Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
OLDER SEARS GARAGE DOOR OPENER WONT OPEN GREEN LIGHT FLASHING
WILL NOT RESPOND TO REMOTE OF IN GARAGE BUTTON HAS NO VACATION ON OR OFF BUTTOMS MUST BE 10-15 YRS OLD HAS WORKED GREAT JUST STARTED FLASHING A GREEN LIGHT TO THE REAR OF THE OPENER NEAR UP AND DOWN TENSION ADJUSTMENTS
IF I PUSH THE GREEN RESET TYPE BUTTON FLASHING GREEN LIGHT STOPS FLASHING BUT DOOR DOES NOT RESPOND TO REMOTE OR WALL UNIT
PLEASE HELP IF YOU CAN
THANKS GDL
    Sergeant:
    Champion:
  • 247 Answers
Do you have the sensors at the bottom of the door? if so they might be out of alignment. all you have to do line them up by getting the green light solid. let me know if this helps you.
Posted on Dec 18, 2008
My garage door starts down then goes back and the motor light flashes 10 times. The owner's manual only refers up to 6 flashes.
Richard, what is the make of your GD Opener unit? However, make sure the antena wire on the unit is turned up. 2. sometimes direct sun on the sensors prevent operation from the remote. 3.adjust sensors on both sides making sure the green or red lights are on.4. check the remote battery ensuring red light works when you press the remote button. 5. finally, has on vacation switch on the unit has not been switched on. GL
Dec 01, 2014 | Building Materials
I have a Merlin Powerlift model 430R roller door. The battery went flat in the remote and I replaced it. Now the door will not work via the remote.Works ok from red button on unit. I have tried to reset...
If the LED is flashing rapidly when the button on the remote is not pressed you have interference from something. Check for old remotes stored in a drawer somewhere or some new electric item nearby. Start unplugging things until that rapid flashing stops.
Apr 24, 2011 | Sears Craftsman LiftMaster Chamberlain...
Cannot get remote for garage door to work
push the green button on the opener then push your remote button
Jan 25, 2010 | Locks & Locksmithing
Craftsman Model 139.53684 Security+ Keyless Entry Garage Door Opener... Green light flashing on door control push button. Remotes no longer work. Can open and close garage door from keypad. Why is light...
To answer your question the opener is in vacation mode. Press and hold for 3 seconds the button on your wall control with the lock icon. The green light will stop flashing and you will be back in business.
Dec 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
My wired key pad in the garage opens and closes the door but the buttom keeps blinking fast. My two car remotes stopped working. My remote key pad on the house works. Whats with the fast blinking and...
Press and hold for 3 seconds the button on the wall control that has an icon of a lock. The light should quit blinking and your remotes will once again work. Holding that button for 3 seconds toggles your openers vacation mode.
Nov 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sear garage door wall mount contol light keeps blinking
Hold the button with the lock icon in for 3 seconds. This should toggle the unit off vacation mode and your remotes will work.
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman- garage door opens but will not open using the remote I changed the battery but the green light keeps on flashing,any suggestions if so you can reach me at chef3430@yahoo.com
If it is the green light on the wall control press and hold the button with the lock icon for 3 seconds and release. This will take the opener out of the vacation mode and your remote should work.
May 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door only opens with wall unit
a component in the wall unit is failing , that makes the conection happen when the remote signal is recieved , ( it is recieving the remote signal but not sending it out to the control circuit for the motor )
Dec 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
The remote opener reset button goes off and will not work
The green button is not a reset it is the program button.
If you hold the button down for about 20 seconds it will erase all codes. Then, press and release the button - press and hold the button on your remote for about 10 seconds. the next time you press it it should activate the door. Repeat the 2nd step for all additional remotes.
The lock button on the wall control locks out all radio signals for vacations etc.
If the lock has been activated the green led in the wall control will flash - when the lock is deactivated the led stays solid green.
Hope this helps
May 07, 2008 | Sears Craftsman LiftMaster Chamberlain...
Remotes don't work (3)
Did you inadvertantly hit the "vacation lock" button on the Mounted push button? This will cause the remotes not to work. Try hitting the button again, and then see if the blinking goes to solid green.
Good Luck
Jan 01, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,019 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
