Question about HP Photosmart 3310 Printer
L7780 won't scan
All of a sudden, my L7780 won't scan.  The message I get says, "the device you selected does not support scanning.  or I get "scanner not found"  Do I need to reinstall the printer/scanner software?  Is this one of those goofy HP problems I see posted all over this site?
    Sergeant:
  • HP Expert
  • 367 Answers
First test: try a photocopy to check the scanner is actually working. If copy is blank or defective then you have a faulty scanner.
Second test: are you scanning to device/PC by USB cable or network. Network scanning is notoriously fickle and may need you to completely uninstall and then completely re-install the device. You may also need to remove all references to the scanner in you registry. If scanning by wireless - forget it and use a cable.
Posted on Feb 13, 2018
SOURCE: Scanner Problem
The Laserjet 3050/3052/3055/3390/3392 FULL software version 4.0 (27 Mar 2007) for Windows Vista. Check out HP's download page or click the following for the US & EU version: http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=1161389&prodNameId=114078
0&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ma-38114-4
This should fix all your problems
Posted on Aug 27, 2008
SOURCE: Scanner not working on Canon MP 210
As for the drivers, go to the following link and then click on the "Drivers and Downloads" tab, then choose your operating system. It should then give you the drivers under the "Driver" heading right below the operating system drop-down box. The software is there as well.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=116&modelid=15402
Posted on Nov 21, 2008
SOURCE: error message 0x8021000E
scanner will not scan. Comes up with error (ox8021000e)
Posted on Mar 26, 2009
  • 26 Answers
SOURCE: Scanner not detected by Microsoft Office Document Scanning
1) Install the Microsoft Office Document Imaging feature by following the steps
given below:
1) Go to Start -> Control Panel.
2) Click the Add or Remove Programs.
3) Select the Microsoft Office Professional Edition 2003 and click the Change
button.
4) Click the Add or Remove Features and click on Next.
5) Select the Choose advanced customization of applications checkbox and click
Next.
6) Click on the Office Tools -> Microsoft Office Document Imaging -> Scanning, OCR
and Indexing Service Filter.
7) Select Run all from My Computer, insert the Office installation CD, and the
feature is installed.
Posted on Apr 11, 2009
madguy1089
  • 21 Answers
SOURCE: i have a lexmark x3350 and the scanner wont scan
Alot of the X3350 all in ones have there scanners go bad if you still have a warranty for this printer then call Lexmark if not then you can go out and buy one for like $85.
Posted on Apr 28, 2009
How to get windows to see the scanner every time.
Buy and install the 'Viewscan" scanner driver utility.
Then: Found that for windows to reliably see the scanner start windows, go to device manager, turn the scanner on and as it goes through its setup, right mouse click and select "scan for new devices" Windows 7 will now see the scanner right away.
May 13, 2014 | Acer ScanPremio 1220ST Flatbed Scanner
I have an HP L7780 that I can print to - - but when I try to scan an error message comes up saying "No HP device has been detected"
check cable connection, check at contol panel printer and fax, select the print that online, may you chose print that offline
i hope this helpfull, please rate very helpfull or helpfull if you think this helpfull
thanks for using fixya
Jan 22, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
Cannot scan documents
go to device manager look for imaging device (scanner) right click and uninstall. / click scan for hardware changes tab, found new hardware must be appeared and click next / select don't search, i will choose the driver to install / click show compatible hardware and choose scanner driver found and click next. and finish.
Feb 11, 2010 | Fujitsu M3091DC Path-Through Scanner
Will not Scan. Gets message..
Is it installed in windows as a scanner? Dont use scan button on machine try using scanners or document imaging software that needs to be in place on your computer, ie Document imaging in office or scanners and camera in windows, one sends scan signal from the PC, can use the scan button on scanner only when configued to do such. Scanner has software as does the printer both can found at HP web
Nov 07, 2009 | HP Photosmart 3210 Printer
The device will not scan a paper document to my computer - the cord is connected and the driver is installed
First, power off your scanner, then shut down the computer. After reboot test the scanner again. If you still can't scan, verify that you have the correct driver for your scanner. To check for your current driver click start --> Control Panel --> Scanners and Cameras. Right click the icon associated with your scanner and select properties. You should be able to find driver info there. Verify this information at the manufacturers website as they will most likely have the updated drivers available for download. Also, for the best answers, in the future please include the make and model of your scanner and what operating system you are using.
Aug 01, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
HP L7780 Scanned images are all black
i think your batch's thickness is high. so that when you are keeping your batch on the scanner then your cover will be not covering properly. so that the external light will be passing through the gap between scanner and cover. so that your scanning is showing black. if you want to scan your batch, then you have to cover by plane paper around your batch on the scanner. otherwise you try to protect out side light on the scanner glass. now you can get proper scaning.
regard
priyabrata
Feb 16, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Selected scanner was not found adobe acrobat
first downloaded the trial version of Acrobat 7.0 and removed
Acrobat 6.0. Test scanning ok it will worked!
Proceed to uninstall the Acrobat 7 trial version and
reinstall the 6.0 version you own, try this i hope it will work for you.
All d best
Mar 29, 2008 | Kodak Open Box i50 Flatbed Scanner
HP Photosmart 3310 Printer Logo
69 people viewed this question
Clive
Clive
