Question about SanDisk Sansa e250 MP3 Player
How do i reset my sansa e260 without using a program and if i have to use one where can i get it online for free
  • 758 Answers
1. Press the "Power/Menu" button and select "Settings" and then select "USB".
2. On this screen, select "MSC".
To format your Sansa, please follow these steps:
1. Plug your Sansa into your computer then open "My Computer", right-click the drive associated with the player and choose "Format."
2. Set "File System" to "FAT" if your Sansa's capacity is less than 2GB. Otherwise, select FAT32.
3. Click on "Start" to proceed in formatting your Sansa.
I hope that helps..
Computerrep
Posted on Dec 18, 2008
How to upload videos in sansa sandisk e260 mp3 player????////
Use the supplied Sansa Media Converter program to convert videos (and photos) to a format the Sansa can handle. The SMC also does the file transfer.
Oct 02, 2010 | SanDisk Sansa e260 MP3 Player
Purchased refurb e260 online, came with some songs loaded. Cannot delete them using RealPlayer. How can I remove them?!
Start the sansa updater, set sansa to recovery mode plug in to computer2.gif unplug when told sansa should restart (Lock sansa press and hold rec and menu until recovery begins)
Reset All
NOTE: THIS IS AN ADVANCED OPERATION AND RESTORES ALL SETTINGS
TO THE FACTORY DEFAULTS. NORMAL USERS ARE NOT RECOMMENDED
TO PERFORM THIS OPERATION!
If your device freezes up press the Menu button and hold for 15 seconds.
This is like a power down of the device. Once you perform the reset, the adjustments you made during last operation
will be gone.....
Go to my computer click on folder scroll to sansa and open the media folder and open each sub folder and delete manually then delete the folders Right click on your sansa then format a couple of times hope this works
Oct 21, 2009 | SanDisk Sansa e260 MP3 Player
My Sansa e260 v2 is frozen. I have rebooted many
Check to see if you have a boot file in one of the folders this is from starting the computer with the sansa connected if this doesn't work try to Reset All
will be gone.....
IF that doesn't work try to recover...download the update software and install then lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Star the update software if it doesn't start automatic goto /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa hope this works.... Please rate I believe you already have the software/firmware
Apr 21, 2009 | SanDisk Sansa e260 MP3 Player
E260 - now showing two empty directories (but I still have my music)
try formatting it. to do that, simply scroll down to settings, and in settings hit format. you'll lose everything that was on it tho, if that don't work then try updating. if your unsure how to update go here.
and install the program.
Nov 06, 2008 | SanDisk Sansa e260 MP3 Player
Sansa Updater Problem
Use the add/Remove hardware tool first
If that fails, go into Programs --> Sansa --> Uninstall
That's a new one for me - go ahead and call Sansa
Jun 27, 2008 | SanDisk Sansa e260 MP3 Player
Mp3player wont turn on with or without cord
For the Sansa e260:
Hold the power/menu button down for at LEAST 20 seconds, then let it go. Connect it to your computer, and it shoud begin to respond. This happened because there was a power glich in the system, and reseting the Mp3 player is what was needed. :) Hopw this helps all of you e260 users! :)
Feb 16, 2008 | SanDisk Sansa e260 MP3 Player
Why does this happen to my converter/e260? (pic)
the sansa media converter is only used for videos and pictures.
for song you go to my computer and u will see that it says sansa e260 you click on it then it will have files for music vieos pictures and recoding click on music and drag ur music on to it.
Jan 11, 2008 | SanDisk Sansa e200 MP3 Player
How to insall sansa e260 mp3
My same player did not come with the CD. Depending on which program you use to get your music on your player, the CD is not needed. Try connecting your sansa to your computer and open whatever program you use for your music.
Jan 01, 2008 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260
When it comes to deleting songs, I went on the program I use to get my music on and clicked on the sansa 260 and found my playlist. I bet if you connect your sansa and look around that program, you could probably find your playlist and start deleting.
Dec 30, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
46 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
