Question about Proscan PS50700 50" Rear Projection Television
Tv wont stay on
When i turn it on, after a moment it doubleclicks off, then back on by itself...this will repeat 3 more times then stays off
  • susan schave Mar 29, 2007
    how do i go about getting it fixed....will it cost much? can u gimme a ballpark on the repair costs or a ref.? i live in the inland empire area. SoCal.
  • NavyWifeVA Feb 19, 2008
    My husband is in the military and is currently deployed. I went to turn on the tv and it clicked a few times and no picture at all. I am not sure what to do or if it is something that I can fix .. I am an electronically challenged if I do say so myself. Any help would be greatly appreciated.
    Navy Wife
    President:
  • 3,130 Answers
These are common problems with these sets.Mostly main power supplys or the sweep power supply. the set detects a short circuit, and tryes to reset but after three tries, it goes to stanby. Good Luck
Posted on Mar 27, 2007
Toshiba 65UL610U Wont stay on
Is the problem with the remote or your TV? Does it stays on if yiou turn your TV on manuall?
If so, you may have a contact problem with the remote and should take it to a repair service to get it cleaned
Jun 08, 2015 | Toshiba Televison & Video
Samsung TV model LN32A450C1DXZA, after turning the TV on it will turn itself off shortly after and then turn itself back on shortly thereafter. Then it repeats that several times before staying on.
If the tv is still under warranty, this can be repaired at no charge.
However, if not under warranty, you will need to have the CAPACITORS on the main power supply circuit board tested (or replaced).
The capacitors responsible for the power supply can sometimes fail - open the back panel. If the capacitors on the main power supply board look too fat, or signs of burning near the solder joints, then you've found the problem.
Hope this helps.
Cheers,
Scott
Feb 01, 2013 | Samsung LE Televison & Video
Toshiba 27af45 repeatedly turns itself off. Sometimes (usually) every few minutes, other times will stay on for hours. Works perfectly otherwise.
The fact that the television stays on for hours and other times turns in five minutes shows that your problem is intermitent .A defective component in the power supply is probaly causing the B plus voltage to go up.The TV can also have a dry joint which looks more likley i am curtain if you gave the TV a firm tap to the side when it come off it would come on back. Try it .
Dec 29, 2010 | Toshiba 27AF45 27" TV
Sony kdlf-50e2000 will only stay on for 5-1o min then the screen will go out?
If TV turns back on itself and repeat that on-off cycle then its time for new lamp in TV.
How old is this TV and when did you replace its lamp?
Sep 26, 2009 | Sony KDF-50E2000 50" HDTV
Sony Grand Wega KDF_60XBR950 turns itself off
Symptom shows its time to replace Lamp.
How old is this TV?
Apr 14, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
LG TV Turns itself off
Sounds like it could be a poor connection in the power plug or a ' dry joint ' on the power board, if it's the latter, it will respond to light thumping at the side of the tv. If that's the case it needs resoldering by a technician..
good luck !
Mar 30, 2017 | LG 32LG30 32 in. LCD HDTV
Sony KP-51WS510, standby led blinks 5 times
It sound like you have a bad picture tube...check your 1k circuit for correct voltage and wave form.
Oct 03, 2008 | Sony KP-51WS510 51" Rear Projection...
Intermittent power on/off
My exact same TV did the same thing. Your fuse us going bad. Go buy a new one and replace it.
Jul 01, 2008 | Panasonic CT-32G11 32" TV
My samsung projection television model pch521r wont stay on
when the set does come on do you notice any thing odd in the picture or sound of the set.
Aug 19, 2007 | Samsung PCH521R 52" Rear Projection...
Proscan PS50700 50" Rear Projection Television Logo
57 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
