Question about Taylor 7532 Ultra Thin Glass Digital Scale
Taylor 7530 scale wont turn on,i have new batteries
Stopped working thought it was the battery
  • 6 more comments
  • Anonymous Dec 19, 2008
    I have the same problem. I changed out the batteries and now it returns "ERR" then "0 - Ld". Anyone have any ideas?
  • timmo53 Jan 24, 2009
    new batteries, won't start, reads "E" then "Lo"
  • Diane Rudy Jan 31, 2009
    I have the same problem, but after it displays E it shows 79.9kg and then won't display anything.
    I have the same problem. This is the first I've had to buy new batteries and I bought Energizer, a name brand good battery. Can't figure what this would be. I have contacted Taylor, but haven't heard anything as of yet.
  • Brian Nedimyer Feb 08, 2009
    New batteries as well. It reads 38.8 LBS or -----. Once and a while I can get it to peg out at mar scale. That is when it turns on.
    What I am thinking is that when the batteries died that scale lost its calibration data. The internal reference it uses for 0LBS and 350Lbs. (What ever the scales range is).....
    Well, I took the scale apart. Those jerks de-soldered the calibration button. There is no way to re-calibrate it or even set a zero refinance.
    All, you can do is demand a new scale or use it as a frisbee.
  • Natalie Oueis
    Natalie Oueis Sep 05, 2014
    I Just got a brand new scale an HOUR ago and it won't work!!!! I tried the batteries that came with it then i tried new batteries. This is unbelievable.
  • Faye mcclain
    Faye mcclain Sep 16, 2017
    I put in New battery now my scales doesn't work at all.
  • Pat Dolan
    Pat Dolan Jan 17, 2018
    The 7 seconds without batteries stepping on then off then new batteries worked for me.
Basically, the frisbee comment is on the mark. I called Taylor. a nice person walked me through a calibration exercise: take batteries out; stand on scale for 7 sec.; get off; put batteries back in (assuming they are still good); step on scale and if it reads ---- step off again, then back on to weigh yourself. My scale's display was blank, not -----, so they said calibration was unsuccessful & so I mailed it back to the NM address on the bottom. It just fits w/ padding diagonally in a USPS flat rate box. Waiting to see if they replace it (lifetime warranty).
Posted on Feb 08, 2009
    Problem Solver:
  • 10 Answers
New batteries as well. It reads 38.8 LBS or -----. Once and a while I can get it to peg out at max scale. That is IF it turns on.
Thank you! I went to the Taylor website from the link above and followed the instructions for resetting (under troubleshooting) and my scale works again!
Posted on Aug 16, 2012
  • Rachel Reddington
    Rachel Reddington Jan 21, 2014
    Me too!! I bought this scale for my husband for Xmas, no he was not offended, and was very embarrassed when he turned it on, stepped on it, and saw that he weighed 110lbs. He was thrilled, however. I immediately assumed it was way out of calibration because I had left it in the trunk of my car for a solid week in the ice cold Wisconsin winter, negative 10 to 20 below (F) overnight. I ended up on this website and saw the above directions on how to calibrate the scale. I followed the directions feeling foolish and not expecting any change whatsoever. To my surprise, it WORKED!!!! Calibrating it fixed everything and the scale works PERFECTLY!!!! Thank you SO MUCH for your helpful advice!!!
  • 74 Answers
This link allows you to trouble shoot directly with the company... I hope this helps. http://www.taylorusa.com/advantage/root/contact.html
Posted on Jan 07, 2009
Taylor scale model 7004 v1812 displays ee replaced battery and it still displays we
Found in a 2012 FIXYA post for a Taylor 7558 but this may work for you too!
"...make sure the batteries are CR2032 and NOT CR2032E batteries. My Taylor 7901 scale finally works!" More on this later...
Taylor 7558 scale not working even with new batteries
More...
The e on CR2032e denotes the manufacturer as Mitsubishi. Both are CR2032 batteries which means they produce 3V and 210 mAh (210 is the spec, 220 is a common claimed total energy content).
https://www.quora.com/Whats-the-difference-between-CR2032-and-cr2032e
I dunno... I just calls em' as I sees em'
Anthony
Dec 16, 2017 | Taylor Health & Beauty
Second request re: taylor lithium electronic scale model 7000 not working after changing battery twice. Yes interested correctly
On Amazon this scale got 24% 5 star and 43% 1 star rating.
In many cases it quit working or broke in some way.
"I owned this model for 1 year before it gave me the "batt" signal. after I spent another $7 on new lithium batteries, it turned out the scale was broken. looking on the web, I discovered lots of other stories like mine. advice: find another brand."
Aug 03, 2016 | Taylor Health & Beauty
the above answers are correct and need to be done but make sure the batteries are CR2032 and NOT CR2032E batteries. My Taylor 7901 scale finally works! Thanks for the advice. I love fixya.com because they always have the correct answers!!!!
Sep 12, 2012 | Taylor DIGITAL SCALE BODY FAT WHITE 1.0'...
When you get onto the scale (Taylor Lithium 7506), the numbers just keep cycling and never stop. We tried changing the battery, even though the scale is less than three months old, but it still does the...
Turn it over - take out battery and check with multimeter to ensure it is still workable - let sit for 10 to 15 seconds - replace battery - set it on level surface and step on and back off. Step on it again and it should now work.
Sep 16, 2011 | Taylor 7506 Precision Tech Lithium Battery...
I have 2 Taylor lithium scales and each one has stopped working. I have replaced the batteries and they still don't turn on.
The reboot below may clear theproblem from
your scale. You may need to do thisseveral times to completely reboot
the system.
1. Remove the battery from thescale
2. Set the scale on the floor withoutthe battery in place.
3. Stand on the scale for 10 seconds(still without the battery)
4. Carefully replace the batterywithout turning the scale on.
5. Using only one foot, tap the scaleor apply just enough pressure to
turn on the display. (It should showdashes or zeros) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weightreading.
Hope this will help you. GoodLuck.
Jul 15, 2011 | Taylor Health & Beauty
My scale just went blamk and wont show numbers even after re callibrating it.
Hello. when the scale goes blank it is time to change the batteries. Turn the scale over and you will see the battery compartment. Take the batteries to Radio Shack or Walmart and get the same in the new ones. Then be sure to install them correctly regarding the polarity [ the + and the -]
please rate my answer as very helpful. thank you.
Mar 26, 2010 | Taylor DIGITAL SCALE BODY FAT WHITE 1.0'...
Taylor 7532S, battery replaced, error message 0-Ld
Try to reset the unit. Use the following steps
- Open the battery compartment on the bottom of the scale. Push the tab on the door and lift the cover.
- Remove the battery from the compartment. Close the battery compartment door.
- Sit the scale right side up on a hard surface floor.
- Step on the scale and stand still on it for five to ten seconds. Step off the scale.
- Turn the scale over and open the battery compartment. Re-insert the battery. Close the battery compartment cover.
- Place the scale right side up on the hard surface floor.
- Press one foot on the scale until the display shows zeroes or dashes. Remove your foot.
- Wait for the scale to shut off by itself. When you step back onto the scale, it will be reset.
Hope this solution has been helpful?
Jan 26, 2010 | Taylor 7532 Ultra Thin Glass Digital Scale
I put the new battery in my Taylor 7004 V1812 and the screen rem
Check and see if you put the battery in right. Make sure the rough part is facing bottom.If this doesn't work your battery may be bad.
Jul 22, 2009 | Taylor & Digital Scale Lithium Scale
Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
1. Remove the battery from the scale
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Feb 11, 2009 | Taylor & Digital Scale Lithium Scale
Taylor digital bathroom scale
Oct 15, 2008 | Health & Beauty
Taylor 7532 Ultra Thin Glass Digital Scale Logo
11,594 people viewed this question
Top Taylor Health & Beauty Experts
Norman Worley
Thomas Perkins
Thomas Perkins
Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
