Question about Bosch 24 in. SGS4072 Free-standing Dishwasher
Bosch SGS4072AU won't progress cycle
Hi, the dishwasher just rumbles on and won't porpgress. If I manually progress the dial it moves on and keeps making a washing noise, but then it hangs up again. If I keep rotating the dial manually to the end it then won't turn off... just keeps rumbling away. Any clues?
cheers, Nick
SOURCE: Noisy Bosch dishwasher SHU43C05UC
your main wash motor is faulty it must be replaced.
Posted on Jun 10, 2008
  • 210 Answers
SOURCE: Bosch 5300 Dishwasher
This sounds like a thermal stop as well. The unit wants to get up to a final rinse tempurature but can't reach it so just keeps going. If you have an amp probe you can check to see if the heater is coming on in the final rinse. If it is not, could be the thermistor of even the heater.
Sgt 48
Posted on Jun 18, 2008
  • 478 Answers
Replace the fill valve that sound is it trying to open
Posted on Mar 12, 2009
  • 3 Answers
SOURCE: Diswasher Pump won't stop running
Introduction: This may work for your problem, but only if you're finding that you cannot get further water to flow into your machine. If your machine fills, OK, then this ISN'T a solution to your problem.
I have a Bosch SHV. My sink drain backed up, and the water accumulating in the sink then migrated to the dishwasher, through the drain pipe, causing the dishwasher to fill up and, it turned out, overflow a little. When I turned on the dishwasher, the water drained, but no new, clean water came through the hot water pipe. The drain just kept running, but nothing else happened.
Here's what happened. Under the main chamber of the dishwasher, by three inches or more, is a white plastic tray. It sits almost at the floor, and it may not be obvious that it's a tray capable of holding water. The overflow water spilled into that tray, which in turn caused a float in the far left side of the tray to lift (the way a toilet float lifts when the water fills in a toilet tank) and shut off the water intake valve (like the toilet float shuts off the toilet water flow). So long as that valve is closed, your machine will not run.
STOP: disconnect power supply at this point for safety.
To see the white plastic tray and thereby fix the problem, you'll need to take off the BLACK TOE-KICK (attached on my unit by two star-head screws at its bottom) and, possibly , the OUTER PANEL OF THE DISHWASHER DOOR (in my case, a custom wood panel (attached by a few screws through the inner side of the door, two screws that are accessed by popping off little--smaller than a dime size--covers on the sides of the doors, and then the door panel lifts up and out). (I took the outer panel off, but I can't remember if I would have had to reach into the white tray without doing so.)
Once you do that, you can see the white plastic tray. It doesn't come out--at least not without removing the entire machine--so try this. You can take your fingers and feel over and into the tray. You'll probably feel the water--I did. Look at the far left of the tray with a flashlight. Back there you'll see a flat, round, 3-inch diameter piece of white plastic sitting at the bottom of the tray. To its center is a generally U-shaped lever looking device, which, at its far left end, is connected to a red stick pointing up into the machine. When water goes into the tray, the float rises, causing the U-shaped lever to rise, causing the red stick to raise, which (though I couldn't see it) causes an electrical signal to run to, and shut, the valve for your water intake.
I took paper towels, and then a narrowly cut sponge, to sop up the water in the tray. I then took my shop vac and, using it as a blower, blew what little water was left right out. You might be able to use a hair dryer, but first sop out what you can or it'll take forever. Once you've done that, put everything back together and plug your dishwasher back in. My buttons are at the top panel. To reset, hold down the two buttons marked for clear drain for three seconds and release. You should be able to start up then. It took 15 seconds before the water started to run, but it did and the machine works fine again.
Interesting note: The valve that stopped the water from flowing in automatically opened once I got the water out of the tray. You don't need to reset the valve.
Good luck.
Montpelier Man
Posted on May 09, 2009
SOURCE: Bosch she44c wash cycle time keeps extending.
We have had the same problem, except the water was not getting hot either. After a ton of research there was an issue that kept popping up. There was a massive recall on many of the model and serial #s. According to the recall there was a fire risk from the control board, the brains for the machine, that sits behind the digital display. For those not "at risk" but with the water not heating and the run time increasing, the problem can still be with the control board. I removed the control board and found a burned out connection with one of the controls. I soldered it and put the machine back together. The run time has returned to much closer (down to 128 from 184) than before the fix, but still is not back down to the original 108 minutes. I've priced a new control board--about $120.
This happened right after the warranty ran out. Imagine that.
Posted on Oct 10, 2009
Is anyone have Bosch dishwasher SGS4072AU/36 user manual?
Search the internet for:
Make + Model + the word "Manual"
or contact the manufacturer.
Mar 16, 2016 | Bosch Dishwashers
Motor keeps running. Water heats fine. Help
One of the reasons for motor not draining during normal cycle is the check valve is stuck. It is meant to return to normal during drain cycle but close during wash. I think the cancel is resetting it and letting water out.
See this discussion.
Apr 02, 2014 | Bosch 24-in Built-In Dishwasher Color:...
CI am having a problem getting our Miele G575 dishwasher to run through a wash cycle. It definitely has power, the water is on and there is no water in the bottom of the dishwasher. When you turn the...
You said it does not progress...meaning the dial does not eventually move? it may be waiting on a water level sensor to be tripped. The dishwasher is just not filling. The water valve solenoid may be stuck or defective. or a wire may have come off the valve solenoid.
Mar 08, 2011 | Dishwashers
Our dishwasher is five years old and now it is not
Sounds like you might have a bad water valve. Before you change the water valve, see if the valve under your sink is your problem... Turn it off and and back on to see if it helps. Sometimes hard water will clog the valve. If that doesn't help, you may need to replace the dishwashers water valve. Definitely worth fixing. Hope this helps
Dec 10, 2009 | Bosch 24 in. SGS4072 Free-standing...
Our dishwasher does not progress beyond the wach cycle to the rinse cycle. It will run for hours and still has soap in it.
I'm positive of this, but your dishwasher may qualify for a somewhat recent recall. Call bosch to see. If you can get it to drain manually and put into rinse and hold manually, but it won't progress on it's own, then it's the control board. Hope this helps.
Nov 28, 2009 | Bosch 24 in. SHE43C05UC Stainless Steel...
Dishwasher stalls
Apr 07, 2009 | Bosch SHU4006 Dishwasher
Bosch dishwasher SGS55M2 leaves dishes wet
Are you using drying agent?If not you have to use it in bosch dishwashers.When the cycle is completed is it hot,steam rolls out.if not you have a heater problem or thermostat problem.
If you need more info please ask
Feb 05, 2009 | Audiovox Bosch 718 World Cellular Phone
Dishwasher wont progress to next step
Does after the manual moving to the next step, the dishwasher complete the cleaning process properly ?
May 16, 2007 | Bosch 22 in. SKT5102 Free-Standing...
Bosch 24 in. SGS4072 Free-standing Dishwasher Logo
133 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
