Question about HP Officejet Pro L7650 Printer
L7650 scan error problem
I am trying to scan a 7 page document on my L7650. I keep getting a message on the LCD screen that says ''save error''
I have two L7650s and they both show the same error. They both started having this problem at the same time about three days ago.
SOURCE: hp 7680 give 'General Error, error saving file'
There is a bug in HP firmware that doesn't allow duplex scanning to memory cards. Once it happens, you need to power down and power on the scanner. (and on a couple of occasions, I had to reformat my memory card)
Posted on Oct 14, 2008
richa33
  • 71 Answers
SOURCE: Want to scan several pages as one pdf document
OCR to Microsoft word ,then
You can find a software tranfer like DOC word file to PDF file.
http://www.doc2pdf.net/
http://www.pdfonline.com/
Posted on Jan 31, 2009
  • 16 Answers
SOURCE: scanning...
What do you mean scan? Is it from the printer to the computer? Or just plain copy? When you want to scan to the computer, you need a software that can scan multiple pages. HP's document feeder can copy and fax multiple pages, so if the software supports multiple pages scanning, then I'm sure it can.
Posted on Jan 05, 2008
adonscott
  • 106 Answers
SOURCE: Scanning multiple pages
hi,
For you to be able to scan multiple pages using the .pdf and save it in one file, here are the steps that i want you to follow.
SOLUTION I.
1. Open the Solution Center.
2. Click on Settings, then go to scan settings.
3. Click on Scan preferences.
4. Make sure that the "Prompt for additional scans from glass/TMA has a checkmark. then click OKAY.
SOLUTION II.
1. Solution Center is open, click on Scan documents.
2. Scan document settings is open, choose SCAN TO: .pdf and file type is .pdf
3. Click on SCAN below. It will start scanning, and just click on ACCEPT everytime it gives preview on each document.
Thank you.
adonscott
Posted on Jul 04, 2008
  • 1894 Answers
SOURCE: Problem with scanning both from the auto feeder and from scanner glass
this is what HP has to say
This document applies to all HP product models. Issue When the product is turned on or in the middle of an operation, an unexpected noise occurs, such as clicking, thumping, or grinding. Blinking lights and error codes might accompany the noise. NOTE: Noises can be caused by a number of things. This document focuses on isolating, identifying, and resolving known causes of product noises. Solution Noises are subjective and can be difficult to describe. Some noises are normal to the operation of the product and might include the following:
  • The product might make humming and buzzing sounds as the carriage moves around on the right or left side of the product while cleaning the ink cartridges. This is normal when a product is turned on, before and after printing, after a product has been on standby for some time, after replacing an ink cartridge, or in the middle of a large print job.
  • During a print job, the movement of rollers, gears, carriage, and paper (paper feed and ejection) creates some noise.
  • During a print job, if the product is printing in the fast or draft mode, the noise level might be higher than when using the best or normal mode.
  • At the end of the print job, a louder clicking noise occurs as the paper is pushed to the output tray.
  • At the end of a print job, a noise emanates from the left or right side of the product as the pens are capped. The product might try to do this a couple of times.
Abnormal noises are a symptom of a problem. The most accurate way to determine the origin of a noise is to isolate where it comes from and when it occurs. Use the following steps to try to isolate the noise issue. NOTE: Error codes might indicate the source of the noise. Make a note of any error code or blinking lights that appear. Step one: Check for loose or broken parts
  1. Raise the cover of the product.
  1. Check inside for loose or broken parts.
  2. If there are broken parts, the product needs to be serviced.
  3. Step two: Make sure that accessories are installed correctly
  1. Press the power button (c00636182.gif ) to turn off the product.
  2. Remove the power cord from the back of the product and unplug the power cord from the power source.
  3. Check any accessories (duplexer, envelope feeder, automatic document feeder (ADF)) to make sure each is installed and seated correctly.
  4. Plug the power cord into the back of the product and plug the power cord back into the power source.
  5. Press the power button (c00636182.gif ) to turn on the product.
  6. If the noise still persists, remove each accessory one at a time to try to determine if the noise is associated with a single accessory or a combination.
  7. If the noise stops when a specific accessory is removed, that part might need to be replaced. If possible, exchange the accessory with a known good one or a new one to determine if the noise is associated with the accessory. NOTE: If the product is fully functional with the accessory in place, the noise might be normal.
  8. If the noise persists, proceed to the next step.
Step three: Check connection with computer Turn off the computer to determine if the computer is the source of the noise. If the noise persists, proceed to Step four. If the noise stops when the computer is turned off, try to isolate any issues with connectivity:
  2. Disconnect the USB cable from the product.
  3. Unplug the power cord from the wall outlet and from the back of the product.
  4. Wait a couple of minutes to allow static to be discharged.
  5. Plug the power cord into the wall outlet and plug the power cord into the back of the product.
  6. Connect the product to a different USB port.
  7. Turn on the computer.
  8. Press the power button (c00636182.gif ) to turn on the product.
  9. If the noise persists, service the product.
Step four: Check for a paper jam Paper jams can prevent the internal components of the product from moving, which can create unusual noises.
  2. Disconnect the power cord from the back of the product.
  3. Remove the rear access door.
  4. Remove any paper that is inside the product by pulling it out through the rear access door and then securely replace the rear access door.
    1. If a paper jam cannot be removed from the back of the product, raise the product cover, carefully remove the paper jam from the front of the product, and then lower the cover.
    NOTE: Remove any paper jam carefully as it is possible to damage the product when removing a jam from the front of the product.
    1. Reconnect the power cord to the back of the product.
    2. Reload the paper in the paper tray.
    3. Press the power button (c00636182.gif ) to turn on the product.
    4. Try to print. If a jam is cleared and the product prints, but the noise persists, proceed to the next step.
    5. Step five: Make sure that the carriage moves freely
    2. Disconnect the power cord from the product.
    1. Make sure that the ink cartridges are locked into the carriage and have not come loose. Also make sure that there are no obstructions under or around the carriage to prevent it from moving.
    2. Close the product cover and reconnect the power cord.
    4. If the noise persists, proceed to the next step.
    5. Step six: Plug the product into a wall outlet
    If the product is plugged into an uninterruptible power supply, that source might make a beeping or whistling noise.
    1. Unplug the power cord from any power strips or surge protectors.
    2. Plug the power cord directly into a wall outlet instead.
    3. Press the power button (c00636182.gif ) to turn on the product. If the noise persists, proceed to the next step. If the noise stops when plugged directly into a wall outlet, the power strip or surge protector might not be allowing sufficient voltage to reach the product and might need to be replaced.
    Step eight: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
    Comments by scrodamoon in premium
    Posted on Aug 05, 2008
    Can I scan on HP officejet pro L7650 all-in-one
    Upgrade ur drivers. Select printer icon n then rt click go to trouble shooting
    Feb 13, 2015 | HP Officejet Pro L7650 Printer
    Trying to fax, scan or copy and anytime I try the erro message Document in ADF press OK to discharge document
    Hi sdrnjen977,
    Here's what you can do to address the issue and clear error message: Document in ADF.
    If you press the Stop button during scanning, Document in ADF. Redo operation after checking document in ADF and pressing OK. appears on the LCD. Press OK button so that the remaining document is automatically fed out.
    Removing the jammed document from the Document Tray:
    1. If printing is in progress, press the Stop button.
    2. Turn off the machine.
    3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF, then open the Document Feeder Cover.
    4. Raise the Paper Release Lever, then remove the jammed page from under the roller to the Document Feeder Cver side.
    5. Pull out the jammed document from the ADF.
    6. Press down the Paper Release Lever, close the Document Feeder Cover, then turn on the machine.
    Removing the jammed document from the inner side of the Document Cover:
    3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF.
    4. Open the Document Output Slot.
    5.Open the Document Cover.
    6. Insert your hand into the Document Output Slot, then while pushing up the paper output rollers inside the Document Output Slot with your fingers, pull out the document from the inner side of the Document Cover.
    7.Close the Document Cover.
    8. Close the Document Output Slot, then turn on the machine.
    Hope this helps.
    Thank you for using FixYa.
    Jun 30, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
    I have a Kodak AIO 5 printer and Windows 7. I
    This is easily accomplished using Kodak AIO Home Center v5.3:
    Scanning documents from Home Center
    1 On the main screen, click Scan Documents and Pictures.
    2 Place your original document face down on the scanner glass.
    3 Select Document.
    4 Select the type of document you are scanning.
    5 Select a Resolution for your scan from the drop-down list.
    6 Select Perfect Page Technology to automatically correct imperfections in the scan.
    7 Select Next.
    8 On the Edit screen, edit each image as needed.
    9 Click Next.
    10 Select Save to File, then select Save As (pdf or rtf), Then Save.
    11 Select Done to return to the main menu.
    Jul 21, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
    Can I scan multiple pages to a PDF?
    1. Open the HP Solution Center 2. Click Scan Document 3. Document to PDF File 4. Change Settings 5. Save to File Save Options 6. Make sure One file per scanned page is not checked. 7. Click, OK > Scan 8. Ofter first page is scanned, position next page on scanner, then click Add Page. 9. Keep doing step 8 until all pages scanned. 10. Click Finish.
    Apr 01, 2010 | HP Photosmart Premium C309A All-In-One...
    Troble saving pdf after trying to make changes
    I would think either you need more hard drive space or more system RAM... thats a BIG meatball!!
    Jan 29, 2010 | Adobe Acrobat 9 Standard Full Version for...
    Canon mp630 scanner
    You can save the scanned data on a USB memory or a memory card by using the control panel.
    IMPORTANT
    - You can not use USB memory card and memory card simultaneously.
    1 .Select Scan (Scan) on page HOME (HOME) and then press the OK button.
    The screen where you select where the data should be saved is displayed.
    2 .Turn the USB memory card direct print port or memory card into the slot.
    3 .Select USB flash drive (USB flash drive) or memory card (Memory card) and then press the OK button.
    4 .Select Save on USB disk (Save to USB flash). The screenshot Scan documents (Scan document) is displayed.
    5. State the necessary settings and then press the OK button.
    6. Place the original on the glass plate as shown on the LCD screen.
    7. Press the [color] (Color) for scanning in color, or button [Black] (Black) for scanning in black and white.
    When the preview is enabled, press the OK button after viewing the preview pane on the LCD screen.
    The machine starts scanning and the scanned data is stored either on the USB memory card. Remove the original from the glass plate, the scan is complete.
    REFERENCE
    - You can only scan images continuously when you select PDF. Continue to scan the confirmation screen. You can save up to 100 pages of images in a PDF file.
    - If the USB memory card or memory card becomes full while images are scanned, saved only images that are already scanned.
    - You can save up to 2000 files of scanned data in both JPEG and PDF formats.
    - Folder and filename of the scanned data stored on USB memory or memory card is as follows:
    • Folder Name: (extensions: PDF): CANON_SC \ DOCUMENT \ 0001
    • Folder Name: (File Extension: JPG): CANON_SC \ IMAGE \ 0001
    • Filename: Serial number, starting from "SCN_0001"
    • File dates: 01/01/2008
    Mar 28, 2009 | Canon Office Equipment & Supplies
    Selected scanner was not found adobe acrobat
    first downloaded the trial version of Acrobat 7.0 and removed
    Acrobat 6.0. Test scanning ok it will worked!
    Proceed to uninstall the Acrobat 7 trial version and
    reinstall the 6.0 version you own, try this i hope it will work for you.
    All d best
    Mar 29, 2008 | Kodak Open Box i50 Flatbed Scanner
    Error message
    Hi-
    Its the operating system on the computer since it won't accept this types of images in your computer. Try saving the scanned document on a different folder/ or in your desktop. If everything fails, reformat your computer.
    Hope this helps
    Mar 16, 2008 | Epson Stylus Photo RX620 All-In-One InkJet...
    Scanning negatives on CanoScan 600F, I get an error message "Cannot write or read. 252.0.0"
    The Canon support site is the place to go for that if your Manual does not tell you.
    However remove the software and reload it - it may be as simple as that.
    Dec 26, 2007 | Canon CanoScan LiDE 600F Flatbed Scanner
    HP Officejet Pro L7650 Printer Logo
    49 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
