Question about Samsung CLP-500N Laser Printer
I keep getting the "waste toner tank full" error, and I ordered a new one
  • 43 Answers
This messages referes to the waste toner being full or not installed.
Manufactures try to stop you from emptying the container by having a small "window" that the printer looks through, when you empty the toner there will still be some toner on this window, so the printer will still believe that it is full.
a way around this is to wash the container out with water (do not use hot water as this will melt the toner). i also wouldn't recommend pouring the water & toner down the sink as this could be breaking local laws.
Posted on Dec 18, 2008
2 Suggested Answers
SOURCE: waste toner tank full/not install keep displaying
The sensor itself weren´t dirty, but plastics in waste toner tank was bit dusty and sensor couldn´t read through it. So I modded waste toner tank a bit with a knife (took the part away which the sensor uses when reading if it is full or not). And works again beautifullu.
All I have to do know is to take care of waste toner tank manually i.e. checking it every now and then and when it becomes full I throw it away.
Posted on Feb 09, 2008
How to clean waste tray
The printer uses an optical sensor to determine when the tank is full. There are clear plastic ports on the side of the tank that the light needs to penetrate in order for the printer to work, otherwise it will generate waste toner tank full error and stop printing.The easiest way to clean the waste toner tank, is to remove it from the printer, and dump the contents into a trashcan. Tap it a few times to get as much as you can. Then take some soap and water and partially fill the tank. Then take the green cap and place it over the tank opening. Shake the soapy water in the tank a few times to clean it. Then dump the soapy, toner water in the sink. Add some tap water into the tank and replace the cap and shake then drain. You don't need to get the tank completely clean, just enough to allow light to past through the clear plastic port. Dry the outside of the tank and and reinstall into the printer. Hope this helps you.
Dec 14, 2010 | Samsung CLP 300 Laser Printer
I keep cleaning the toner/printer waste tank cartridge and the printer continues to stop printing and the same error message displays saying "Replace/Install waste toner printer cartridge.
How are you cleaning the tank? Just dumping the contents into a trashcan may not work. The printer uses a light sensor to detect whether the tank is full. When the light does not shine through the clear window of the tank, the printer thinks that the tank is full. Sometimes cleaning the window with a cotton swab will make it work, but it can be difficult since the location of the window with respect to the opening of the tank is not a straight shot.
Another way to clean it would be dump the waste toner into ther trashcan. Tap the tank a few time to get as much of the toner out. Then add some soap and water into the tank and seal the tank opening with the green lid. Then shake the soapy water in the tank for a about a minute. Then dump the soapy toner/water out. Rinse again with just water and and allow it to dry. You don't have to get the tank completely clean, just enough to stop the waste tank error message.
Hope this helps.
Nov 17, 2010 | Samsung CLX 3160fn All-In-One Printer
Replace waste toner tank
You can get the waste tank at www.precisionroller.com but you can also empty yours in the trash and clean the neck and top real well so the sensor can see thru and not think it's full. You can use a Q-tip to wipe the sensor near the top where the tank goes as toner gets all over that and gives false full errors.
Feb 09, 2010 | Samsung CLP-510 Laser Printer
My Kyocera Mita KM-C380 copier check waster toner tank
Hello sir; the waste toner tank haveto be clean up thoroughly, aspecial the bottle neck .
Mar 30, 2009 | Kyocera Mita Office Equipment & Supplies
Error code: E000019-0000 we're getting this error message and don't know where to find the expired toner location so we can empty it. thanks richard.moran@spectrumfl.com
It,s an error occured when the waste toner is full in the waste toner tank.to remove the waste toner open the left side lower panel cover & remoove the waste toner catredge.
Aug 01, 2008 | Canon (6981A002AA) for imagerunner 2200,...
C-7 980 error code
can you give us the error code?
waitin for your reply.
May 08, 2008 | Kyocera KM-1505 Copier
Waste Toner Error Message For Samsung CLP 550
Dr. P,
Printer will display "Waste Toner Tank Full/Not Installed" error message if the waste tank is full of toner or not installed.
  • Open the waste tank door and check for the waste toner tank.
  • If the tank is full or not intalled, install a new tank.
If you have user guide, it will show you how to install the waste toner tank.
Sometimes you will also get this error message if the Waste Toner sensor is covered with toner powders.
  1. Remove your waste tank and look for the black plastic on the right side after removing the waste tank.
  2. You sould find small openings on each side in the black casing.
  3. Use Q-tips or thin cotton object to clean the inside the small opening.
for user manual just click here:
If this solution works, please don't forget to rate it fixya
For any more question just ask me.
Thanks
Iqbal
Apr 14, 2008 | Samsung CLP-550 Laser Printer
Waste motor error
The wate motor transfers (you guess it) waste toner to the waste toner bottle. If the bottle fills up, the motor cannot transfer more waste to it. This is rare, for the printer should ask for a new waste toner bottle when the previous one fills. However,it happens frequently when users try to empty and clean the bottle instead of replacing it.
If a new waste toner bottle is in place, then the printer needs a new motor, which can only be purchased through an Authorized Service Center.
Oct 24, 2007 | Samsung CLP-510 Laser Printer
Waste toner tank full/not install keep displaying
The sensor for the waste toner tank is dirty or defective. The toner sensor is on the right as you look at the panel just below the liquid crystal display. There is a bump in the clear plastic just below the circular right vent port, that's where the used toner pours in. When you clean out the toner cartridge there is some residue left that makes the sensor think it's still full. Take a piece of paper towel and a small screwdriver (I'm told a bent coat hanger will work, too) and clean the inside of the sensor window inside the used toner cartridge (w/ access through the toner port). It looks like a little raised groove on the right. Just wipe it until it's clear on the inside. The sensor can now see through the window and you should be okay. Otherwise, the sensor may need to be replaced by an authorized Samsung technician. Let me know how it works out!
Jun 16, 2007 | Samsung CLP-500 Laser Printer
Error Message--Waste Toner Tank Full/Not Install
What I have started to do is to actually wash the toner tank out with water and make sure it is good and dry then be sure the section that breaks the light sensor is good and clean (it is on the left side as you look at the backside - the side that goes toward the printer - and protrudes out) the tank full indication comes on when the tank gets dirty
Jan 03, 2007 | Samsung CLP-550N Laser Printer
Samsung CLP-500N Laser Printer Logo
226 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
