Question about Samsung CLX 3160fn All-In-One Printer
I have a Samsung CLX-3150 All in one Printer
I am having trouble receiving faxes so I am wondering if I need to put the telephone line in the TEL or EXT to receive and send faxes?
SOURCE: Problem Faxing sending and receiving faxes
disregard post....i have it, have been working onb it all evening and the fax does not work.
Posted on Aug 09, 2008
Benimur
  • 6966 Answers
SOURCE: I have a samsung CLX
Hi again,
For some reason I could no longer view your responses.
Nonetheless, I posted in the Live Session a method of verifying the fax sending capability even in the absence of a receiving fax machine.
Cheers.
Posted on Dec 18, 2008
  • 526 Answers
SOURCE: Receiving faxes
If you are receiving a fax and you pick up the telephone before the fax machine answers it, the fax will never be able to respond to the fax being received. I assume that is whats happening. If you have a phone connected directly to the fax machine and you pick it up from that phone, the fax machine should transfer to itself after 2 seconds when it recognizes that it is a fax machine.
If you are going to do it from anywhere else, you need to get a fax detector device connect it to the main phone jack, and have the fax machine go to the fax jack of the connector and the other phone in to the other lines, make sure you have enough sockets on the fax detector.
thanks
Posted on May 07, 2009
FixinFax
  • 3085 Answers
SOURCE: couldn't receive my fax
No, make sure you aare plugged into the LINE port. You may be set to maual receive.
press the fax button when its ringing to verify.
Posted on Jun 11, 2009
  • 22 Answers
SOURCE: having trouble connecting samsung clx-3175fn
Make sure you attach a dsl filter to the Samsung. Should look like this: Samsung/filter/phone line. Should be installed like this: filter to Samsung bottom phone jack, phone line to filter. Attach the home phone to the upper extension jack from the Samsung.
Posted on Aug 14, 2009
Can not receive or send fax. There is the phone tone on the BT line.
When we are speaking about faxes you have to try at least a few numbers, because there is sometimes a temporary problems with tel line speed. To send or receive the fax the tel line should be stable. Fax machine try to connect to highest speed (33,6 by default) and if the line is not stable you will receive connection error.
Try again but tomorrow or ask yout telephone company if there is a problem with line
pifonski
Feb 20, 2011 | Samsung SF-5100 Plain Paper Laser Fax
Can't send or receive faxes ADSL
If you want to use the FAX - use the dedicated line to the FAX Machine..
Hi check the following steps
Problems with sending and receiving FAX
Check the TELEPHONE LINE
Make sure that you have plugged the phone cord directly and securely into the wall jack and into the back port of the fax product. The fax port on your product is marked "Line," "To Wall Jack," or with a wall jack symbol.
Check LIU
Make sure the Line Interface Unit (box that the phone cord plugs into) is fully seated into the back of the fax product.
Remove the SPLITTER
Remove any other devices from the line such as splitters, credit card machines, or telephone answering machines.
Can try sending the Fax on Another Line
CHECK WITH DIFFERENT CABLE
Try using a different telephone cord.
Jan 22, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Fax tones heard during tel conversatio
Kindly check your incomming line connected in Line In port of machine . And change your receive mode as TEL/FAX .
Again the same will happen the probelm related to its Line Interface Unit. Change it and check, your problem must be solve.
Jul 19, 2009 | Samsung SCX-4828FN All-In-One Laser...
I have a samsung CLX 3160 Multifunction Fax. I have had the fax for a while and typically have no problem in receiving a fax. I need to know which one of the ports to put my phone line in that goes to the...
Hi again,
Cheers.
Dec 18, 2008 | Samsung CLX 3160fn All-In-One Printer
Having trouble connecting samsung clx-3175fn multi function printer to home phone and dsl to enable me to send and receive faxes
Nov 27, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Sharp fax machine: help!
look to see if it is in tel,fax,or a.m. mode you need to have it in fax mode.tel=telephone,a.m.=ansering machine
May 09, 2008 | Sharp FO 3150 Plain Paper Laser Fax
Set up to receive fax
To select or change your Receive Mode
If it is not illuminated in green, press (Fax).
2 Press Menu/Set, 0, 1.
3 Press ▲ or ▼ to select Fax Only,
Fax/Tel, External TAD or
Manual.
Press Menu/Set.
4 Press Stop/Exit.
Setting the Ring Delay
The Ring Delay sets the number of times the MFC rings before it
answers in Fax Only or Fax/Tel mode. If you have extension
phones on the same line as the MFC or subscribe to the telephone
company’s Distinctive Ring service, keep the Ring Delay setting of 4.
(See Operation from extension telephones on page A-7 and Easy
Receive
on page 4-4.)
1 If it is not illuminated in green, press (Fax).
2 Press Menu/Set, 2, 1, 1.
3 Press ▲ or ▼ to select how many
times the line rings before the MFC
answers (00, 01, 02, 03 or 04).
Press Menu/Set.
(If you select 00, the line won’t ring at all.)
4 Press Stop/Exit.
Initial Setup
1.Receive Mode
Current Receive Mode
Fax : Fax Only
F/T : Fax/Tel
TAD : External TAD
Mnl : Manual
Setup Receive
1.Ring Delay
Apr 02, 2008 | Samsung CLX 3160fn All-In-One Printer
Stop the Samsung CLX 316FN from answering the house chat line
Make sure that the unit is hooked to the fax line only. Many people often merge both lines when connecting answering machines and more than one wireless phone. Also make sure that the unit is the FIRST equipment connected from the wall outlet. Finally, enter the program mode and make sure the fax setting is turned to FAX or TEL. The first setting makes the unit answer after the amount of rings programmed, while the other setting is for manual reception only. One final notice: if you are using the phone line for talking and someone hits START for a copy, the unit will assume a fax and iterrupt the communication. To avoid this, press NO. COPIES first before making copies. Even if it is for one copy only.
Oct 04, 2007 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX 3160fn All-In-One Printer Logo
629 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
