Question about LG Microwave
Squirel cage locked up on my furnace
After it locked i smelled a burnt wire smell up staires i beleive comming from vents is this normal
  • LG Master
  • 9,086 Answers
Either the bearing has seized, or there is a bad connection on the terminal board where the wires connect to the motor.
I would spray the bearings with a good penetrating oil (I like PB's Blaster) and let it soak for a while.
Then spray it again and immediately turn the squirrel cage by hand and see how well it turns. If it's not smooth, it needs to soak some more and the bearings may be shot. Then you'd have to replace the bearings or the motor.
It is turns smoothly, you need to unplug the power cord and inspect the area where the cord plugs into the motor. Look for charred connections. In some cases (as I did to mine a few years ago) you can clean up and/or bypass the connections, making sure they are clean and tight.
If the connections are bad and cannot be repaired, the motor will have to be replaced.
I bought a spare from an independent heating and cooling guy. Saw his truck, looked him up and called him. He sold me a good used one for $20.
Here's a helpful tutorial on how to replace such a motor. Lotsa pictures.
Some good videos about it here.
We'rehappy to help you with free advice and we'd appreciate yourthoughtful rating of our answer.
Posted on Dec 18, 2008
I burnet a styfoam, and plastic cover in the microwave. The smell is awful, like melted plastic and burnt wood. My entire house smells horrible. Is there some way to get the smell out.
Try pouring some vinegar in a cup and microwaving until the vinegar steams. This works well when burnt popcorn smells up the microwave.
Apr 21, 2016 | In Microwave Ovens
What do i do about the tirntable not turning
first open door an take a good sniff see if you smell any burnt smell it could be a burnt out drive motor or a broken wire there are repair shops that do that DO NOT TRY AND FIX YOUR SELF read the warning panel
Jul 11, 2014 | Panasonic NN-H965 Microwave Oven
FMV152KBA
When a microwave gets a strong smell and then just stops working actually this means that something is bunt down in it, more of so the strong smell indicates that the HT (high tension transformer) inside has its windings burnt. If replaced check that while its on, its vent holes on the sides or at the back is not blocked, this helps it not over heat. Also check that the fan inside is working or else replace it too.
May 26, 2014 | Frigidaire Microwave Microwave Oven
Microwave smells like burnt wire
When you smell something wire is burnt..The first that needs to check is the inside wiring.You need to open the back portion of your oven to further see whats the problem behind..You can unplug from the source and using a MULTITESTER.Check both terminals setting yuor TESTER to OHMS value.If the TESTERS pointer moves a little it means its not short-circuited ans if otherwise moves to its maximum amount it means it is short-circuited that needs to be repaired..Wiring might have been burnt.If you gonna continue using it it might lead to further complications of defects.Try to check the motor that turns the turntable..check the heating filament.hope this helps.
Jul 07, 2011 | GE JE1640 Microwave Oven
Model JVM1630WB004. KW 1.58. 10 years old. No problems till now. Just stopped heating. Some burnt smell. Vented to outside thru duct. Everything clean. Is it fried? Also, cu. is not listed. What...
Check the door safety interlock safety switches for proper operation. If the switches are faulty, you can replace them. If you smelled something burning and it wasn't dinner, it could be the capacitor. You should have this dangerous electrical device serviced by a pro. The capacitor potentially stores up to 25,000 volts and may be lethal. The Cap is the silver can looking device inside with two or three wires on it. Expect to pay up to $150.00 for repair. Your machine is 10 years old, you may just want to replace it.
Apr 16, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Our GE dishwasher has been working fine for years. Now it is tripping the braker? all wiring is good right to the dishwasher. We did smell burnt wires but it went away.?????
Your dishwasher may be damaged beyond repair. When I installed the dishwasher in my home I found that there is a surprising number of wires bundled under the dishwasher. If you are skilled in that field you can pull the dishwasher out and try to repair the damaged wiring under the machine. However once you've smelled burned wiring it means that there are potentially significant problems in there. You aren't smelling the burnt wires anymore because the damage is so great it's just tripping the breaker. If you continue to try and force the machine to work in this situation you may end up with a fire and further damage.
Please be careful.
Apr 06, 2011 | Microwave Ovens
Smells like burnt wires
It is very possible it may have burnt wire or burnt capacitor. Remove unit, remove top cover and look inside to see if you see any burn marks or burnt wires. Also check fuse to see if it is good or not.
Aug 07, 2009 | Whirlpool MH1141XM Microwave Oven
GE Spacemaker XL1800 does not heat. All other functions appear to be working normally, the light comes on and the turntable functions. When turned on, it makes a humming noise slightly louder than normal,...
Possible bad heating element, You should remove the cover of the unit and look at the heating element with the power off. Until you get your problem resolved I would recommend not to even turn it on due to the fact that you are unsure what is going on and you smelt some burnt smell. Just for safety until you fine the problem
Feb 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Burnt smell in microwave from burnt muffin in a GE microwave
Many solutions are found here:
http://www.google.com/search?hl=en&q=microwave+smell+OR+odor&btnG=Google+Search
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 06, 2007 | GE JES738 Microwave Oven
LG Microwave Logo
78 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
