Question about Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Drive defect, repair or find replacement for HP laptop?
I have a HP nc6120 mounted with a CRX835E-H5 But the drive is defect! Tray won't open, and BIOS won't detect the drive. So I guess the circuit is burned. And the defect drive halts the system so I won?t boot. When I unscrew and remove the drive the PC starts up fine. (Just so you know ? I have another identical laptop, and if I mount the drive from this one the PC works fine ? so it is not the motherboard) Is it possible to repair the drive?? Is it possible to find a replacement drive?? I have found a original HP replacement, but its VERY EXPENSIVE. I have found another Sony drive close match on the model no. CRX835E-11 I bought this drive, but I cant make it work. It powers on, but is not detected by the BIOS. I flashed the HP BIOS ? but still the same problem. I talked to the company I bought the drive from and they just said: ?HP computers are made so they will only accept ORIGINAL HP parts? Can this really be true?? Hope someone can help. - Michael
  • Elderloup Apr 01, 2008
    Hi, I have the sony CRX835E CR-RW/DVD Rom but it just won't play DVD's and I can't find the driver. Can anyone help?
    Thanks
Some drives are set to slave and need to be flashed
Posted on Nov 05, 2007
  • 46 Answers
No this is not true but there is a hidden file on the bios chip and on the harddrive im told and all hardware must match these two drives or pc wont boot this is second hand info by the way regards
Posted on Sep 19, 2007
What is the proper procedure for opening the dvd drawer on a gateway ne 522 laptop
Locking device or software installed First, verify no locking software is being loaded that prevents the tray from opening. If you are unable to determine this, reboot the computer and as it is booting up, eject the tray. If the tray is able to eject as it is booting, but stops working after loading Windows or your operating system something is being loaded that is preventing the drive tray from opening. This is most commonly software such as a CD burner program that has taken control of the drive.
Bad eject button If you are running Microsoft Windows open My computer, right-click on the disc drive icon and choose the option to eject. If this ejects your CD-ROM drive tray, the button on the disc drive is defective and it is recommended that the drive be replaced.
Jan 06, 2014 | HP Computers & Internet
I have a hp laptop cd stuck inside how do you get it out
CD Drive Tray problems
There are two ways to open the CD drive door ifthe button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drivetray next to the Eject button. Push the paper clip gently until the drive traypops out, then pull the tray until it is fully out, then you can remove the CDdisc.
If you continue having problem opening with the Eject button, then the CD driveis faulty and needs replacing.
May 29, 2012 | HP Computers & Internet
How to fing the hdd size of my hp compaq nc6120
Go to Windows Explorer and Right Click on the HDD (C: drive) then go to properties this will tell you the size of the drive and give the amount of free space available as well.
Jan 21, 2012 | HP Computers & Internet
My cd rom drive has power but when you try to eject the tray it won't go out...my laptop brand is HP PAVILION DV7-1135NR ENTERTAINMENT NOTEBOOK PC
If you continue having problem opening with the Eject button, then the CD drivemay be faulty and needs replacing.
Aug 22, 2011 | HP (198702-001) Plug-In Module DVD Drive
I have a hp laserjet 4250 printer it had a paper jam in tray 2 i have cleared the jam but it keeps saying i still have the jam in tray 2
There is still paper stuck in the printer. try lifting the printer off of tray 2 to inspect it or here it is straight from the service manual...
Jams in tray 2
Table 7-10 Causes of tray 2 jams
Cause Solution
The feed or separation rollers are dirty, worn, or damaged. Clean the rollers. If they are dirty after cleaning, or if they are
worn or damaged, replace the rollers.
The pickup roller is worn or damaged. Replace the pickup roller.
The tray 2 paper pickup assembly drive gears are damaged
or the assembly is defective.
Check the drive gears in the paper pickup drive assembly.
Replace the pickup drive assembly if the gears are
damaged. See Paper-pickup drive assembly.
The tray 2 pickup solenoid (SL101) is damaged. 1 Disconnect the connector for the tray pickup solenoid
from the dc controller PCA (location J92).
2 Measure the resistance between the cable connectors.
3 If the measured resistance is not approximately
160 ohms for the HP LaserJet 4200/4300, or 110 ohms
for the HP LaserJet 4250/4350, replace the tray 2
pickup solenoid.
The tray 2 lifter-drive assembly or the stack position
sensor (PS107) is defective.
Replace the lifter-drive assembly. See Tray 2 lifter-drive
assembly and/or Printer switches and sensors.
The dc controller PCA is defective. Replace the dc controller PCA. See Dc controller PCA.
Dirty, worn, or deformed pick-up roller, cassette separation
roller, and cassette feed roller.
Clean the rollers if they are dirty. Replace any worn or
deformed rollers. The cassette separation roller and the
cassette feed rollare are to be replaced together.
Damaged gears in the cassette pick-up drive unit. Move the gears in the cassette pick up drive unit. If the
gears are not rotating correctly, or are damaged or worn,
replace the cassette pick-up drive unit.
Dec 25, 2010 | HP LaserJet 4250 Printer
Recomended replacement HDD for HP Compaq NC6120 (PG825EA#B1A). Original HDD "Toshiba MK8026GAX"
Circuit City currently haas some really great deals on the hitachi 500GB 7200/16 MB 2.5 Mobile Sata HD for approx $90 with no shipping fee. Simply to install and works like a charm. I have replaced about 6 of the original Toshiba hard drives in the past few months and not had a single complaint only complimentary feed back about the Hitachi replacements. Its worth looking into.
Item # H450-9100 BM
Feb 07, 2010 | HP Compaq nc6120 Notebook
Replace Optical With Hard Drive?
Unfortunately that model does not have a removable optical drive.
http://www.notebookreview.com/default.asp?newsID=2483
It mentions the fixed optical drive at the bottom under cons.
Nov 19, 2009 | HP Compaq nc6120 Notebook
Nc6120 1720-smart hard drive detects imminent failure (failing attr: 05)
Back up your data frequently as the hard drive will fail soon. When the hard drive fails you need to install a new one and install Windows on the new hard drive to get a fully functioning computer again.
May 05, 2009 | HP Compaq nc6120 Notebook
HP DVD 635 - auto tray open
no ghosts, you either have something jammed up inside of the drive which is keeping the door from closing properly all the way or the door itself is defective.
Either way you would be better off replacing the drive with a new dvd-rw cause the drive would be up to date and the problem with the opening door would go away.
Mar 21, 2009 | HP Pavilion a810n (PP164AA) PC Desktop
Unable to manually open the CD/DVD drive
There is a good possibility that the switch under the button has failed, especially if this drive has been used a lot. An electronics technician could replace the defective switch, but unless you have a good friend in that business, it will probably be cheaper to replace the drive with a new one.
Jan 13, 2008 | HP (350208-001) CD-RW/DVD-ROM (Combo)...
Sony CRX835E CD-RW/DVD-ROM (Combo) Burner Logo
272 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
