Question about Digital Audio DA8012 12" Subwoofer Car Speaker
Neg and a pos on each side of car speakers
I have digital audoi speakers but need to know how to wire them up becuz they have two neg and pos posts
  • 27 Answers
Depends on your amp. If they are dual 4 and your amp is 1 ohm stable and you have 2 subs, wire red to red and then red to plus on the amp. If your amp isnt 1 ohm stable wire ch1 red to + on amp, ch1 black to ch2 red, then ch 2 black to - on amp. If this sounds like french to you, go to a stereo shop in your area and pay them to hook up your stuff. It will be a lot cheaper than buying a new amp and subs.
Posted on Dec 18, 2008
I have a WahlDorf sound system no instructions...its WD310HT Home Theater.its a subwoffer an 5 speakers how to connect to TV or DVD?
there is no info for a 310,but,there is for a 305,you need to make some cables for it,you need some rca cables with one end cut off,the rca plugs into the tv audio output,the two wires from each one,go into the push connectors,treat the outside wire as neg(black) and inside wire is always pos(red),,the top 2 push posts on the left are for the left audio from your tv,the 2 posts on the right are for the right tv audio,there are 4 more connectors for another device,like a dvd etc,push connectors operate by pushing in on them and pushing the bare wire into the little hole and releasing,
25715906-ghuqylfbvqx2ddmcce1obb43-5-0.jpg this is the only pic available,the 4 push connectors on the right are,tv right,pos,,tv right neg,then other audio right neg.,,the bottom one is other audio pos,,,,the 4 on the left side are left tv audio pos,,then left tv audio neg,then other audio left nrg,,then left other audio pos,,,
25715906-ghuqylfbvqx2ddmcce1obb43-5-2.jpg this is like what you need,the red is positive and bare is neg
May 27, 2015 | home Audio Players & Recorders
How do I hook up this unit Two wires or four
Almost all car batteries have 2 pos and 2 neg. More precisely, 1 pos post and 1 side connector, 1 neg post and 1 neg side connector. You only usually use use one set or the other depending on what connectors are on the end of your cables. You can connect something else to the side posts if you need to, but generally only pair is used.
Feb 28, 2015 | Cars & Trucks
Convert battery cables from top post to side mount replacement ends?
If all you are doing is changing to a side post battery, just connect all the positive cables from the old pos post to the new pos holder and all the neg ones to the new neg holder. If you've already cut them all off and not sure where each wire goes, all the reds are positive, all the blacks are neg. To make sure use your continuity meter to test. Connect one meter lead to any good clean metal part on the car and test between each black wire in turn, the neg ones will show a circuit, the pos ones will not.
Feb 10, 2015 | 1993 Chrysler Concorde
I have 2 audiobahn 12 inch 500 watt awc12t dvc woofers with 2 pos and 2 neg hook ups on each side of the speakers like this (- -) (+ +) and the same on opp side i need to know how to wire them to each...
OK. Sometimes manufacturers put two flat prongs to each of the positives and negatives of the voice coils. This allows for daisy chaining multiple subs to be easier. Here is how you want to wire your subs in the box.
From the positive post of the box to the positive posts of both voice coils (just choose one prong on each of them, you do not have to connect all 4 of them). So you will have 2 wires going from one post on the box to 2 posts on the sub. Got it. Not go from the negative post on the box, to both negative posts on the subs. Repeat this with the other sub. Now you can hook each channel of the amp to the box regularly pos of amp to pos of box and neg of amp to neg of box.
This set up is called parallel and will drop the ohms resistance of two 4 ohm voice coils to a 2 ohm load. You will get 2 ohms for each sub, thus connecting one sub to each channel. This will allow you to get the max power out of the amp or 150w RMS per your post. Hope this helps.
Aug 23, 2011 | AudioBahn AWC12 Car Subwoofer
I need to know wat colours do wat on a kenwood KVT-739 car Stereo DVD player wiring
yellow - constant power, red - switched or ignition power black - ground white - left front speaker pos. white/black stripe - left front speaker neg gray - right front spkr pos gray/black stripe right front spkr neg green - left rear spkr pos green/black stripe - left rear spkr neg purple - right rear spkr pos purple/black stripe - right rear spkr neg blue - power antenna remote blue/white stripe - amplifer remote turn on
Aug 16, 2010 | Kenwood Car Audio & Video
Does anyone haven a wiring diagram for a quad 4ohm voice coil subwoofer?
Basic wiring dictates that with a speaker with 4 voice coils all at 4 ohms each is meant to be wired in parallel. This will put the load at a 1 ohm total load on the amplifier. Wiring in parallel is positive out from amp to pos. to pos. to pos. to pos.. And neg. out from amp to neg., to neg., to neg., to neg..
Apr 09, 2010 | Eclipse SW9182Pro Car Speaker
How to hook up from post to post
if u have two pos. and two neg. on the back just run a wire from one pos to the other pos and do the same with the neg just run the wire from the box to one of the pos and neg only on one side u have two wires runing to them
Sep 28, 2009 | Kicker CVR12 Car Subwoofer
Need wiring diagram for sub
u should have two pos, an two neg. on the back of the sub run a wire from one pos to the other same with neg. now just run a pos an neg from the box to one side of the sub u should have one side with two wires runing to the pos. an neg. if u need more help let me know bertman285@hotmail.com
Apr 25, 2009 | Car Audio & Video
Installing 4 after market speakers in my Ford F-350. POS/NEG post
this is actually a quotation from a site on the net as i've wondered about it to
"Speaker wire has a mark or strip on one of the conductors this is to indicate polarity of the wire. When installing speakers to the output of an amplifier you need to observe the proper polarity. This is particularly important when installing a surround sound system with front and rear speakers. If the polarity is not followed then the results will be poor balance of sound and even cancellation of some frequencies."
Robert
Jan 21, 2009 | 1994 Ford Mustang
Car stereo wire diagram for 88 toyota tercel
1988 toyota tercel sedan as follows
pink = (+) pos. for left front speaker
violet = (-) neg for left front speaker
light green = (+) pos. for right front speaker
blue = (-) neg for right front speaker
blue/yellow = (+) pos at all times (power)
grey = (+) pos. only in the accessory or run position
brown = (-) neg gound
red = (+) pos. right rear speaker
black = (+) pos. left rear speaker
white = (-) neg right rear speaker
yellow = (-) neg left rear speaker
verified at 2 resources . fixya
Dec 26, 2008 | 1988 Toyota MR2
Car Audio & Video Logo
175 people viewed this question
Top Digital Audio Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Digital Audio Car Audio and Video Expert? Answer questions, earn points and help others
