Question about Plumbing
Kubota kx91-2 excavator keeps stalling.
Hello. My mini excavator keeps stalling from the main boom and track drive. It won't respond very well when steering. Drives well when going downward but struggles on flat and uphill. Only steers sometimes but most often I need to work levers back & foward to get it to turn. I think the original pump has been replaced and the diesel injectors and pump have been repaired. So if anyone has any ideas it would be a big help. Regards Darren.
  • 15,935 Answers
Check fluid levels and viscosity of fluid. The valve spools may be also sticking. Remove, clean and replace them as well.
Posted on Dec 22, 2008
I need parts list for Kubota excavator rx501
As you may well be aware, Kubota USA does not offer any support for your tractor. This is because that model is a "gray market" item (that has been banned for importation in 1997). Kubota initiated this legal action because the unauthorized importation, distribution and sale of Kubota "gray market" tractors by individuals or companies independent of Kubota adversely affected Kubota's reputation in the United States and with the United States consumer. Following an extensive evidentiary hearing in the Fall of 1996, the United States International Trade Commission affirmed a finding by the Administrative Law Judge that the importation, distribution and sale of these "gray market" tractors infringed upon Kubota's registered trademark, issued a General Exclusion Order prohibiting further importation, and issued various Cease and Desist Orders against the respondents. The Court of Appeals affirmed the Commission decision. Such "gray market" items typically are of inferior quality and/or workmanship.
However, you ca find what you need at 3rd party suppliers. Try this one: http://www.kenkidepotneo.com/cgi-bin/heavy_equipment_parts.cgi?category_type=&category=FILTERS&equipment_type=&equipment=&maker=KUBOTA&model=RX501&part_no=&page=
Apr 05, 2016 | Cars & Trucks
How to remove front idler on bobcat 331 mini excavator
Bobcat 331 Mini Excavator, Front Idler Assembly
www.loaderpartssource.com/bobcat-331-mini-excavator-front-idler-asse...
Loader Parts Source, Inc. offers this Front Idler Assembly for Rubber Tracks (W/ Holes in idler) for replacement on the Bobcat 331 Mini Excavator. Serial Number ...
Bobcat Idler: Construction Equip Parts ' eBaywww.ebay.com/bhp/bobcat-idlereBayBobcat 325, 328, 331, and 334 Front Idler - Undercarriage, Mini Excavator, ... BobcatT140 T180 T190 T200 T250 T300 T320 T650 T630 T750 864 Front Idler ...Undercarriage Parts Can Help You:Eliminate Unwanted Machine Downtime.Front/Rear Idlers - Mini Excavator Partswww.miniexcavatorparts.com/productcart/pc/viewCategories.asp?...14Aftermarket front and rear idlers are available for Bobcat track loader and mini excavators, Kubota miini excavators, and ... Aftermarket Bobcat® Front Idler - Bobcat CTL ... Aftermarket Idler - Bobcat 325 328 331 334 430 335.
Dec 25, 2015 | Mini Cars & Trucks
What do all the instrument lights stand for on my kubota rx 302 mini excavator
kubota owners manual for rx 302 mini excavator pdf - P(1 ...
www.search-document.com/.../kubota-owners-manual-for-rx-302-mini-e...
Looking for: kubota owners manual for rx 302 mini excavator ... 3.4 Flow testing, regulating & setting the excavator OEM relief valve. ... of the parts, even those ...
Manual KUBOTA RX 302 - User's Guide KUBOTA RX 302 ...
www.manuals.club/results_alpha.php?search=KUBOTA+RX+302
KUBOTA > KUBOTA > RX 302 > 10 results for : KUBOTA RX 302 ... KUBOTA - KX 008 (KX008) Mini Excavator (User's Guide in French) · KUBOTA - K008-3 Mini
Oct 27, 2015 | Garden
121-3 runs great for 5 to 10 minute then when under load tries to stall let up on the load engine catches up change all filters this started when I was digging for 10 hour in very hard dirt
OK you've got me tricked.
The 121-3 is a Kubota number.
If this is a mini excavator, and I own big ones, this is where I would be getting my friendly QUALIFIED mechanic to check the pressures at various points and do the trouble shooting.
Aug 11, 2015 | Caterpillar Backhoe Tractor
Kobelco 120 excavator sometimes one track will not drive.
Filter or pressure relief valve, or track feed valve. Otherwise you are in for a big bucks drive motor.
If it were the pump you would have bad everything.
May 11, 2015 | Cars & Trucks
My mini excavator 334 lost hyds to boom and tracks. blade still goes up and down .the red ! light is on
could be a bad solenoid find out which on works that solenoid , make sure you are getting power to it could also be fused ck that first , cannot be to much to fix ,get a manual of it to ck the solenoid position
Nov 25, 2014 | Mini Cars & Trucks
My KX 41 kubota mini excavator is smoking
Valves need ground, injectors overfueled, if a lot hours, rings maybe bad.
Jan 26, 2014 | Garden
Hitachi excavator
Hi I have the same problem,zx16hitatchi mini and I've been told it is track motor needs replacing? Or it could be a seal gone in one side of the spool valve for that track, on the hydraulic pump? Ask a local digger parts dealer for a good repair shop in your area.
Dec 03, 2013 | Hammering
Boom creeping down on case c28 excavator
your spool valve needs rebuilt
Nov 01, 2009 | Garden
Plumbing Logo
696 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
