Question about HP Officejet Pro L7680 All-In-One Printer
Printing mirror image/print
I adjusted some settings and now for some reason my print is mirrored (I am assuming it is for the transparent sheets for projector). I can't figure out what setting it is.I have a similar print mirroring problem. Normal text printing such as from Word documents or emai is fine. However I get mirroring while printing photographs or when using a network laptop. I wonder if the drivers have gotten corrupted.Any suggestions for a fix?
  • slyfox750 Dec 18, 2008
    The mirror option has been turned off, To repeat, I am experiencing the original problems with the mirror option turned off.
  • HP Master
  • 6,487 Answers
If problem still there I would suggest you uninstall the printer software from your computer and reinstall it back to correct the problem...
Posted on Dec 18, 2008
  • 162 Answers
Quick fix - uninstall driver, disconnect printer, reboot computer, re-install driver and connect printer when directed.
  • HP Master
  • 1,879 Answers
Do this on all computers using the printer:
close all programs first
then go to Printers & Faxes, right click on the printer icon and click Printing Preferences and check options.
since "Normal text printing such as from Word documents or email is fine" check the application you are using for photo's print settings.
  • 837 Answers
Go to control panel and go to printers or printers and faxes. If you see the printer icon right click on the printer icon and select printing preferences. Under printing preferences click on advance and look for mirror image. Click on mirror image and change it to off
  • 199 Answers
Looks like two identical problems on similar all-in-one. since settings can and may be mis-configured on either or both hardware/printer and/or application, best approach would be from a clean/fresh install.
Of course, the original installation should be discarded by deleting the L7680m inside the Printers & Faxes. Thereafter, reboot into Safe Mode and run "regedit". Delete all entries of L7680. Reboot and re-install.
Hope this helps.
  • 57 Answers
I would go and check to see if there is a way to set the settings to default and perhaps try over?
Check to make sure if you have to I would uninstall it and and reinstall the driver might help also.
    Genius:
  • 1,199 Answers
Go into the printers menu and look for settings and turn off the reverse image setting!
I have a HP Officejet Pro L7680 All-in-One It appears to print the text in a reverse mode (just like Koranic Text). What should I do for the text to come out normal (readable)?
The image is mirrored in the printer options. Find the check mark next to "Mirrored" and uncheck it.
On the same tab of the driver you have also "Inverted" option.
Both options are usuable for press release. Mirrored images are printed on transparancy and used for preparing the drums of the typographic machines. The Inverted image is for preparing photopolymer stamps.
Aug 05, 2010 | HP Officejet Pro L7680 All-In-One Printer
PRINTING BACKWARDS
Go to Start>>Control Panel>>>Printers.
Select Printing preferences.
Go to Advance Tab.
Select Mirror images and turn it off or uncheck it.
Press Apply and OK to Apply the settings.
Also perform the same steps on Solution Center.
Open HP Solution Center.
Go to Settings>>Print Settings>>Advance Tab.
Mirror images=OFF
Jun 01, 2010 | HP PSC 2210 All-In-One InkJet Printer
Print mirror image gel printer GX700
The mirror image setting is in the printer properties/ printing preferences. You can either go to control panel/printers/properties, or when you press print, and the window pops up, in printing preferences you can choose the mirror image setting.
Oct 13, 2009 | HP Officejet Pro L7680 All-In-One Printer
I want to print on transparency film; can't find it as an option
Go to the printing preference in your software driver and to the right you should see a "media type" radio button.Look through your choices and you should see a category for tranparencies.
Also make sure the the box under the media type shows auto sheet feeder.
Jun 13, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Printer is printing job as a mirror image
I would have said Gotta be setting in your print dialogue box, but if the test page comes out as mirror image, must be
a setting on printer control somewhere
Apr 21, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
go into the properties setting for the printer, go to advanced tab, then to the prinint defaults button on that tab. When you click on that - if you go to the advanced tab within there, you will see "mirror image" and i bet it says "ON" - click on the word mirror and it opens up the ability to set this back to off. Hope that helps!
Mar 26, 2009 | HP Officejet Pro K5400n - - colour -...
All of a sudden my spread sheet is being printed as a mirror image.
The next time you go to print something, select "Preferences" when the first window opens. On the Advanced tab, under Printer Features look for "Mirror Image". Make sure it is set to "Off". If not click "On" and change the drop down to "Off".
Nov 25, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Go to control panel and go to printers or printers and faxes. If you see the printer icon right click on the printer icon and select printing preferences. Under printing preferences click on advance and look for mirror image. Click on mirror image and chage it to off
Oct 29, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP L7590
I hit print on the pdf file, went to properties and THAT was still set to mirror, so I changed it and everything was o.k.
Sep 25, 2008 | HP Officejet Pro L7590 All-in-One InkJet...
Mirror Image Printing
Need to use editing software ie photoshop etc
Oct 25, 2007 | Lexmark P4350 All-In-One InkJet Printer
HP Officejet Pro L7680 All-In-One Printer Logo
49 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
