Question about HP Pavillion ZV6000 Notebook
Screen becames little white with horizontal lines
When I open my display screen, It will shows white wahsed screen with horizontal lines and images are displayed in the background. I have to keep moving screen from higes until I can a screen to display images clearly. This happend after I replaced brocken hinges on this computer. Please let me know what is going on?
Thank you.
  • Andrew Hawkins
    Andrew Hawkins Feb 15, 2009
    I have the same problem
My led samsung tv has a horizontal line and the upper right corner shows a white vertical lines
Not good. You may have a tab failure. A repair shop may be able to diagnose and repair this, but most likely the lcd panel is broken. The panel is the most expensive part of flat tv's. A new panel will cost more than a used tv.
Feb 02, 2015 | Samsung Televison & Video
Philips 47PFL5609D/30 White screen displays on 3/4 of screen
It sounds that the connection between t'Con board to panel have some problems; loose contact etc. Check it. Re-seat them once, and check. If you wish to get more details about faults to Philips PFL series flat panel TVs, check this link.
Feb 05, 2013 | Philips 47 in. LCD HDTV
Display jumping vertically
I had same problem.
Narrowed it down to C637 on logic board.
Replace C637 or logic board.
Sep 21, 2009 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Can I see the difference
Visually, there is very little difference to the eye of the average consumer between 720p and 1080. However, 720p can deliver a slightly smoother-looking image, due to the fact that lines and pixels are displayed in a consecutive pattern, rather than in an alternate pattern.your tv is display format is 720p and blu ray is 1080p. what happen is it will be scaled into 720p. old tv set format is 480p 720p represents 1,280 pixels displayed across the screen horizontally and 720 pixels down the screen vertically. This arrangement yields 720 horizontal lines on the screen, which are, in turn, displayed progressively, or each line displayed following another. 1080p, on the other hand, represents 1,080 horizontal lines displayed sequentially. This means all lines are displayed during the same pass. 1080p is the highest quality HD display format. 480p represents 720 pixels displayed across the screen horizontally and 480 pixels down the screen vertically. This arrangement yields 480 horizontal lines on the screen, which are, in turn, displayed progressively, or each line displayed following another.
Apr 05, 2009 | Samsung Televison & Video
2 Problems - Small white horizontal line. Black Lower part of screen
Try changing the TV's display format from widescreen to fullscreen.
Sep 21, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
Remove dry solder at Vertical IC if problem not solves replace VERTICAL IC and pf104
Darshan
Jul 05, 2008 | LG Studioworks 552V 15" CRT Monitor
White horizontal lines on display.
Cameras dont like drop tests! Check if you are getting the same results on the images- printed or viewed on the computer screen. This will prove whether is is a LCD error or CCD error or Processor error But the remedy will be that same New Camera
Sep 06, 2007 | Pentax Optio S60 Digital Camera
HP Pavillion ZV6000 Notebook Logo
190 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
