Question about HP Deskjet D4260 Printer
Paper is struck in the printer and I can not remove. It is too far inside. I can see it but there does not seem to be a way to open the printer to get the paper out.
First, open the main cover and see if you can tug the paper out. If this does not work, look at the back of the printer. You should see a door with two latches on the side. Squeeze the latches to open (like you would open an old-fashioned window screen), and you should be able to tug the paper out from here.
Posted on Jan 16, 2009
2 Suggested Answers
SOURCE: can not close the back cover
a Samsung tecahnician justed fixed it for me. The feeder (at the back cover) just in wrong position, turn it to the opposite way and he recommended that next time if the paper jam no need to open the back cover just turn the printer off and then turn it on, the paper will feed out. But it case you have done as he recommend and it still jam, open it would be possible. (the Feeder I'm not sure what it's call, it were 3 piece of black plastic)
Posted on Feb 01, 2009
Hp 1007 laser printer on position but no initialise
just open the printer and check all the censor whether it got struck or any small paper will be inside.other than there is no problem in the printer
Aug 09, 2012 | Office Equipment & Supplies
A paper has struck in printer so its not printing how to remove the paper
1) Open the top cover
2) Remove the toner cartridge
3) Remove any paper from the multipurpose tray
4) If you can see the LEADING EDGE of the jammed paper slowly pull it out.
This may be easiest from either the multipurpose tray side or from under the toner cartridge
5) If you can see the TRAIL EDGE of the jammed paper slowly push it through the printer until it comes out
Dec 17, 2010 | Canon LASER SHOT LBP-2900 Printer
Copier wont work alarm light is on says paper tray is open.
If you are using any refilled catridges, remove it and try with original one. See if any dust is present or any pieces of paper left or struck inside. Make sure the catridges are not empty. Try it out.
If still it does not happen then call the technician to check the sensor part of the printer.
Sep 05, 2010 | Canon MX300 Office All-In-One Printer
Stylus CX9400 Photo Printer: paper jammed inside printer...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
May 18, 2010 | Epson Stylus CX9400 Photo Printer
The paper jam button is on, but there doens't seem to be any paper in there. I took the paper tray out and examined the underside of the printer, no visible paper jammed. I undid the back access part,...
power off printer
remove paper tray
open front panel
remove both tonor and phto conductor kit (tonor seats inside of that)
inspect inside the printer
Chances are there is a fragment of paper in the right corner near the paper sensor
replace components
restart printer
Keep me posted
Feb 01, 2010 | Lexmark E232 Laser Printer
PAPER JAM PRINTER SAYS PAPER JAM IN INPUT TRAYS BUT PAPER DOES NOT SEEM TO BE JAMMING
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 11, 2009 | HP LaserJet 4050 Printer
Can not close the back cover
Jan 28, 2009 | Samsung CLP 300 Laser Printer
Paper is struck in the printer and I can see it but can not get i
Dec 18, 2008 | HP Deskjet D4260 Printer
HP Deskjet D4260 Printer Logo
29 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
