Related Tags:
This problem should be removed because:
Problem with Microsoft Windows Server Standard 2003 for PC
windows cannot connect domain either domain controller is down or otherwise unavailable or because your computer was not found
Solutions (3)
Best Solution
The resolution and workaround to solve the error is as below.
- Login to the Windows 2003 domain controller, and delete the computer account object from the Active Directory by using Microsoft Management Console (MMC) which you can always access from “Manage Your Server”.
- Log-in to the PC workstation as local administrator. If you cannot logon as local administrator, try to unplug the network cable and logon to the computer by using a domain administrator user that used to logon on the PC before, by using cached logon credentials feature.
- Go to Control Panel, then click on System icon, then go to Computer Name tab.
- Unjoin the computer from the domain by clicking on “Change”. You should see that Domain button is now selected. Remember your domain name in the text box. Select (Click) on “Workgroup” to remove the computer from the domain, and put any workgroup name in the text box (e.g. workgroup).
- Click OK to exit.
- Restart the computer (optional)
- Go back to the Control Panel, launch System properties and then go to Computer Name tab, and click on “Change”.
- Rejoin the domain by uncheck the Workgroup button and select (check) Domain button, and put in the domain name noted above into the text box.
- Click OK to exit.
- Reboot the PC.
try to ping DC Computer ip, if it ping then restart your Computer and try Again
if it does not ping then check with Internal Settings
Sanjay Limbu's solution worked for me. In active directory, under computers... the computer name was disabled and had a big red X on it. Right click and enable this computer... bam, the user could log back in. You do not have to remove the PC from the domain or the user from the active directory list.
Suggested Solution (1)
This is usually a computer trust issue, if the computer was previously used to logon to the network and has been rebuilt or had in problems it can have trust issues. First way would be to change the computer name and add the DNS Prefix for your domain. ex desktop.abc.com to desktop1.abc.com. when prompted it is best to use the domain admin or equivalent to make the change and then reboot.
I am unable to login our domain user account.
Windows cannot connect to the domain either because the domain controller is down or otherwise unavailable, or because your computer account...
domain controller is down or otherwise...
After replication server to the Headquarter company.My company user unable login to their user profile and come out the message "the...
Client login problem.
i have just recovered failed server from system state backup after recovering i found that when users try to login sometimes they recieve...
i can't login to my windows xp computer. i...
i receive this error message ''domain unavailable''
Add Your Solution
Is there any Group Policy for...
We are needing to add the -nomerge or (noframemerging) switch in the Windows 7 registry remotely for 300 machines....
can i install SAP trail
can i install SAP trail verson in windows 2000?
See all Microsoft Windows Server Standard 2003 for PC Problems
Fix-O-Meter
29,933
29,933 people viewed this problem
- 74 people found this problem to be helpful.
- 1 person is following this problem
Top Microsoft Operating System Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
thanks sir
its working .
now i can login on my computer by using server account.
thanks
