Question about Estate TAWX700JQ Top Load Washer
My Estate by Whirlpool Corp. TAWX700JQ3 will fill up no drain,spi
It will fill with water but wont spin, agitate, drain or anything.
The model: TAWX700JQ3
Please help me with my problem!!!!!!
  • 5,911 Answers
The problem is usually related to a lid switch malfunction. The lid switch is located under the right-hand side of the tub rim and is activated by a small plastic piece on the lid, called a "lid strike". First, make sure the lid strike is not broken off. Second, double check the two mounting screws that hold the lid switch in place along the tub rim opening on the right-hand side. Sometimes, all that is required is to tighten the screws that hold the switch in place to realign it with the lid strike. If all parts are in place, open and shut the lid. You should hear a distinctive "clicking" sound indicating the switch is activating. If the switch still does not work, replace it. The following link explains:
http://www.fixya.com/support/r397101-replacing_lid_switch
A replacement switch can be purchased on line at searspartsdirect.com. Just type in your model number and look under the "Top and Cabinet" heading. The lid switch is listed as item number 9 and the lid strike is listed as item number 20. If you're exact model number is not shown, any of the listed models will do. The part numbers are still the same. You can also try any of the following other websources: repairclinic.com, pcappliancerepair.com and appliancepartspros.com. They all offer great service and competitive pricing. I hope you find this information helpful. Let me know if you have further questions.
Posted on Dec 18, 2008
  • 36 Answers
Dear Customer
Please perform the following checks
Pease rate this,Thank u
Estate washer fills with water and stops. It wont agitate spin or drain
Try replacing the lid switch.
These are cheaply mad of plastic, and fail often on all washers.
God bless your efforts.
Jul 03, 2017 | Estate Washing Machines
My washing machine will not spin or drain,only fill up with water
Couple things could be happening;
Scenario 1: Your motor is dead, or the electrical connections leading to it are chewed up and no longer send electricity to the motor. If you have a voltage tester, you should see if you are getting power to it.
Scenario 2: The safety switch that stops the motor from spinning when the lid is open is compromised.. This is possible, but less likely, as the motor would still spin in agitate mode..
Jul 12, 2010 | Estate ETW4100SQ Top Load Washer
I got an estate whirlpool washer and it wont spin and i smell a burning smell
YOU HAVE SOMETHING STUCK IN THE WATER PUMP OR YOUR MOTOR COUPLING IS BAD
Jan 15, 2010 | Estate TAWX700JQ Top Load Washer
Washer keeps filling w/ water, only stops when changed to spin
Your drain line is too low.
OR the drain line is restricting air where it enters the drain stand pipe.
Remove the drain line and hold it up high.
Turn the washer on to fill. It should fill then stop.
This example should explain what you must do to correct the drain line problem.
Mar 12, 2009 | Whirlpool Washing Machines
Washer wont work.
try putting it on spi - do you hear anything? could be a broken belt - very easy to fix.
Feb 28, 2009 | Amana LW8203
Will fill water but agitator wont run.
Thats very agitating.There is a motor that runs the agitater,its either going out or you have lost the drive,a little spendy to have fixed.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
WATER FILLS AND DRAINS BUT DOES NOT AGITATAE OR SPIN
motor coupler is goingto be the issue, easy enough to replace, you can find a video on you tube, search "whirlpool motor coupling"
Jan 25, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
My washer will fill up and drain, but it wont agitate or spin
hi friend,
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many
washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub
that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's
attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the
hoses
from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the
large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using
needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator,
top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might
be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be
turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably
has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the
pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen
or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your
washer may be siphoning the water from a laundry tub that has a slow drain, back into the
washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck
in the drain?) Also, check for these problems:
* If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
* If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Nov 11, 2008 | Estate TAWX700JQ Top Load Washer
Estate TAWX700JQ Top Load Washer Logo
408 people viewed this question
Top Estate Washing Machines Experts
Marvin
Marvin
Starnley Johnwells
Starnley Johnwells
Justin Duby
Justin Duby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
