is the paper is strucking in the middle of during printing processes the printer modle number is Dell 1710
Hi, the printer manual or the printer itself would have instructions on how to remove paper jams. Also loosen the guides alongside the paper feed a bit to ensure it is not holding onto the paper sides too tightly as this will continue to cause jams.
Nov 29, 2009 | Dell 1710 Laser Printer
Out of paper error message but printer is loaded with paper.
Please follow the follwoing steps,
1) Open the rear access door and check for any paper jam and struck paper, unplug the power cord at the both ends from the printer and wall outlet. connect to wall out let directly dont connect to printer.
2)Press and hold # and 6 while reconnecting the power cord to the product hold for 1 min after plugging the power cord, and then release both buttons, this should resolve the issue.
Regards,  raj_p5983
Jan 22, 2009 | HP Officejet 7210 All-In-One InkJet...
Paper Jam
Unplug printer check the paper loading tray something struck , small paper , coins, hair pin etc , printer can detect , message appear paper jamped.
Dec 05, 2007 | Lexmark E232 Laser Printer
HP Deskjet D4260 Printer Logo
32 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
