IT'S GOT ONAND OFF SWITCH. iT'S GOT VOL, SWITCH ON IT. More identifying numbers, Type:OTE3, GNM-OTE3, and 004WWAO564
SOURCE: How do you put a Jabra GNM-OTE3 in discovery mode?
Go to this site, and it will walk you through each step to connect your
particular Jabra headset with your cellphone. Choose the headset, and
then at the next page, choose your phone. Moving your mouse over each
step will change the picture to what you should be seeing on your phone
at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
password is 0000
SOURCE: I have a Jabra GNM-OTE3
I can confirm that the headset works. Suggesting two steps:
1) Confirm that you are holding both the power button AND the answer button for at least 5 seconds. When you release both buttons, the light will go on steady. Does the light go on steady? (If not, you may have a headset problem.)
2) Turn on bluetooth on your phone. Then "search" for the (now with light on) headset. (If the light is off, repeat step 1). The moto should discover the headset, and connect. It may prompt you for a pin...and the default pin code is 0000.
Hope that helps. dw
