Question about Onkyo HT-S680 System
Theatre Sound system only works with DVD, not on TV
Samsung LCD HD TV & Samsung Home Theatre System. No Theatre Sound when just watching TV. Audio cable (R&W) installed and still no theatre sound with TV only. Can you help me...All I want is to turn the TV on and to be able to enjoy the great theatre sound system while watching TV. :)
  • 93 Answers
SOURCE: Panasonic SCHT895GNS Home Theatre
Is there scart out on TV?
Posted on Oct 01, 2007
SOURCE: Onkyo subwoofer not working
I fixed my subwoofer. The resistor at R16 (right next to the fuse) was the fried component. I removed it and replaced it with a 13K ohm 5 watt metal oxide resistor (from Mouser Electronics if not available locally). Works fine now. I got the solution and the circuit schematic from an audio hobbiest at diyAudio.com. This is, evidently, a fairly common problem.
Posted on Nov 19, 2007
  • 15 Answers
SOURCE: TV Audio won't come through the Home Theatre Speakers
why it doesn't come. just connect the RCA cable to the output pins of TV and connect them to the input female jacks of home theatre receiver. or if the TV has optical out and the home theatre reciever had optical in. thats the best option. just connect one optical cable to enjoy the 5.1 sound. tell me clear problem if u r nt solved.
kanny_amancha@yahoo.com
kanny-sounds.blogspot.com
Posted on Jan 27, 2009
jhall1793
  • 60 Answers
SOURCE: need some sound to my home theatre system
Hey gr37_98:
1 thing to keep in mind with HT (home theater) systems is that when selecting a particular function that the input to the receiver matches the output to the TV/monitor. Example, you can play dvd's just fine because the HDMI output from the 958 matches the input to your monitor. Many consumers are under the mistaken impression that the home theater receiver can convert the HDMI to some other format, i.e. digital co-ax or optical. This is not the case. To use some other input the receiving device must have the same function & that particular input must be selected in order for the receiver to amplify it.
That being said, when you previously tried the digital co-ax connection did you specially select that input on your HT receiver? If you didn't, the receiver would be expecting to be processing audio from the HDMI input & would ignore the digital co-ax. You may also need to select that output on the monitor in order to active it, which, in most cases, would be odd. I was attempting to access the owners' manuals for these units & decided to respond with basic info hoping to get you up & running. Respond to this post if you have any additional questions.
peace-out
Posted on Feb 04, 2009
SOURCE: Samsung HT-BD2R 7.1 Channel Blu-ray Home Theatre System
If your television has RCA style audio/video output you can use an audio RCA cable (red & white connectors) and simply plug from the 'output' of your television into the auxilliary input on the back of the HT-BD2.
Then select AUX on the HT-BD2 remote, whenever you wish to listen to the television audio.
Posted on Mar 30, 2009
My home theatre was connected successfully playing the cd movie, but after turning off the dvd and go back to watching tv the sorroung system speakers do not give a sound to the television. is it that i...
hi,
select tv input on ur theater system. u can hear audio fro the frond left and right speakers. if u want to hear the audio from the surround speakers, then press the A-MODE button on ur remote to select different type of sound modes. press again and again to select different sound field. select one which suits u.
ok
Dec 27, 2010 | Curtis DVD5091 Theater System
I just bought a Samsung HD LCD 32 in TV and want to play it through my Home Theatre System. I set the TV to external speakers, put the HTS in aux mode, but I don't get sound. My old Samsung SDTV would...
If you do not have a manual for the machine down load one at http://www.samsung.com/us/support/downloads/LN32B460B2D
It will show you how to set up a Home Theater Connection
Connecting an Amplifier / DVD Home Theater
TV Rear Panel
1 Audio Cable (Not supplied)
Amplifier/DVD Home Theater
1 Connect Audio Cables between the
AUDIO OUT [R-AUDIO-L] jacks on
the TV and Audio Input jacks on the
Amplifier / DVD Home Theater.
When an audio amplifier is connected
to the AUDIO OUT [R-AUDIO-L]
jacks: Decrease the volume of the TV
and adjust the volume level with the
Amplifier's volume control.
Each Amplifier/DVD Home Theater has
a different back panel configuration.
When connecting an Amplifier/DVD
Home Theater, match the color of the
connection terminal to the cable.
Nov 29, 2010 | Samsung LN32B460 32 in. LCD HDTV
Installing a pioneer home theatre dvd/speaker system.
On page 36 of the Pioneer users manual, it describes how to set your audio for HDMI interconnect. Follow the directions, and hopefully it will work. You can down load the manual from the Pioneer web site. Google "speaker system HTZ171 DVD". Click on the Pioneer site for your system and look for the download on the right side of page.
I hope this was helpful...
Jul 25, 2009 | Pioneer 45X4 DFS BLUE LED CAR CD
1ST TIME SETUP OF NEW TV...HAVE AUDIO, NO VIDEO
Are you getting sound through the TV from the DVD, or is the sound from the DVD coming out of your home theater/surround sound system (if you have one)?
If it has more than one HDMI port (on the TV) try changing it. If not look around in your DVD settings as it might think it is only giving audio through the HDMI to a audio/home theatre system. And using the other video outputs to give the video instead.
It shouldn't be a problem with the cable, since it is digital, if it were not to work - nothing would, or the audio would atleast be coming out weird (it it wasn't working).
Feb 28, 2009 | Samsung LN46A750 45.9 in. HD-Ready LCD TV
No surround sound through tv
May be you have to set the Pro-logic option soundfield, this will matrix a 5.1 surround sound effect, unless of course you are sending a Dolby Digital 5.1 audio signal from your TV broadcast into the Home theatre system, also have to check the TV audio output to send audio output to a Home theatre system in other than 2 channel stereo.
Feb 09, 2009 | Insignia NS-H2002 Theater System
Samsung series 6 tv & Samsung 2:1 home theatre problems
if you got all the lead you should have fibre optics which connects from dvd to tv and then set your dvd to digi in. you should get the sound. i have same cinema system and i have done the same
Jan 13, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Problem getting home theatre sytem to play audio when watching tv
you need the red and white audio cable hooked into the AUDIO OUT connectors on the tv and the other end of the red and white cables into the AUDIO IN in tv to the media center (main Bose unit).....If your tv does not provide AUDIO OUT connectors, you cannot connect the tv audio to the 3-2-1 system. Continue using your tv speakers for sound.
Dec 26, 2008 | Samsung 1000W 5.1-Ch. Home Theater System...
I have no surround sound when watching normal T.V
Hi there, in order to listen to t.v you need to purchase an optical cable and plug this in the optical out of the tv to the optical in on the blue ray then select D.IN.1 on the blue ray and press mode on the remote until it says matrix . This will allow you to listen to the t.v through all speakers. hope this helps. Also remember to take the rubber protectors off the ends of the optical cable, a lot of people forget this :)
Nov 17, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Digital optical connection is creating any sound
Check to ensure the Home Theater is outputting the digital audio via the optical cable.
Nov 21, 2007 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
Home theatre problems sound
Did you try to connect AUDIO OUT from your TV to AUDIO IN on your package?
Oct 04, 2007 | Sony DAV-C700 System
Onkyo HT-S680 System Logo
52 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
