Question about PSC PowerScan RF Base Station
Can i clone the configuration from another scanner?? please i need to know how to make this....
    Sergeant:
  • 274 Answers
You can contact them directly at either link: http://www.datalogic.com/ http://www.scanning.datalogic.com/html/contact.htm They may have software for it that does this.
Posted on Sep 11, 2007
Cloning of mc65
Contact Motorola Solutions.
Get Support
Mark
Motorola Mobility Support
Nov 07, 2014 | Motorola MC55/MC65 1-SLOT ETHERNET MODEM...
What is the four digit code for my pro 404 scanner
I plugged a 1/8 phono plug in the PC/IF jack over and over repeatedly and this fixed mine.
Jan 10, 2012 | Radio Shack Radio Communications
I have a pro 97 hand held cant get it out of clone mode
Your scanner is designed to automatically enter CLONE mode when a cloning cable is attached, and to exit CLONE mode when the cable is disconnected. If you do not currently have a cable connected, you will need to INITIALIZE your scanner to return it to normal operation. NOTE: Initializing the scanner will erase/delete all programmed data and return the scanner to its original factory settings. Before starting this procedure, be sure that you have a record of all programming information so that you can reprogram your scanner.
To INITIALIZE the PRO-97:
1. Turn the scanner OFF.
2. Turn the scanner ON. "Multi-system Trunking Scanner" appears.
3. Press the 0 (zero) key while "Multi-system Trunking Scanner" appears.
4. Press the 1 (one) key.
5. Press the ENT key. "Initializing please stand by" appears on the display for about five seconds.
Do not turn the scanner OFF until the initialization process is complete. When it is complete "M000" will appear on the top line of the display, and "Bank 0 Ch 00" will appear on the third line of the display.
Once the process is complete you can begin to reprogram the scanner.
Bill B
Listening in since the 60's
Oct 06, 2010 | Radio Shack Pro-97 Handheld Scanner
We recently received another 9520 from Honeywell to replace a faulty one. For the non-tekkie, how do I configure it for use with library scanning for books?
Bar Codes The MS7120 can be configured by scanning the bar codes located in the MetroSelect® Single-Line Configuration Guide. This manual is available for download at http://www.honeywellaidc.com/site.aspx/na/en/product_center/product_support/?category=5&product=297
Please let me know if you need further assistance
Kim Ganoe 800.933.2839 x251.
Mar 23, 2010 | Microsoft Metrologic MS9520 Voyager...
Need to mate my rotor with my cable internet
You need to get to the web configuration page of your router and clone the MAC address of your modem. It's because cable internet providers uses MAC address of a device to be able to connect to their server.
You can follow this manual to access the web configuration tool and look for the topic MAC Cloning Address.
http://downloads.linksysbycisco.com/downloads/WRT54GL-EU_11_UG_A-WEB.pdf
If in some case, your internet didn't work after connecting the router and after cloning the MAC address of your modem. Try to turn off your modem and disconnect everything from there, turn off your router as well and disconnect everything. Wait for 1 minute and plug the power cord back to your cable modem and plug the ethernet cable. Wait for 1 minute, turn reconnect everything to your router to the modem, and Clone the MAC address again.
Hope this helps.
Jan 13, 2010 | Linksys Wireless-G WRT54G Router
How do i clone my own desktop?
you just need to know all the settings and the programs you have into one ...and look for the installers and configure it in the same way ...after that set it like the other ...if it has the same specs will be just like the other ...also you might use a program that does this ...
http://blog.taragana.com/index.php/archive/top-10-hard-drive-cloning-backup-software/
Oct 26, 2009 | Dell Inspiron 1501 Notebook
Need to reprogram hand held pro 96
Radio Shack can "CLone" your scanner with one in the store - try that first to see if it will work and let me know.
Aug 19, 2009 | Radio Shack Pro-96 Scanner
Please help me to configure network scanner in develop ineo 250 model.If I check in Our Printer summery its showing optional printer is not configured but I give destination IP and folder path every...
alright follow these steps to properly configure the scanner on a network. first of all you need to make sure you have the proper drivers for the scanner. second, you need an IP, Subnet mask, and gateway that are all STATIC, not DHCP. you need to make sure that the folder you are trying to scan to is shared out correctly, and the scanner has full access rights to the folder, meaning a user name and password. if the folder is not shared out you will not be able to push a scanned image. any other questionns just let me know.
Jun 20, 2009 | Office Equipment & Supplies
I got cloned nokia 95(china) internet connection
You will need to configure this manually in your system menu. For any china mobile software like drivers and others, just check chinamanuals.com - they have the english manual for your N95 - including network settings. Ask them for Saudi Arabia settings!
May 02, 2009 | Nokia N95 Cellular Phone
Stuck in the clone mode
Sounds like you need to re-initilize it... Not certain of the codes, but I'll look around and see what I can find for you.
Good luck.
Tom
Oct 23, 2007 | Radio Shack Pro-97 Handheld Scanner
PSC PowerScan RF Base Station Logo
180 people viewed this question
Top PSC Computers & Internet Experts
Sardar Yasir
Sardar Yasir
Level 1 Expert
Tom Chichester
Terry
Terry
Are you a PSC Computer and Internet Expert? Answer questions, earn points and help others
