Yamaha 5 disc drawer will not open. - Televison & Video
  • 100 Answers
Its the problem of the door assembly.needs servicing or replacement.
Posted on Dec 18, 2008
Sony cdp-ce525 drawer won't open
How old is the DVD player? I have a Yamaha 5-disk player and the rubber drive belt that wraps around the drawer motor and connected to the pulley for the drawer was stretched out and useless. Just bought a new one online and voila!
Jun 16, 2014 | Yamaha CDC-745 5-Disc CD Changer
Yamaha CRX-330 CD drawer won't open
I had the same problem. It opened when I gave the reciever a slight lift and let it dropp, after I pressed the Reject Button. It's not a solution but at least it's open.
Jan 10, 2014 | Yamaha CRX-330 CD receiver
CDC-735
Part Number VQ776900. I got it online for 99 cents but other places can be up to 7-8.00 dollars. I removed 5 screws on the sides and rear of the case. Took case off. Press the open button and help the drawer open with your hand while the motor tries to. Then remove old belt with pliers or paper clip, etc.
I did not take anything apart on the inside to replace the belt. Push the belt into the player over the larger wheel and then I pulled the belt with a paper clip over the smaller drive wheel.
Mar 17, 2012 | Yamaha CDC-755 5-Disc CD Changer
I have a cdc 675 CD changer, When I close the draw it stays close about 10 seconds, the display reads "open" and it opens back up whether there are discs in it or not
It's reporting that it (correctly or incorrectly) detected that the drawer has not fully "closed", i.e., it thinks that there was a "jam" while the drawer was sliding towards the "closed" position.
This sounds (pun intended) like you need to take the unit to a qualified audio/video technician, to trouble-shoot, and maybe check the "alignment" of the drive-tray.
Sep 30, 2010 | Yamaha CDC-675 5-Disc CD Changer
Need drawer belt for Yamaha CDC-805 CD changer - the one needed that opens and closes the changer's door - not sure where to get it or the part number. I thought I ordered the right one and got the 'drive'...
Any decent repair shop should have a large supply of replacement belts. The Part number isn't necessary. Just take the old one in and get a new one just 2mm smaller than the original. Some repair shops won;t sell them because they don't want you repairing your own property but a decent shop should sell you one.
Apr 07, 2010 | Yamaha CDC-745 5-Disc CD Changer
How to unlock region code for Yamaha-DVD-S1800-DVD-Players
This worked last time I tried it. As with all region hacks you must first ensure that the remote has fresh batteries inside.
1. Switch the DVD S1800 on using either the remote or the front panel button.
2. Open the disc loading drawer and leave it open
3. Using the remote control press the "Clear" button.
4. Use the remote keypad to type in "2580".
5. Now press "Subtitle" on the remote.
6. Close the disc loading drawer.
7. Wait until the player has finished the loading cycle
8. Switch the device off using either the remote or the front panel switch.
When you turn the player back on it should be a region 0 (i.e. multi-region) player.
I hope that this has provided the answer you require, if so all I ask in return is that you remember to rate my answer.
Oct 21, 2009 | Yamaha DVD-S1800 DVD Player
DOOR KEEPS OPENING instead of playing
Hi. there is a tiny limit switch that regulates the actual CD platform drawer(The part where you lay down the CD). this switch if faulty. it is designed to shut of the load motor when the CD tray is fully inside the unit.
this limit switch must be replaced. this is a job for a qualified Yamaha service tech. contact Yamaha for this repair.
Jul 29, 2009 | Yamaha CDC-585 5-Disc CD Changer
Disc door keeps opening.
The drawer belt may also lift the laser up to meet the CD . If the belt is bad , the CD player will kick out the CD.
Change the belt.
Try studiosoundelectronics.com
or
mcmelectronics.com
Jan 11, 2009 | Yamaha CDC-585 5-Disc CD Changer
DVD S540-needs password and screen scrolls
Open Disc Drawer
Press 99990
Close Disc Drawer
or
Open Disc Drawer
Press 99990 and then press enter/ok button (!)
Tray was closed independently by itself
and that's it. Enjoy!
Feb 19, 2008 | Yamaha DVD-S540 DVD Player
The drawer open & close function on my Yamaha DVR C300 isn't working.
could be that the rubber band is need of replacement, take it in to radioshack and they will get you the right piece, it should cost you a few dollars
Jan 01, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
