Question about Tatung V30CMTT 30 in. HD-Ready LCD Television
My Wii system will not work on this TV when connected
I plug in the correct Audio and Video cables to the appropriate outputs and nothing happens
    Problem Solver:
  • 15 Answers
You have to plug them into the inputs of the tv
Posted on Jan 24, 2009
HOW DO YOU CONNECT CABLE BOX
Connect a Cable Box to a Receiver:
1 Gather all your tools, parts and cables together before you start the connection process. Chances are you will need to connect several items at the same time, including your TV, audio system and TV cable receiver. Your cable box manual is likely to include a diagram of how to make the appropriate connections, so it's important that you read it before attempting any links.
2 Connect the output of the cable box to the input of the receiver. If you are connecting an audio system as well, make sure the audio output cables go directly into the receiver and, from there, to the cable box. Avoid direct connections; instead, go through the receiver for all secondary connections.
3 Select the correct jacks for sound and video. A newer model of receiver should offer several options, including analog TV out and DTV out. It should also offer an S-video and a service port. Depending on the type of cable box you use, one or more of the same jacks will be available there, too. When connecting both systems, make sure cables go between similar outputs.
4 Use an S-video connection cable to link your TV with your cable box. S-video connection cables allow you to preserve good quality in both image and audio. Most cable boxes come with S-video connection cables, but you can get them at any electronics store. Once you have them, simply connect both ends to the right output. It'll be easy to identify, because it's usually the only round one available.
5 Plug the TV, cable box and receiver into an electrical outlet to make sure everything is working properly. If you are getting static or interference, you may need to tighten the connections or change the cables.
Sep 03, 2011 | Sony KV-35V65 TV
No component video with my Wii (component audio and HDMI video/audio both fine). It used to work fine, but now it won't show any picture regardless of which component IN I use. I checked all assigned...
Hello, I am sorry about your issue. Did you make any changes to the output resolution on the Wii. The output must be at 480i for the receiver to up-convert to HDMI. If there is a problem with the receiver I suggest a work around by connecting the component [red,blue,green] video outputs to the TV and the audio connections [red, white] to the receiver. Thank you, Onkyo USA
May 11, 2017 | Onkyo TX-SR606 Receiver
How do i connect my wii consol to my tv? I've connected all the cables correctly but nothing is showing on screen. My tv is a toshiba 37RV635D
1st ensure all the Cables are in the correct plug ie. input not output, as well as video or yellow in video, audio red and white in audio. 2nd make sure you set your TV to the input selection you used for your Wii setup. Hope this helps, Happy Gaming
Feb 24, 2011 | Televison & Video
I want to connect my philips home theater to samsung tv so how do i connect plz guide i hv three colour ep pin
Hi, to hook up a Tv to an home theater they are all the same process.
Instruction:
Make sure your playback devices are properly connected to your receiver. Whatever playback devices you use, make sure they are plugged into the appropriate inputs on your receiver. DVD and Blu-ray players, satellite boxes and cable boxes should all be plugged into video inputs, and CD players should be plugged into audio inputs. Your receiver will have labels on the back panel indicating into which input you should plug your devices.
Connect the video out to your TV's video input. Make sure you use the correct cable to make the connection. For newer receivers, the connection will likely be either HDMI or component. If your receiver has an HDMI output, use an HDMI cable to connect the receiver to the HDMI input on your TV. If your receiver uses a component output, use a component cable to connect your receiver to the component input on your TV.
Connect the audio output of your TV to one of the audio inputs on your receiver if you want to output your television's audio through your home theatre system. Most recent TVs will either use an optical cable or a digital coaxial cable to connect to the receiver, allowing you 5.1 channel surround from your television. If you have an older set, you will likely have to use standard RCA cables.
Turn on your receiver and press the "Setup/Menu" button on your receiver's remote. When "Input" appears on the display, press the right arrow key on your remote to select TV from the list.
After selecting TV, press the up or down arrow keys on your remote to select the audio input jack into which you have plugged your TV's audio cable. Press the "Exit" button on your remote to exit the setup menu and lock in the settings.
Tips & Warnings
Make sure you plug everything into the correct jacks or you will spend unnecessary time trying to troubleshoot why you don't have picture or sound.
Feb 17, 2011 | Audio Players & Recorders
Hooking up Wii with monster cable kit to Onkyo SR875 and Mits 73" HD TV. I cannot get sound through receiver. What am I doing wrong? I can hear the sound through the WiiMote, but no sound through my...
If the Monster cable kit is in fact compatible with the Wii, continue with the following instructions. Otherwise use the Wii connectors.
This is only one connection method for your equipment but the easiest and requires the use of only one additional cable.
Connect the audio and video cables from the Wii directly to your television. Then connect an audio cable from the "variable audio out" or "audio out" from the television to the audio input of your choice on the receiver. Then select that input on the receiver. Then select the input on your TV that you plugged the Wii into. Enjoy.
Jan 13, 2010 | Onkyo TX-SR875 Receiver
Can hook up my wii to this tv
The AV Multi Out plug that is included with the Wii will allow you to connect the console to most televisions or video cassette recorders (VCR). First, look at the back of your television AND your VCR and see if you have colored holes label "Input". Though most TVs have them, almost all VCRs do as well.
  • Audio/Video (AV) inputs are located on the front or back of the TV or VCR.
  • They are smooth silver posts with the inside showing a color, usually red, white and yellow.
  • Look for inputs marked Audio and Video IN.
  • The image on the left features stereo audio inputs. Some televisions have only one audio input. Click here for help setting up a mono audio connection.
  • Do NOT connect your system to anything marked OUT.
Where do you have these inputs?
Additional Options:
Connecting to a Television
  1. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console. setuptvav.gif
  2. Insert the RCA plugs on the Wii AV Cable into the input connectors on the TV. Plug the colored connectors into the following inputs:
    Yellow = Video Input
    White = Audio Input Left (or Mono)
    Red = Audio Input Right
    Interested in playing your games in Dolby Pro Logic II (simulated surround sound)? Click here setup information.
  3. Once the cables are inserted and the Wii is powered on, you must find the Input Select for your TV to view the game (it is likely not going to be seen on Channel 3 or 4). Typically this is found by pressing the TV/Video button on the Television's front panel or remote control. If you have more than one input channel, keep pressing TV/Video until you see the display from the Wii.
    If you do not have a TV/Video button, then the input could be labeled something different. Some other common input selects to look for on the TV or remote are: Input, Input Select, EXT, AUX, or a channel such as 00 or 99.
    Still can't find it? We have compiled a list of known input selects for many popular brands. Click here to see our list.
    Go to Next Step (Set Up of the Wii Remote) >
Connecting to a VCR, DVD-R, Cable Box, etc.
    In order to connect a video game system through a device such as a VCR, DVR, cable or satelite box, it must have Video and Audio "inputs." While most VCRs and VCR/DVD combos have these inputs, other devices typically have "Outputs" which will not work for playing your Wii console. Please verify the device you are attempting to use has these holes.
    While many cable/satelite boxes and DVRs may have "inputs," accessing them can be difficult. Please consult the instruction manual for the device you are connecting to, for more information.
  1. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console. setupvcrav.gif
  2. Insert the RCA plugs on the Wii AV Cable into the input connectors on the VCR. Make sure you are plugging the connectors into the holes labeled"Input" or "In". Holes labeled"Output" or "Out" will not work. Plug the colored connectors into the following inputs:
  3. Once the cables are inserted and the Wii is powered on, put your TV on the channel you use to watch movies (usually channel 3 or 4). Put in a video tape and play the movie. When you see the movie playing, press stop (do not power off the VCR!) and proceed to the next step.
  4. You will now need to find the Input Select for your VCR. This is usually a button on the original remote control that is labeled Input Select, AUX, Input, EXT, Line In, or a high or low channel. For more information on locating your input select, click here.
Nov 26, 2008 | Video Game Consoles & Games
Can't get my new wii to work
Hello.
Most likely it is not your console. Depending on what type of TV it is there may be many different inputs in the back. My HDTV has 5! It can get confusing. If you have it connected directly to the TV, note which ports the cables are plugged into, then make sure the TV is in the correct output mode. Ex...cables are hooked to Video 1 in, set TV to Video 1 output. Now if you are hooked up through a DVD or VCR player it could be different. If you are hooked up to your VCR and the VCR is hooked up to the TV, the VCR would need to be powered on also. It would be the same for a DVD player. I really hope this helps you. The Wii is very fun!
I wish you much luck. If you have any more questions, please do not hesitate to click on my "Ask Me" button.
Thank you.
Aug 01, 2008 | Nintendo Wii Console
Setting up Wii
why dont you hook them up to the tv?
Dec 30, 2007 | Nintendo Wii Console
Tatung V30CMTT 30 in. HD-Ready LCD Television Logo
131 people viewed this question
Top Tatung Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Josh Whitehead
Josh Whitehead
Are you a Tatung Televison and Video Expert? Answer questions, earn points and help others
