I recently had a technician delete all of the loaded programs of my vista system and reinstall all of the disks that came with the computer. I am not able to connect to the Yahoo applett to play any card games. Is there something I need to do? Thanks for your assistance. Ralph Osman rhusky1@aol.com
  • 395 Answers
Install java and flash player again and it shold fix it
www.java.com
www.adobe.com
Posted on Dec 18, 2008
Emachine will not run anything
Rundll32.exe errors typically occur in response to the inability of Windows to access an application, program or file as the result of a corrupted or missing DLL (Dynamic Link Library) file or in response to a rundll32.exe virus that has been designed to look like a normal Windows process.
Here are the easiest ways to fix rundll32.exe errors.
Click "Ctrl + Alt + Delete" on your computer's keyboard to open the Task Manager window.
Click the "Processes" tab and search for a rundll32.exe program.
If one is running and appears to be accessing a lot of your system's resources, click "End Process" as it is likely a malicious program and not a true Windows program.
Run software to seek out, detain and remove viruses, malware, spyware and adware. Often these malicious programs corrupt DLL files or cause them to be deleted or moved and, as mentioned, some rundll32.exe programs may in fact be viruses on your system.
Reboot your computer to update any changes you may have made recently to your files and programs.
Many programs and applications require a reboot for successful installation.
Uninstall a recently installed or changed program or application and then reinstall it using the default settings.
An installed program may not have loaded properly, an installation via the Internet may have been interrupted enough to create errors or the program may have a bug.
If you uninstalled a program and see a rundll32.exe error, reinstall the program and then uninstall once more.
Retain the services of a Microsoft certified technician, if all else fails, to review and fix your system's Registry.
Dec 01, 2013 | E-Machines Computers & Internet
Tip
My computer is running slow
In order to optimize your computer performance, follow the instructions given below.
1. Delete all of the temporary files.
a. Click Start, Click Run(Window XP) and type temp(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required), Click Edit at the top in the menu bar, click Select All, Right Click on Mouse and hit Delete. This would delete all of the temporary files.Note:in Window Vista and Window 7, Menu bar would appear by hitting Alt key.
b. Click Start, Click Run(Window XP) and type %temp%(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required), Click Edit at the top in the menu bar, click Select All, Right Click on Mouse and hit Delete. This would delete all of the temporary files.
c.Click Start, Click Run(Window XP) and type prefetch(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner,once you click Start), hit Enter, (hit Continue if required), Click Edit at the top in the menu bar, click Select All, Right Click on Mouse and hit Delete. This would delete all of the temporary files.
2.Run Disk Cleanup to free up wasted space.Click Start, click My Computer, right click C drive and click Properties. Now, click Disk Cleanup. It will delete all of the useless temporary files.If it ask to click Next, click Next.
3. Run Disk check.Disk Check program is used to check and clean any errors on your computer and keep it running smoothly.
How to run Disk Check:Click Start, click My Computer.Right-click on C drive, click Properties.Now, click the tab, Tools. In the Error-Checking section, click the Check Now. Also, check both of the check boxes: Automatically fix file system error and scan for and attemp bad recovery of bad sectors.
Now, You will see a message box that says you can schedule the disk check to start the next time you restart your computer. Click Yes. The next time you restart your computer, it will automatically run through a disk check before displaying your login screen. After the disk check finishes, Windows will automatically bring you to your login screen.Note: Check Disk can take more than an hour to check and clean errors on your computer.
4.Defragment Your ComputerTo arrange the files in a sequential manner, it is recommended to defragment the hard drive. Click Start, click My Computer, right-click Local Disk, aclick Properties.Now, the Tools tab, click Defragment Now. Now, Click first hard disk, click Defragment.Note: Disk Defragment may take long time like 30-40 minute to complete.
5.Stop Programs from running at the startup.
As soon as you restart the computer a number of programs load themselves at the startup and you will be able to see them at the bottom right-hand side corner. In order to stop some of the programs (except security software and programs which you use immediately after starting up your computer) to load itself automatically, please follow these steps.
Click Start, Click Run(Window XP) and type msconfig(Window Vista and Window 7-type in the Start Search box which appears at the botton once you click Start),hit Enter, (hit Continue if required)You will see System Configuration Utility. Click Startup at the top right hand side corner. Now,uncheck the items which you want to stop to load automatically.Now, click Apply and then click OK or Close. Click 'Exit without restart'Now, you have to delete the startup from registry.Click Start, Click Run(Window XP) and type regedit(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required),.Now, scroll up to the top and click Computer, rigth-click it and click Export and save it as file name say backup on the desktop.
In order to remove startup from the registry go the following locations:
HKEY_LOCAL_MACHINESOFTWAREMicrosoftSharedToolsMSConfigstartupfolder
Right click startupfolder and click Delete.
HKEY_LOCAL_MACHINESOFTWAREMicrosoftShared ToolsMSConfigstartupreg
Right click startupreg and click Delete.
Restart your computer.
6.Uninstall the useless programs(like gaming softwares, unnecessary toolbars like my web search, myfreeze toolbar)Click Start, click Control Panel, Click Add or Remove programs(Programs and Features or Programs in Window Vista and Window 7),you will see a list of the programs. Click on the programs, you want to uninstall and click Remove(Uninstall in Window Vista and Window 7).
7.Scan the computer with good antimalware, antispyware, antivirus.
http://malwarebytes.org/http://superantispyware.com/
8.Update the drivers on the computer.Click Start, Click Run(Window XP) and type devmgmt.msc(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required).Right click the device, click Properties.Click Driver tab, and click Update Driver.Follow the on screen instructions to complete update.
9.Upgrade RAMWindows can run slow if you do not have enough RAM.Many newer operating systems and programs use more RAM when they are running.How to check RAM.Click Start, right click My Computer, click Properties. You will see the RAM mentioned her.You should have at least 1 Gb(2 GB would be even more better)RAM.
10.Update Windows
Windows XP:Click Start, click Control Panel,Click Performance and Maintenance, Click System, click Automatic Updates tabclick Turn automatic updating on and click install updates.
Windows Vista:Click Start, click Control Panel, click System and Maintenance,click Windows Update,click Turn automatic updating on and click install updates.
on Apr 06, 2010 | Computers & Internet
I can't delete any of the d drive even after restoring factory settings
Which operating system ?
some operating systems have part of there operating system stored in partitions which are protected other operating systems like Vista have partitions which have there recovery back up and also are protected
Sometimes there's no better way to repair a damaged Windows XP install than to start from scratch and reinstall the whole thing. It's a drastic move, but it is almost guaranteed to work. (Only serious hardware issues or incorrectly installed files can cause errors in this case.) If all other options have been exhausted, and your computer still won't function correctly, fear not: After a reinstall it should be running as good as new.
Locate an XP install disk, preferably the one that came with the computer, and any other software packages and drivers. Most of the time these will come packaged with the computer at the time of purchase. To save your data, copy information in your "My Documents" folder and any other important data you might have stored on the hard drive to a flash drive, CD or an external hard drive. Insert the XP install disk into the computer's CD drive and reboot the computer. The computer should automatically boot from the disk, loading the blue Windows XP Setup screen. On some computers, you may need to press a button when prompted to boot from the disk. After the Windows XP Setup has finished loading files, press "Enter" as prompted on the screen to set up Windows XP, and then accept the Licensing Agreement on the next screen by pressing "F8." Navigate the partition menu to find the partition on which Windows XP had previously been installed (likely, there will only be one) and press "D" to delete it. Verify that you want to delete the partition on the screens that follow. Set up a new partition, press "C," set the desired for the partition and press "Enter" to create it. The new partition will now be listed on the previous partition menu. Select the newly partitioned space, and press "Enter" to set up Windows XP on it. The Windows XP Setup program will format the new partition and continue with the graphical user interface portion of the installation process after the computer reboots. Navigate through the set-up menus that follow. The setup program will reboot the computer and load Windows after it has finished installing files. Reinstall any drivers and software that may previously have been installed on the computer by inserting their disks and going through their installation processes. Download Windows updates from Microsoft's website. (See Link Below.)
http://www.microsoft.com/windows/downloads/windowsupdate/default.mspx
Mar 04, 2013 | Acer Aspire M3201 Phenom X3 8650 PC...
Hi i go to load windows n it comes up corrupt n error code OxOOOO14c n wont let me do anything wont even let me load my recovery disc or windows support disc
You mean error Oxcoooo14c? That means your system registry is corrupt, or even missing.
You can try this; and how to get Recovery Media info is also included:
Download the ISO file at the supplied link, and make a Bootable Startup Repair Disk from it.
Go into your Bios/Setup, or Boot Menu, at startup, and change the Boot Order to make the DVD/CD drive 1st in the Boot Order, then reboot with the disk in the Drive.
At startup/power on you should see at the bottom of the screen either F2 or DELETE, to go into Bios/Setup, or F12 for the Boot Menu.
When you have changed that, insert that Bootable Disk you have made in the Drive, and reboot.
http://www.bleepingcomputer.com/tutorials/tutorial148.html
Above link shows what the process looks like, and a how-to, as it loads to the Repair Options.
Neosmart contains the contents of the Windows Vista DVD's "recovery center," as we've come to refer to it. It cannot be used to install or reinstall Windows Vista, and just serves as a Windows PE interface to recovering your PC. Technically, one could re-create this installation media with freely-downloadable media from Microsoft (namely the Microsoft WAIK kit, a multi-gigabyte download); but it's damn-decent of Microsoft to make this available to Windows' users who might not be capable of creating such a thing on their own.
Read all info at the website about creating and using it.
http://neosmart.net/blog/2008/windows-vista-recovery-disc-download/
ISO Burner: http://www.snapfiles.com/get/active-isoburner.html
It makes a very good Vista Startup Repair Disk.
You can do a Startup Repair, System Restore, etc from it.
It is NOT a reinstall disk.
And the 32bit is what comes normally on a computer, unless 64bits requested.
How to obtain Vista recovery Media and/or use the Vista Recovery Partition on your computer to put it back to Factory Settings.
There is no legal free Vista download available.
Contact your Computer Manufacturer and ask them to send you a set of Vista Recovery disk/s.
They normally do that for a small $ cost.
Also, ask them if you have a Recovery Partition on your Computer/Laptop to restore it to Factory settings.
See if a Manual came with the computer, or go to the Manufacturer's website, email or phone them for info on how to do a Recovery.
Normally, you would press F10 or F11 at Startup to commence the Recovery Process..
Another way I have seen on some models is to tap F8, and go to a list of Startup options, and start a Factory Standards Recovery from in there, by selecting the Repair computer option.
Try the F8 Option to get into Safe Mode and try to do a System Restore:
http://www.howtogeek.com/howto/windows-vista/using-windows-vista-system-restore/
Do System Restore in Safe Mode, if unable to do it in Normal Mode.
Try tapping F8 at startup, and from the list of startup selections, select Safe Mode by using UP Arrow Key to go there > then hit Enter.
Try a System Restore once there, to pick a Restore Point before your problem..
Click Start > Programs > Accessories > System Tools > System Restore > pick a different time > Next > etc
If that does not work > Try the Recovery disk to do a Startup Repair/System Restore > if that fails, reinstall Vista.
Mar 13, 2011 | Computers & Internet
I need a new Windows Vista for my computer.I have got computer with Windows XP but I would like to have Windows Vista. What I have to do ?
First changing computer opering systems is possible. A new Vista operating system has to be acquire from retails usually $200 value pack. Attempting the install new operating systems is achievable only may require expert to ascertian whether the old would have to be deleted to make way for new. usually inserting the new disk into disk drive should capture new effects. Unless any peculair encounters were experieced, the installation change is achievale. The reason to allow technicain to perform the changes is to gurantee againts any situations that may occur least repairable by computer neophyte. estimate the program changes of $200 to acquire new system program and technicains experts installation may have raised costs. Installations of systems are usually same rates $49. Several options available to acquriing computers that has XP systems. Recent computers are windows 7. However, the used devices computer retails may have functioning computers with XP systems. Also, simple, acquire another computer system unit that performs on windows XP to be pluged into the monitor screen to attain experinces. Whenever required, the computer sytem unit with XP is interchaged with the computer with Windows Vista. Ironicly, i have a computer with Vista and would also need to convert to XP though experiecing cost conditions. Consider exchanging computers with me.
Feb 09, 2011 | Microsoft Windows Vista Ultimate Edition
Its slowing down and i want to reset everything were i could start off fresh
before you reset every thing lets do these steps
10.Update Windows
PS Please Note to leave a positive note.
Jul 08, 2010 | E-Machines eMachines Monitor E15T4
Slow running laptop
10.Update Windows
PS: Please leave a positive comment
Jul 07, 2010 | Dell Inspiron 700m Notebook
Forgot password
If you did not create a password reset disk you need a technician to do this for you. If there is another user on the computer you can remove the password from the control panel using there account.
Feb 23, 2010 | Microsoft Windows Vista Ultimate Edition
My computer is running slow it takes 10 mins to load up from start
things to try ,
1 depending if you have windows vista or xp or 7
if vista start, all programs, accessories, Command and prompt, Right Click it then run as administrator.
if xp just click it,
then Type chkdsk /f
this is a command to scan the computer for errors and fix them. reboot the computer and wait for it to do the scan this should make it a bit faster , try defragment , delete your browser history and cookies, disk cleanup on accecoties,system tools
Feb 17, 2010 | Computers & Internet
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
