Question about LG VERIZON VX5200 Hands-Free Headset (Silver) 98323 / AAYN4264A / 22802H Headset
Half main screen showing
My main LCD on the phone will work every once in awhile when it isn't working I can only see about a half inch of screen and it's bugging the hell out of me because I'm a substitute teacher for high school and all I do is text bc they're able to do their work. please help!
0 characters
1 Points
Phone system not working
This can be complex, and easy, depends on what you can do yourself. If you have an old phone, you could plug it into the socket the provider is offering the service. If you get a dial tone, you know the line to that point is working. If the phone you are using now, is in another room, please do the same there. If you are sure the line is working, the phone has to be tested. Make sure the cable you are using is correct. Make sure the phone you are using is the right one. Don't try to connect a digital phone to an analog line.
These things are the first things in my mind. I write them down in less then 2 minutes and can keep you working and checking for at lease half an hour.
Nov 01, 2014 | Nortel Norstar T7316 Telephone NT8B27...
My mouse isn't moving on the screen
Hi I had this recently do you have a small oblong button right below the spacer bar you might have pressed it by mistake, while dusting etc, this freezes the pointer, also on my previous laptop I had the same problem but no button, so that was fixed by closing it down, unplugging it, removing the battery and replacing then switching back on, very important though to unplug from the mains......
Aug 27, 2012 | Razer Rz01-00280100-r3u1 Naga Mmog Laser...
One side of my tritton headset wont work
it has a short in one side of the headset. as much as you hate to hear it, you have to contact Triton and either have it refurbished, or buy a new one. The good thing is, Triton tech support is pretty helpful and will be glad to assist you. But for future reference, use steel series. as long as you save the receipt, if one side ever goes out, they will either send you a new one free of charge, or half price.
Jun 25, 2012 | Headsets
Screen Is White.
I had repaired about 10 Z520a that have the same symptom as yours.. It is because the Flex cable damage. The LCD are connected using this flex cable. You can purchase one from shop or at Sony Ericsson shop.
Jun 21, 2009 | Sony Ericsson Z520a Headset Headset
Pairing problem
As Quoted from Arfur - see bold print if you are having problems. You don't need to unpair the other phone, it will unpair itself.:
>Paraphrasing from the manual:
>1. Turn off headset.
>2. Press & hold the Multi-function button for 8 seconds, until >the lower half is lit up blue (not flashing).***THIS IS >IMPORTANT! KEEP HOLDING IT IN UNTIL IT STOPS >FLASHING! The whole thing will be lit up blue, but the lower >half will be brighter.
>3. Set your 'phone to discover bluetooth devices.
>4. Your 'phone will find the "Samsung WEP410" headset, & >ask if you want to pair with it. Confirm by pressing "Yes" or >"OK".
>5. Enter passkey or PIN "0000" (4 zeros), then "Yes" or "OK".
Jun 06, 2008 | Samsung WEP410 Bluetooth Headset Wireless...
Please help
replace the flip part it is fairly easy ..
you can locate a new flip on ebay or do a google search..
once you locate a can disassemble it with a t6 screwdriver.
Once open remove the ribbon that attaches the flip to the main board
attach the new flip reseat the housing and replace screws
Apr 30, 2008 | Nextel i930/i920/i870 Stereo Headset [OEM]...
Motorola H700 Bluetooth connection problem
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H700 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Apr 01, 2008 | Motorola Mobility Bluetooth...
Motorola blue tooth h700 set up
Solution 2 did the trick for me. Once I followed the instructions I was prompted for the passkey and I entered 0000, my ear piece finally works again! Thanks you!
Jan 03, 2007 | Motorola Mobility H700 Wireless Headset
Razr liquid damage
If you are handy - open the phone and clean the flex pad connectors with a cotton swab and a little bit of isopropyl alcohol.
Jan 02, 2007 | Motorola Mobility RAZR V3i SLVR L7 L8 OEM...
Headsets Logo
13 people viewed this question
Top LG Headsets Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
sonic boom...
sonic boom...
Sudeep Chatterjee
Sudeep Chatterjee
Are you a LG Headset Expert? Answer questions, earn points and help others
