Question about Sony Cyber-shot DSC-N1 Digital Camera
Sony Cyber-Shot DSC-N2 is stuck on off with lens out. my camera is stuck with the lens in.
  • miltonkgeedv Dec 22, 2008
    url to the link for the solution to broken gears in lens could not be found.
  • 10,594 Answers
I know what is problem with DSC-N2
Lens is not being initialized and causing error so system control generate power on-off display.
New lens assembly is probably proper solution because repair of this lens is really tough job for tech person.
You can order lens aseembly with following part number ...
8-848-799-01 LSV-1100A
below is exploded view of Lens Mechanism of DSC-N2
Above info taken from following service manual ...
Posted on Dec 22, 2008
  • 2,427 Answers
YOu'll need to pull the lens out, use a small flat head screwdriver or paperclip. If you cant remove it like that simply open it up and push the lens out.. Common problem usually cause by dust sticking the lens or if someone pushed it it.
  • Sony Master
  • 19,396 Answers
Try slapping gently the back of the camera with the palm of your hand while you turn the camera on.
Try also helping the lens out with your fingernail (gently), while you turn on the camera.
Try spraying canned air on the lens.
If all that does not work, the lens must be taken apart, in this case ask a quote to a repair shop, unless you want to turn the camera into a bunch of tiny bits and screws.
Thanks.
    Master:
  • 416 Answers
It might be battery problem. Try to remove the battery, plug the camera to power outlet.
Try to restart it several times.
Do you have any messages on it:E:61 error "Access" and then "Turn camera off and then on again".
If yes you have jammed lens. You need to bring it for repair, it will be around $65+
Good Luck
Posted on Dec 18, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Unfortunately, the correct procedure would be to seek the services oa an authorized service center as this involves opening the lens mechanism.
A non-technical, temporary workaround is to jar the camera back into action. This could be accomplished by thumping the bottom of the camera against one's palm or an open book. Of course this procedure is not recommended as it either clears the jam or reinforces it.
Good luck and Thank you for using FixYa. Happy Holidays.
    President:
  • 2,110 Answers
If you have stuck lens on you digital camera and you get the message inthe camera screen "Turn the power off & on". This means that thegears of the camera probably will be broken.
Here is the instructions how to fix this problem:
http://cia.saulius.googlepages.com/repairinstructionsfordsc-p7292
How to choose the best image size when using DSC-N2 camera?
I suggest to check in the cyber-shot-dsc-n2 user manual in the section about image resolution (taking pics).
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Feb 24, 2012 | Sony Cyber-shot DSC-N2 Digital Camera
Sony cyber-shot dsc-w570 lens cover won't close
Lens block is faulty you must replace it with a new one
Nov 04, 2011 | Sony Cyber-Shot DSC-W570 Digital Camera
The screen on my sony dscn-n2 is broken where can i buy new screen?
Part number of lcd for Sony DSC-N2 is as follows:
A1151474A... TP BLOCK ASSY (30STGU05) (including LCD)
Available in Sony Part Store for $192
Thanks.
Apr 18, 2010 | Sony Cyber-shot DSC-N2 Digital Camera
When I turn it on the software keep telling me to switch off and on again.
It is lens mechanism problem and system control deos not get reset signal from lens mechanism.
Need to replace lens assembly. Qualified camera tech will replace it.
Oct 01, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
Turn off and on again.
you should have dropped your camera down hard. you should replace your lens array from the nearest sony service center. it costs about 60$.
Jun 11, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
Zoom lense 'Slanted'
The parts (gears) are manufactured in plastics so once damaged it is very difficult to rebuild. Sony does not sell gears but complete lens assy. so best way is to find out what Sony charges for the repair. At www.camerarepairjapan.com the rebuilt of zoom repair was around $120 with 3 months warranty. Good luck. James
Mar 26, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
Sony Cyber-Shot DSC-W30. The lens is in a "stuck" position
You have a bad lens, it prob. also says turn off and on again.
Jun 30, 2008 | Sony Cyber-Shot DSC-S90 Digital Camera
Cyber-shot DSC-N2
Please spacify where you are not getting sound? in TV, in PC or in camera?
Jun 21, 2008 | Sony Cyber-shot DSC-N2 Digital Camera
Sony cyber-shot DSC-S700
maybe you have to format it on the computer
Jan 18, 2008 | Sony Cyber-shot DSC-N2 Digital Camera
Sony nc2
Hi there, You can record or play back images in the internal memory only when a Memory Stick Duo is not inserted in the camera. Please check this link: http://support.sony-europe.com/dime/digistill/cyber/cyber.asp?l=en&m=DSC-N2 Best regards, Arpi
Jun 09, 2007 | Sony Cyber-shot DSC-N2 Digital Camera
Sony Cyber-shot DSC-N1 Digital Camera Logo
648 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
