Question about Samsung ML-2510 Laser Printer
Printer does not feed paper
My Samsung ML 2510 printer does not feed paper properly and most of the time it does not print. Sometimes when I manually feed the paper it works and prints well but most of the time it seems to be spinning and cannot pick up the paper.
  • razzia_walli Dec 21, 2008
    This solution has helped somewhat - the printer prints sometimes, not always. Turning the power on and off sometimes gets it going again. Thank you.
    President:
  • Samsung Master
  • 990 Answers
Dear sir; That's very difficult to tell you detail how to take apart the parts, but I can teach you a easy way and tricky way, this cause you problem is paper pick-up roller, right above the paper tray. therefor you have move out the tray , remove the toner ctg. flip machine over (bottom up) then you will see the roller very clear, clean up with rubber rejuvenator, try it out, and please let me know how does it work, good luck! HAVE A HAPPY HOLIDAY !!!
Posted on Dec 18, 2008
  • Everett Lin Dec 22, 2008
    Hello, sir; As you said sometime work sometime don't, I would said 90% is paper pick up drive solenoid defect , I don't think you can do it, better looking local service techman to help you. thank you your high rating.
Location of Solenoid samsung ML-2510 printer
Pick-up SOLENOID needs replacing.
See this link.
http://www.arbikas.com/view/locator/ML-2510.pdf
Part is JC33-00015B SOLENOID-MP_R2;-,SCX-4720F,DC24V
Fairly involved strip down but there are a Cpl of you tube videos out there showing something similar.
Looking to undertake this task myself and will You Tube it.
Jan 10, 2013 | Samsung ML Office Equipment & Supplies
My Samsung laser printer ML-2510 keep wont stop running (two lights are blinking same time) until I manually turn off the switch.
After removing the pickup rubber (and not removing the rubber band from it's plastic drum) I cut a thick piece of card stock paper the width of the rubber band and slid it under the rubber. I thought it would make it contact the paper with more force and it worked great.
Dec 04, 2011 | Samsung ML-2510 Laser Printer
The paper starts to feed , then stops. There's no jam.
the problem is paper feed roller their have a dust. clean it properly. and then print again
Jan 07, 2011 | Samsung ML-2510 Laser Printer
Red light stays on, and nothing prints. won't recogonize paper in tray???
Depending on how long you have had this , it might be time for a new one. If its still under warranty, rather send it back as it could be a problem inside.
First do a couple of test.
Turn the Printer off and back on?
Reinstall the software for the printer?
Paper **** under the toner drum? Dont touch the green drum!!!
Pull toner out and reinsert
On the top side above the toner were the paper feed's after printing. Is there a paper jam?
Did you replace the toner with a "compatible" toner? If so the printer does not recognize the cartridge thus another reason for the red light?
if you have had your ML 2510 for longer than 2 years and 4 Toners. This is a good time to invest in another ML 2510 Printer. They are cheap and dont break up the bank's money printer to get.
I hope you find help with this.
AJ
Dec 07, 2009 | Samsung ML-2510 Laser Printer
Samsung ML-2510 Laser Printer Jams
printer only supports up 120gsm,anything thicker will jam.
Jun 08, 2009 | Samsung ML-2510 Laser Printer
How to Print an Envelope
User manual should have been installed with the software that runs the printer from your computer. My WindowsXP system has a main menu item for the printer. Mine says "Xerox Phaser 3124", but it's really the same as the Samsung 2510.
When you go to print, select the printer, then the type of paper (envelope). This can be done by going to printer properties and then the layout and paper pages. You will want to insert the envelope just above the stack of regular paper, in the single sheet feed area.
Feb 05, 2009 | Samsung ML-2510 Laser Printer
Constant paper jam
How do you put the paper in?It must either be the paper or the paper feed system.
Apr 27, 2008 | Samsung ML-2510 Laser Printer
ML-2510
Sound like the printer cartridge is either bad ..or now snapped in properly..might try to clean the feed roller the one that pick the paper with a cotton swab or lint free rag with some isopropic alcohol. paper dust will cause slippaged and jam. should be located either in the paper tray or just look above for black or grey rollers (when you have the tray out)
Feb 05, 2008 | Samsung ML-2510 Laser Printer
SIMPLY UNINSTALL THIS PRINTER FROM COMPUTER AND REINSTALL IT AS A NEW PRINTER FROM THE INSTALL DISC THIS WILL USUALLY
FIX THIS TYPE OF PROBLEM
Jan 17, 2008 | Samsung ML-2510 Laser Printer
Samsung ML-2510 Laser Printer Logo
339 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
