Question about Kodak EasyShare C743 Digital Camera
I have a lens problem.lens will go out then display will show I have lens problem and lens will go back in and shut-off.
  • Anonymous Dec 30, 2008
    Same. Camera lens will not go back in. Says lens error then camera turns off with lens still sticking out and the batteries are fine
    Sergeant:
  • 221 Answers
The lens is got misallighned and so this is happening.keep the camera off and move the lens with your hand manually for a minute.in all the directions.but take care the lens is very delicate so do not put or apply pressure or any force on it.and check out it should work.if still does not works and gives the same problem.then keep the camera ON and tap the sides of the camera for a while and the check.if still does not work then two optionseither the lens is broken  internally or itthe camera needs to be opened and lens needs to be readjusted and the assembly which moves the lens has to be checked if that is cracked it needs to be replaced. thanks.
Posted on Jan 07, 2009
Lcd display will not work on canon power shot sx10 is - camera will take pictures and i can review pics on the lcd display but will not show any pictures when trying to take photos. it started this problem...
Of course! You mentioned the beach so maybe salty water or sand got inside the camera. (Salt can interfere with the electrical connections inside the camera and possibly short-circuit.) Send it back for repair to replace any damaged parts you may need. They'll send it back good as new :)
Jun 29, 2010 | Canon PowerShot SX10 IS Digital Camera
Tip
Sanyo digital camera showing lens error 1114 or 112
Hi.
If your Sanyo digital camera is not starting and you get lens error 112 or lens error 1114 prompted on display, that means that the lens is getting stuck, and cannot extend or retract fully. The controller board detects the error on startup, and shuts down after displaying the error message.
This errors usually happen because of dirt, or because the lens mechanis mis damaged in consequence of a shock.
If lens does not retract, try helping the lens back, without putting too much strenght, while you turn off the camera at he same time.
If the lens does not extend, try tapping softly the back of the camera to help lens out, while you turn off the camera at he same time.
If the camera had been exposed to sand or dust, try blowing canned air on the lens.
If this does not work, the lens assembly must be taken apart completely and re-assembed, and for that you need a camera repair shop.
Also call the number listed on the owners manual to get support from the manufacturer.
Check also the links below for more troubleshooting in case of lens error:
Lens not retracting on digital camera.
Lens Error.
on Apr 09, 2010 | Cameras
When I ucover the lens, the display shows that
That is because you have arrived back at the 'setup'.Remove your battery and memory card for two minutes, then put them back.Then select 'menu' and setup the camera again, entering the date etc. I am assuming that your battery is charged.
Oct 10, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Displays "lens Error"
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 22, 2009 | Canon PowerShot S3 IS Digital Camera
When I turn the camera on it makes a few noises then shut off
i called the company (1-888-553-4448) olympusamerica.com and they told me to send it in and they will repair it for 70.95 plus a 6months warranty because i cant find my reciept. they also said what eva is wrong with it they will be able to repair it, but if u have ur warranty u can send it to them it wont cost u anything because u have ur reciept.
Nov 11, 2008 | Olympus FE-220 Digital Camera
Lens Errors 17 & 27 on Sanyo VPC-E760
My camera was showing lens error 12&25 and then shutting off. I tried gently trying to twist and pull the furthest out part of the lens and it popped back into place easily. It made a noise when it did this, and then i turned the camera off, and the lens went back in!! Completely fixed now!!
Aug 03, 2008 | Sanyo VPC-E760 Digital Camera
Canon powershot sd30 digital elph
I have same problem. I turn on the camera you hear it trying to come on, shows display pic for like 3 seconds and then shuts down. If I could get the lens to retract I am sure the camera would work.
Jun 23, 2008 | Canon PowerShot SD30 Digital Camera
Optio M20 Camera: Press on/off button to power up camera, the camera opens the lens cover, turns on a red led inside the lens, cycles the lens out and back in,then makes about 5 little popping noises. The...
i got it!!! on my cam i hold down the menu button at the same time power on, it will showup a " ver 1.00" and lens move a little maybe u have to do it 2 times but second time it should work
Mar 29, 2008 | Pentax Optio M20 Digital Camera
Lens stops functioning
Have you tried this same lens with other cameras? Do you have another camera body you can try? or perhaps a friend with a Canon EOS Camera? Also try the following please: Remove the lens. Look at the lens mount contacts, take a Cotton swap with some rubbing Alchol & clean the contacts very well, both on the lens and the camera body. Is your camera reading the lens aperture range correctly (at least most of the time)? Also since you replaced the PCB on the lens, isn't it under warranty? Let me know if this works. Thank you, AJ.
May 23, 2007 | Canon Zoom Telephoto EF 100-400mm...
Kodak EasyShare C743 Digital Camera Logo
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Parshiv Luthra
Are you a Kodak Camera Expert? Answer questions, earn points and help others
