Question about Samsung CLX 3160fn All-In-One Printer
I have a samsung CLX 3160 Multifunction Fax. I have had the fax for a while and typically have no problem in receiving a fax. I need to know which one of the ports to put my phone line in that goes to the wall--the EXT or the TEL?
    Brigadier General:
  • 6,966 Answers
Hi again,
For some reason I could no longer view your responses.
Nonetheless, I posted in the Live Session a method of verifying the fax sending capability even in the absence of a receiving fax machine.
Cheers.
Posted on Dec 18, 2008
Failing to receive a fax it says received in memory but not printing even when I want to print. Could you please help
Dear Barati
The printer may have some error. pl. check on the display of the printer. After clearing the error the received fax will printed.
Thanks.
Mar 16, 2015 | Samsung CLX-3305FW Color Laser...
HOW I CAN TAKE PRINT OF RECEIVED FAX WHICH KEPT IN MEMORY
it sounds like it is not feeding paper did you try the bypass to feed paper in to the unit? does it copy?
Aug 11, 2014 | Samsung CLX3305FW - CLX-3305FW Wireless...
We cannot receive or send a fax. If I dial our fax number it rings as a normal phone and not the sound that a fax number makes. The machine is only a few months old.
Not sure how a fax machine is supposed to sound when it rings, before the fax answers it will sound exactly the same on the phone as dialing a regular phone number. If you are using distinct ring tone service where the fax line is supposed to double ring and it is not then it is possible that your phone provider has problems. Are you able to make a regular voice call on the phone line that the fax is supposed to use? If no, then it is definetly the line not the machine.
Apr 18, 2011 | Samsung CLX-3160 All-In-One Laser Printer
Fax wont send or receive? I can here it ringing though wont send???
Try changing the cable from the phone wall outlet to the fax, when a incoming RING signal comes, with a bad phone cable (it is 90 volts AC) so the power to ring the fax can go through but not DATA, try pluging a standard phone in the wall outlet to see if it work's.... if the standard phone don't work than call the phone company's service desk, if the standard phone work's (initiating a call) than concentrate on the printer's trouble shooting guide...
Mar 14, 2011 | Samsung CLX-3160 All-In-One Laser Printer
Reset fax clock
http://www.retrevo.com/support/Samsung-CLX-3160FN-Multifunction-Printers-manual/id/2775ag719/t/2/
Hi please find a copy of your user manual, the information you require is explained in the manual.
http://uploading.com/files/14abb465/Samsung%2BCLX-3160N.zip/
Above is your service and repair manual should you need that too. Copy/paste to the address bar.
Aug 19, 2010 | Samsung CLX-3160 All-In-One Laser Printer
Every time when the phone rings and I answer it the fax kicks in with that really annoying sound. I have to shut down the fax and plug it back in after I am done my call. what is the normal setting for...
The fax is on what you call a Distinctive Ring tone. You need to go in to the settings on the fax machine, and look for Ring type, or Distinctive Ring, And set it to 2 or 3, Dependent on how the phone rings on the fax number.
Nov 25, 2008 | Samsung Office Equipment & Supplies
Faxempfang sowie faxe versenden funktioniert nicht mehr
Can you be more specific? What error code is the fax machine giving you? Do you get a dialtone if you pick up the handset?
What is your fax machine make and model?
Jul 07, 2008 | Samsung CLX-3160 All-In-One Laser Printer
Samsung CLX 3160fn All-In-One Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
