Home | Tritton Technology | TANGO Pro 20 GB Digital Media Player | "A HI SPEED USB dev...
Tritton Technology TANGO Pro 20 GB Digital Media Player
Problem for Tritton Technology TANGO Pro 20 GB Digital Media Player
"A HI SPEED USB device plugged into a non HI SPEED USB hub" error message, any idea?
By Ross - usenet poster
Best Solution
posted on Jan 11, 2006
Helpful)
Fafhrd
Rank: Master
Rating: 86%, 158 votes
fafhrd indicated that his solution for
DJ MP3 Player Problem
is valid for all MP3 and Digital...
This is not really an error message, it?s an informative message. This is new to the Windows XP operating system. All it is telling you is that your device (MP3 player) is a USB version 2.0 or higher and the USB port is only at USB version 1.1 or less. There is nothing you can do about this unless you replace your USB ports on your computer (you really do not want to do that!).
There is really no reason to worry about anything, your device (MP3 player) will work perfect with no risk of harming your computer or device. The only problem is that your device is made to run at high speeds and the ports on your computer are lower speed ports so the only thing will happen is that your device will slow down (take longer to put songs on it) then normal. Everything else is good to go! Enjoy!
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #2
posted on Mar 23, 2006
Helpful)
olavocker
Rank: Apprentice
Rating: 88%, 15 votes
olavo... indicated that his solution for
iPod Fourth Gen (40... Problem
This error may occur in case you do not have the proper chipset drivers installed. Make sure after you set up your operating system that you update the latest chipset drivers for your motherboard. They should come on a CD with your motherboard. Have a look at the manufacturer's homepage for the most recent update.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #3
posted on Aug 08, 2005
Helpful)
maartenw
Rank: Apprentice
Rating: 0%, 0 votes
The error message "A HI SPEED USB device is plugged into a non HI SPEED hub..." will appear when you plug a USB 2.0 device into a USB 1.1 port.
The device will work as it should, but you will not have USB 2.0 performance. For best performance use a USB 2.0 port.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #4
posted on Feb 07, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
RYRYRYRNHNJMMMMMMM
Solution #5
posted on Sep 15, 2009
Not Rated)
piekholik
Rank: Apprentice
Rating: 0%, 0 votes
no conect pc...........perlu mtv divece
Was this helpful?
Yes
No
Solution #6
posted on Mar 21, 2007
Not Rated)
Cattyy
Rank: Apprentice
Rating: 0%, 0 votes
I got the message of "Hi speed USB Drive attached to non_Hi-Speed Hub" when I plun in my Zen Microphoto MP3 Player into Window XP computer's USB port, and I am not able to connect my MP3 play to computer because of this.
What I did is while with the MP3 Player plug in, Go to device mangager and find "Creative Zen MicroPhoto" in Window Portable Devices, right click and select "update drive". I used the installation disk with Zen MicroPhoto and My problem is gone.
Was this helpful?
Yes
No
Solution #7
posted on Mar 24, 2006
Not Rated)
mick
Rank: Apprentice
Rating: 0%, 0 votes
My mp3 player does n't allow be to delete any file from the disk. It is say write-protected. When I put on the player it's showing hold. Please suggest to remove the write protection
Was this helpful?
Yes
No
Popular Solutions for Tritton Technology TANGO Pro
Questions and Unsolved Problems for Tritton Technology TANGO Pro
Do you recommend Tritton Technology TANGO Pro 20 GB Digital Media Player?
Answer
Answer
mi problema es que lo formatee y no tengo eldriver para bolber a ponerlo en funcion
Answer
I have a 2GB creative zen...is it best to let the battery completely drain until it turns off before... (More)
Answer
I have synced vidios on to it. When my ipod is connected to the computer it shows the vidios but... (More)
Answer
How can I replace me lithium Ion battery thats inside my nextar mp3?
Answer
hi guy's just wanted to ask probably a silly question to you guy's but i think that in the now it is... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Tritton Technology TANGO Pro...:
Top MP3 and Digital Med... Experts
Rank: Guru Guru
Solutions: 452
Experience: By using this stuff I know what I know when I know, but sometimes don't know how I know you know??
Ask Me
Find more MP3 and Digital Med... Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
