Question about Central System Cooler Ball Bearing Fan Deep 6.5" Long 40 CFM
Home Heater Unit Blows Out Cold Air
My home unit blows out cold air between the hours of 6p and 6a. NO matter how high I set the thermostat. Why? After 6am when I manually adjust the heat to a high temp hot air blows out...Please help!!
Throw the **** out
Posted on Jan 23, 2009
    New Friend:
    Problem Solver:
  • 7 Answers
There must be a clock on the thermostat. Look for clock settings
Posted on Jan 03, 2014
    Sergeant:
  • 359 Answers
Check the program on the thermostat first
Posted on Dec 23, 2008
Furnace in mobile home has a few problems
Sounds like fan & limit control
If temp on limit reaches max temp what happens gas valve deenergized,as MTR continues to run begins to lower temp. Thus reenergizing valve
Check filters,MTR speed for heating
Feb 03, 2014 | Coleman Heating & Cooling
Electric heater problems.
Plug in a ceramic 120 volt or oil type space heater to keep trailer warm. Most travel trailers are propane only, they do not have electric heat strips. I would bet that is why it only blows cold air.
Jan 28, 2014 | Open Range 2011 Mesa Ridge MR243F
I have a Frigidaire FAM18HS2A and when I turn on the heater, sometimes it blows hot air but most of the time it blows cold air. what is wrong and can it be fixed
if your frigidaire is not a inverter,he doesn-t work at outside temperature down -5.if it is a inverter you don-t have enought freon .
Dec 18, 2013 | Frigidaire Heating & Cooling
Have Goldstar Model R1804h ac/heater window unit when turned to heat blows only cold air what is easiest thing to check and purchase first.
If your thermostat is working on the Heat cycle (listen for "click" when turned up and down on Heat), then your heating coil assembly is probably bad. The heating coil is in series with a Fusible Link and a Bi-metal thermostat, if any of these three fails, there will be no heat from the coils.The Link and Bi-metal Thermostat are made up as part of the heater coil assembly.
Jan 18, 2013 | Goldstar Heating & Cooling
Wk Caprice heater blowing cold air? Fitted new heater tap and still blows cold a
sounds like you may need to replace the thermostat and also check fluid level....hope this helps ....good luck
Aug 13, 2012 | Holden Caprice Cars & Trucks
I want all cold air it blows hot out the back why
the back should blow out hot and at the front it blows out hot
the hot is the air in your room
Jul 22, 2011 | Heating & Cooling
Fan on outside unit cuts off for an hour or so while unit should
Hello Rett Check the fan selector switch setting on the thermostat.It should be set to AUTO position instead of ON.
Jul 15, 2010 | Heating & Cooling
My ducted heating continually blows cold air thru
Well, if need be, turn the breaker off. Turn it on when you need heat. Sounds like the fan relay is sticking or something if that sort. Is the tstat fan selector on auto?
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 17, 2017 | Heating & Cooling
20 year old central a/c heater not working
Check your thermostat and mode selector setting, thermostat setting should be set at warmer and mode selector setting should be at low heat or hight this is applicable for manual unit.
If it is a remote control just set the remote to heat mode.
sample only
Jan 02, 2008 | GE Quiet-Aire Ductless Split System Air...
Computers & Internet Logo
988 people viewed this question
Top Central Computers & Internet Experts
 Mikey
Mikey
ray gallant
 steve
steve
Are you a Central Computer and Internet Expert? Answer questions, earn points and help others
