WAP54G wireless access point will not connect. Only lights on are fast flashing red and yellow but very dim
SOURCE: Linksys WAP54G connection to WRT54G
Ok, so why do you need an access point upstairs and a router downstairs connected wirelessly? If you can't connect with a laptop or a pc, why whould you think you could connect the access point? The purpose of this configuration would have to be with the access point to the router via ethernet. What's the point? If the problem is range, check out http://www.dd-wrt.com/dd-wrtv2/index.php to enhance the capabilities of the WRT54G... and maybe building a parabolic antenna for it as well. Plans to do so abound at Lifehacker.com.
SOURCE: Installing a Linksys Access Point to a Verizon Actiontek wireless router.
The IP Address of WAP54G is 192.168.1.245
Connect a computer to the Access point.
Assign a static IP Address to the computer, like : 192.168.1.10 , the subnet mask should be 255.255.255.0
Open the setup page of the Access point, by typing 192.168.1.245 in Internet Explorer / Firefox. Configure the wireless settings, Change the IP Address to the range that of the Actiontek router.
Save settings. To know about wireless security, click here.
To check the latest update on Linksys products, click here.
Hope that helps :)
SOURCE: my friend give me the linksys access point, but when i use it its
First connect your router with ethernet cable with 1 computer .
Then access this link
http://192.168.1.1 or
http://192.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
then go t o wi fi security then go to encryptripn key it is your password.to connect netwrok
Testimonial: "THANK U "
SOURCE: I am using lynksys wireless-g access point WAP54G
The default password for your router is "admin". Leave the user name blank. If a password has been set, you can reset the router or wait for the admin. When you log in, you will be able to change the password.
SOURCE: SETTING WIRELESS
1. Shut off the power to your cable or dsl modem for about 30 minutes.
2. Connect the ethernet cable from your modem to the Internet port on the router.
3. After 30 minute power on ONLY the modem NOT the router
4. Wait about 60 seconds and power on the router
Try it now.
