Question about Dell Inspiron 6000 Notebook
Dell Inspiron 6000 visual going bad
The bottom third of my screen fades to a frozen mix of color while the remainder stays clear and changes with selected page refreshes. If I apply pressure in the bottom left corner of the lcd itself the full screen comes bad with the exception of a few thin, lingering lines in the middle. I'd like to know if it needs a new screen, new inverter, or something else. Ideas?
  • Anonymous Dec 23, 2008
    Lower 1/3 of LCD has bad video. Flexing the display will correct the problem temporarily.
Restart your computer and go to settings and test your color maybe that should do the trick
Posted on Dec 20, 2008
My laptop symptoms are faded lines, fonts not crisp, various shades of the same color in the lines. I have replaced the monitor but that did not ellimnate the problem. I have a Dell Inspiron...
  1. Turn off the Computer.
  2. Hold Down the FN Key on the keyboard and press the power button, then Release both buttons.
  3. This should start your PSA Diagnostics
  4. You will see two color bar screens appear in succession, on the second color bar screen there is a message asking you if you saw the color bars. Press the N key for No to start the LCD BIST.
  5. The LCD BIST will run several full colored screens in succession with a beeping sound.
  6. Check for any lines, distortions, or abnormalities you were seeing in the Operating System here.
  7. Once the Diagnostics are finished you will see an Error message appear, this is Normal. Press the N Key to end the Diagnostics or Press the Y Key to continue the PSA Diagnostics.
  8. If no sysmptoms were displayed please continue on to the next step, if they were displayed please go to the last step.
An out of date Video Driver or BIOS can cause abnormal screen issues.
Visit the Dell Drivers and Downloads website and input your Service Tag to get updates specific to your computer.
If you need assistance in Downloading and Installing Drivers or BIOS. Click here for Installation Instructions
Click Here to Launch the Dell Drivers and Downloads Website
Dec 03, 2010 | Dell Inspiron 6000 Notebook
I have a dell inspiron 6000 laptop..the bottom third of the display has lines in it and i cannot see the mouse..but if i hold the corner towards me it clears up, but as soon as i let go i happens again
the screen may be loose or broken. If loose, you'll need to tighten up the screws that hold the screen and the cover together. If the screen is broken, you'll need to replace it.
Mar 19, 2010 | Compaq Presario M2000 Notebook
Dell Inspiron D530 - Screen Malfunction - Rainbow colors?
Reseat the display cable (under the keyboard) and while you have the lcd hinge cover off, inspect the cable where is goes thru the hinge assembly for chafing and possible broken wires.
If reseating doesn't help, RUN DIAGS
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&cs=19&dl=false&l=en&s=dhs&docid=E3FE44D4AAF58D13E0301E0A5517246B&doclang=en#1
If they fail then replacing the LCD display cable and or the LCD would be next.
Dec 09, 2009 | Dell Latitude D530 Notebook
Laptop Screen display problems
If you remove the LCD hinge cover, you will see where the cable is routed thru the hinge assy to the motherboard. You may have to remove the keyboard to reseat the cable connection to the motherboard. If that doesn't resolve, then the Cable or LCD itself is bad.
http://support.dell.com/support/edocs/systems/ins6000/en/sm/index.htm
Jul 03, 2009 | Dell Computers & Internet
The bottom third of my screen is black w/ fine lines of colors that coincide with the current screen
Dell Inspiron 6000 are notorious for developing screen faults. Dell won't do anything about it unless under warranty. Have the screen replaced by a repair shop unless you feel confident enough to do it yourself.
Jun 09, 2009 | Dell INSPIRON 6000 CENTRINO...
Vertical lines on lower third of dispay on Dell Inspirion 6000
bad lcd or video cable is not making good connection or is bad
Apr 10, 2009 | Dell INSPIRON 6000 CENTRINO...
Inspiron 6000 wont load up
Does the keyboard respond to any of the caps lock or numlock buttons when pressed ?
Mar 02, 2009 | Dell Inspiron 6000 Notebook
My WXGA 15.4" LCD laptop screen for DELL Inspiron 6000 is temperamental. Works most of the time, but when I start up computer the bottom 1/2 of screen looks like color streaks down it (all...
The issue could be one of 2 things. The image inverter or the LCD. From the description it could be either.
Both can be found here:
http://search.ebay.com/search/search.dll?from=R40&_trksid=m37&satitle=inspiron+6000+LCD&category0=
The inverter is fairly cheap ($20 to $50) the LCD around $150.
Service documents are here:
http://support.dell.com/support/edocs/systems/ins6000/en/sm/display0.htm#wp1006390
Aug 04, 2008 | Computers & Internet
Dell Inspiron 6000 Laptop LCD Problem
This is most likely going to be a loose connection. You will need to take the the plastic bezel that surrounds the screen off, the screws are hidden under the small rubber bumpers. Then take the screen loose, you will see he four screws holding the screen at the sides. Tilt the screen forward and you will see the connection on the back. Make sure this connection is seated properly, you may need to apply some new tape on it if it has any. Then check any other connections while you're there. If the problem persists, then the cable may need replacing.
Jul 31, 2008 | Dell Inspiron 6000 Notebook
Problems with Dell Inspiron 6000 Battery ? DELL Inspiron 6000 laptop battery is popular, why ?
You can also pick up the batteries less expensive than most computer places at batteries plus. And yes it sounds as though it is the batteries charge is getting low, especially if it runs fine when the battery is out and you have it plugged in.
Mar 13, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Notebook Logo
150 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
