Question about Dryers
Dryer not producing heat!
My DLE7177RM dryer is not producing enough heat to dry a load.
  • Anonymous May 10, 2009
    dryer dle7177rm dot heat
  • 30 Answers
Make sure your vent screen is clear of lint, You should also check the actual vent duct which comes out the back of the dryer. It sounds like there is blockage of dust and lint which is not allowing the dryer to properly heat up.
Posted on Dec 18, 2008
DLE7177RM is not drying. We are getting heat but not enough to dry anything. A few weeks ago we noticed a lot of condensation on the floor but then it disappeared. Could we have a seal problem?
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Sep 12, 2011 | LG Dryers
Tromm dryer model DLE7177RM spinning but no heat nor drying
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 14, 2011 | LG Dryers
Kenmore 110.70982990 front loading gas dryer. Everything seems to work, except the flame stays on for only 5-10 seconds, and therefore does not produce enough heat. Lights up again after a few minutes,...
Remove the exhaust vent from the rear and try a load of laundry.
If ir dries correctly,clean and or repair the connecting exhaust vent.
It may also be necessary to disassemble the dryer and clean internal ducts.
Feb 20, 2011 | Kenmore 63942 Dryer
Dryer will produce heat but will not dry clothes
Greetings,
several things to check...i usually pull the vent off of dryer and run load of cloths..if it drys ok...we know the vent was the issue..if its vented to the roof..the screen usually gets stopped up inside the hood. if it still doe's not dry with the vent off. there has to be an air circulation problem.. Check the blower wheel fitting tight enough...they come loose, but normally have noise along with it...
Jan 27, 2011 | Frigidaire Electric Dryer
Dryer produces some heat, but not enough to dry a load in one or two cycles. What is wrong?
Jul 08, 2010 | Whirlpool LER4634J Electric Dryer
Not enough heat is produced from the dryer
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 13, 2010 | Maytag Centennial 7.0 Cu. Ft. Super...
Not enough heat to dry clothes
You may find that they come as a kit, as I had one similar a long time ago.
Mar 13, 2010 | Dryers
My dryer spins and heat just a little but not enough to dry any clothes
Need to change the heater filament. The heater filament has several portions to produce heat. As it ages, some portions are not producing heat anymore hence the total heat produced by an old filament can not put out as much as originally designed.
Jan 08, 2010 | Estate EED4300TQ Electric Dryer
Model DLE7177RM, takes about 3 hours to dry a load of clothes. Dryer is NOT overloaded.
Does the dryer heat up or is it just cool air drying the clothes ? If it does actually dry the clothes eventually then it sounds like it is heating up. First thing to check would be exhaust hose. Is warm air blowing out of it ? If warm you got heat. If cool then your heating element isn't working. It should be fairly strong current of very warm air. If weak but warm, then somewhere between lint filter and end of hose you have a blockage caused by lint buildup or hose is bent and blocking air flow. Check hose first. You can disassemble lint trap and go beyond the lint screen into metal duct within dryer and clean with a long brush and vacuum. You can also disconnect exhaust duct flexible hose at back of dryer and work through metal duct from that end too. If you notice increased air flow then it should solve problem,
Aug 05, 2009 | LG Dryers
Dryer produces low heat but not high heat
check the vent outside it seems to be getting too hot and cycling the element off and on your safety therm.
Oct 22, 2007 | Kenmore 62802 Electric Dryer
Dryers Logo
215 people viewed this question
Top Dryers Experts
Marvin
Marvin
