Question about RIM BlackBerry 7290
Battery escape in a Blackberry 7290
What I have to do if my Blackberry 7290 says "battery escape- closing the device" and shuts down, it does not charge, I put another new batter to see if the problem was the battery, but anything function. Can you help me with that? What is happening with the phone?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand a known issue to this model. Some tricks/workaround done are:
  • inserting a thin foam to ensure that the battery makes forced contact with the battery terminals;
  • slightly bending the contacts outwards to give more pressure to the battery;
  • covering one side of the battery with a piece of tape to increase width slightly;
  • of course the correct procedure would be to seek the services of a qualified professional.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 18, 2008
  • 679 Answers
It means that your battery is not seated properly, I just searched the blackberry forums, and it seems to be common when removing the battery, unless seated properly it will deplete the charge faster than normal, I hope this helps you, thanks for using FixYa, peace Gym
By black b. 7290 is saying error 365 when i tried to turn it on i can only see a red light on the right top of the phone. please heeeeeeeeelp
Here (http://www.blackberry.com/btsc/search.do?cmd=displayKC&docType=kc&externalId=KB02983&sliceId=SAL_Public&dialogID=24338156&stateId=1%200%2024332718) you can see detail about your error code. All i did was...
Download BB 7290 firmware... run apploader
As usual copy 7290 firmware folder from C:/program files/common files/research in motion/.............. and paste in drive C:/
plugged in USB Cable without battery
It started erasing.... after it finished the soft was waiting for JVM device bla bla bla....
I now disconnected fone and this time connected fone with battery... 2 my surprise it started loading application and it finished updating my device..
Jan 13, 2010 | RIM BlackBerry 7290
Blackberry 7290 battery icon with line hrough battery
This can indicate that the battery can no longer hold a sufficient charge for the device and may need to be replaced. To be sure, you can download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues.
Jan 11, 2010 | RIM BlackBerry 7290
My RIM Blackberry 7290 comes up with "Device Error: 365 Reset". Whatever key I push, it still comes up with the same message.This problem started after taking the battery out to insert a sim card. Tks
you probably either messed up your battery, scratched your sim card, or got something wet. i would ask a phone technician cause you might need some help.
Dec 15, 2009 | RIM BlackBerry 7290
Device error 365
You'd lose all data
Download BlackBerry 7290 firmware... run apploader
Copy 7290 firmware folder from C:\program files\common files\research in motion\....
and paste in drive C:\
Plug in USB Cable without battery
It will start erasing. all data ... after it finished the soft was waiting for JVM device ....
Now disconnect phone and this time connect phone with battery... It will start loading application and finish updating the device..
Finally use FG to unlock it successfully...
Try this
http://blackberryforums.pinstack.com/5178-how_reinstall_os_when_computer_wont.html
The device might be dead too, how's the warranty .. ?
Nov 22, 2009 | RIM BlackBerry 7290
Display message Battery drained.
might be the battery falt or the battery power recognization ic is worn out
Sep 24, 2009 | RIM BlackBerry 7290
Solution for 7290 blackerry frezzes up how do i reset?
Try resetting the phone by powering off, removing the battery leaving for 30 seconds reinserting the battery and powering on.
If that doesn't work hold down ALT+RIGHT SHIFT(CAP)+DELETE keys simultaneously unti you get a blank screen.
May 11, 2009 | RIM BlackBerry 7290
Blackberry device error 411. I also had a strange
Before Perfoming these steps take a Back up of your Handset. Cause 1 The wireless transceiver software was not loaded onto the BlackBerry device correctly. Resolution Re-install the BlackBerry Device Software using BlackBerry Application Loader. Connect the BlackBerry device to your computer. Open BlackBerry Desktop Manager and double-clickApplication Loader. The BlackBerry Application Loader Wizard opens. Click Next. If prompted, enter your BlackBerry device password and clickNext. The Application Loader Wizard examines your BlackBerry device?s current configuration. When it is finished, the Application Selection window appears. Select the applications to be loaded on to the BlackBerry device and click Next. The Completing the Application Loader Wizard screen appears. Do not click Finish. Click Advanced to begin loading the applications. In the Data Preservation window, select the Erase all currently installed applications check box and clickNext. In the Application Data Backup window, choose the option to automatically back up the application data before loading and to restore the contents when the load is complete. Click Finish to begin the BlackBerry Application Loader process. Click Close when the loading operation is complete. Cause 2 There is a wireless transceiver hardware failure. Resolution Contact your service provider for more information.
Mar 24, 2009 | RIM BlackBerry 7290 Smartphone
My blackberry 7290 Rim(T-Mobile)says: Device error
An unspecified error has occurred with an application on your Blackberry smartphone.
Resolution In BlackBerry Desktop Manager, run the BlackBerry Application Loader tool.
Note: The following procedure will delete all data and applications from your BlackBerry smartphone.
  1. Disconnect your Blackberry smartphone from your computer.
  2. Open BlackBerry Desktop Manager.
  3. Open BlackBerry Application Loader.
  4. Reset your Blackberry smartphone.
    1. Remove the battery cover.
    2. Remove and reinsert the BlackBerry battery to reset the BlackBerry smartphone.
    3. Replace the battery cover.
    To perform a hard reset on a RIM 850 device, RIM 857 device, RIM 950 device, or RIM 957 device, insert the end of a paperclip inside the small hole on the back of the BlackBerry device.
  5. When the LED indicator has turned on, reconnect the BlackBerry smartphone to the computer.
  6. Click Next.
  7. On the following screen you will see either USB:Unknown or USB:; click Next.
  8. Select the required applications from the applications list and click Next. The firmware is loaded to your BlackBerry smartphone.
Warning: The following procedures will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the data on your BlackBerry smartphone before performing this procedure.
Mar 01, 2009 | RIM BlackBerry 7290
Blackberry 7290
the unit may have a bad battery, try another battery.
if it still reboots. upgrade the blackberry's software to the latest version for your device. the provider's website will have a link to get the latest software for your blackberry
Jun 09, 2008 | RIM BlackBerry 7290
Blackberry 7290 issue
my blackberry 7290 keeps saying device error:400 then below says reset i keep reseting it and nothing comes but it keeps saying reset .. wat can i do ?
Nov 20, 2007 | RIM BlackBerry 7290
RIM BlackBerry 7290 Logo
71 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
