Question about Samsung HCN473W 47" Rear Projection Television
Samsung HCN473w out of focus
My TV went out of focus last night and using the perfect focus, it will only go as far as 4%. I'm not sure what to do from here, any help is greatly appreciated. Thanx in advance!
  • Jack M Nov 04, 2007
    THANK YOU!!! THANK YOU!!! THANK YOU!!!!!
    I just finished replacing the IC's on my HCN473WX.......IT WORKS!!!!!! I don't have a lot of soldering experience, but I am very much a handy man kind of guy and things went well.
    I have one issue....there are slight vertical lines in the picture (although very minor). I'd say the picture quality is about 90%. I cleaned tv with compressed air, the connections, double checked everything that I did - all looks good.
    From what I have read, I need to replace the capacitors on the convergence board - but that is only a guess. Is this the issue? If so, what is the part number?
    Thanks for all of your help up to this point!!!
  • jcotee Nov 25, 2007
    This problem (both IC's STK302040) was fixed by a Samsung authorized repair center july 06 - 1 month later the same thing happened - this time they took the set and held it for about 2 weeks - returned it and it ran fine for about 4 months- now the same problem is back. (out of warrentee). I have some expeirence in electronics, and took a look at the CG board and noticed a cluster of resistors that appeared to be burnt (RZ123,124125,126). rechecked solder joints for IC's replaced and they look ok. Does anyone have the specks for this cluster of resistors.
You better do not open the TV unles you know something about electronic. I was trying ti fix mine and did more damage. It is very hard to replace these chips if you do not have proper tools and soldering expirience.
Posted on Aug 10, 2007
    President:
  • 3,130 Answers
The convergence IC's in this TV set are bad. Both IC's should be replaced at the same time. They are labeled STK 392-040. Use only the ones that are not replacements but from a reliable source. The complete convergence board is no longer available from Samsung, so this is why these IC's need to be replaced. You will also need the service manual for this TV set as after vthe IC's are replaced you will need to go into the service menu and do a convergence alighnment. Good Luck
Posted on Mar 27, 2007
We have a Samsung PS50Q91HDX Plasma Tv which is not quite 3yrs old. Ever since we have had it, it turns itself on & off at random but this is not the main problem. Last night we were watching a show...
This is weird. I also have a plasma 50" model PS5Q91HDX and on the 5/02/11 the screen went blank when my friends daughter was watching a Wiggles DVD. The image kept coming back, flashing a scene or two before going black again. But the sound is perfect.
I wonder what is going on? Is anyone else having trouble with their 3-4 year old Samsung 50" TVs???
Jan 17, 2011 | Samsung Televison & Video
They went away along time ago now they are back why?they are colored sparkles on the tv screen/
Convergence is dead.Try Tv repair world.com to buy a whole convergence board for the replacement.The Samsung/Akai use the same convergence board.
Mar 22, 2010 | Samsung HCN473W 47" Rear Projection...
Samsung vp-d351
proper focus in any camera will see colors ..or else record in b& w and in bad focus... make sure your macro mode is off and norm-auto on... most focus problems are due to dropping or stuck lenses.
night mode might mean your day sense has gone bad... the white balance etc.look for a default setting and turn it on.
larry
Aug 22, 2008 | Cameras
Samsung 42" rear projection HD tv issue
1 they are either rebuilt or a defective returned to stock accidentaly
2 yes securly attaching it helps the heatsinks keep even cooler. no you don't need heatsink grease.
3 if the tolernace is very far out of wack then it woun't take long befor they blow. once you have instaled the new board turn on the set enter mute,1,8,3 then perfect focus on the remote let it do it's thing then shut off the tv and resart the tv and press perfect focus again.
Mar 05, 2008 | Samsung HCM4215W 42" Rear Projection...
Blue blurry on perfect focus
Did you try the manual lense focus in the back? There is a wing nut on it and it's pretty easy to change. You just need someone to look at the TV and tell you when it looks good. Additionally for the Blue tube, it's on the far left. You take off the bottom panel in the back to get to this area. Good Luck.
Jan 13, 2008 | Samsung PCN5425R 54" Rear Projection...
My samsung projection tv #pcl5415r don't want to perform perfect focus adjustments
perfect focus functions are based on service mode setup...or factory settings. if the alignment of these setting are loss then the unit wont perfect focus. does the unit have a complete loss of convergence. a complete loss of convergence indicate possible failure of convergence amps.
Jan 03, 2008 | Samsung PCL541R 54" Rear Projection...
Out of Focus
· Samsung parts for convergance problem
· http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Nov 24, 2007 | Samsung HCN4226W 42" Rear Projection...
Perfect Focus
Perfect "FOCUS" is a misnomer.Convergence is the real issue.Enter servicer mode--perform accurate convergence alignment procedure--activate perfect focus as last step to 100% alignment.If you have a High-Definition source,check procedure for that.
Sep 27, 2007 | Samsung HCN5527W 55" Rear Projection...
TV turns on but no picture.
Just had the exact same problem. A Technician from an authorized Samsung service center checked mine and said the convergence unit was gone and it does not allow the TV to turn on. He demo-ed by turning the convergence off and the TV turned on but the picture is very poor and out of focus. He also told me a need a blue tube and other parts for a total cost of ~ $800. No impressed as this TV is only 4 yrs old and is now worthless.
Aug 23, 2007 | Samsung HCN473W 47" Rear Projection...
Samsung HCN473W 47" Rear Projection Television Logo
430 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
