My crosley dvd player only says hello
My dvd player is less than a year old and im getting this error message ''HELLO"". it will not open or close and it will not turn off just read hello.. The input channel line just keeps jumping.
SOURCE: Invalid disc message
I have the same problem. Very frustrading and my solution was to toss it in the trash. Unfortunately these units don't last past 2-3 years.
Posted on Apr 27, 2008
shaggyrat
  • 1224 Answers
SOURCE: hello i need help lol
you gotta open the disk tray and then run the code
Posted on May 28, 2008
  • 70 Answers
SOURCE: DVD Recorder keeps getting stuck at "HELLO"
Try going through the menu, and locate update system, do that then when its finished cancel the auto look for updates.
Posted on Jul 28, 2008
praky16
  • 744 Answers
SOURCE: Toshiba SD-K770 DVD player flashes error and BAD DISC
hi... the problem might be in ur dvd... If ur dvd is perfect and u found that ur player has some problem means the best solution is that to clean up ur dvd player lense which plays a vital role in reading ur dvd when u insert into it...For cleaning up ur lense all u need is a lense cleaner dvd available in electronic shops.. u can purchase it and play that dvd as normal one.. ur problem will get solved..
thank u rate me!!!
Posted on Feb 07, 2009
  • 13 Answers
SOURCE: how to input code
  1. Open the disc tray
  2. Press 1, 3, 7, 9
  3. Press the button for the desired RC (0=codefree)
  4. Close the disc tray
Posted on Apr 15, 2009
JVC DR-MV80B display says hello then shuts itself off.
On electric board you need to change the STR,and work fine.....
Sep 09, 2012 | JVC DR-MV80B DVD Recorder / VCR Combo
Insert DVD, closes, but opens immediately and the screen just says hello. The unit will not shut off unless I unplug it.
If I remember correctly, this unit has a little rubber belt that drives the DVD tray. When it ages, the rubber hardens and loses traction. Thus, the tray does not close properly, the internal sensor recieves no 'closed' message within a specific time, and the tray opens.
Jun 11, 2011 | Zenith XBR716
Dvd not recording
are you using the same brand of DVDs you recorded last year (and the brands that the manual suggest)...and if you are using dvd-rw on the pc and dvd recorder you will also get this message..(just format and record)...
I also find that Imation DVD works (its not listed in my manual) but when Im not using Maxell or Panasonic it works like a charm on both PC / DVD recorder
May 07, 2010 | Sylvania DVL500B Multi-disc DVD Player
Won't play DVDs.
I put in a dvd and get the "disc error" message. This magnavox dvd player is less than a year old.
Jan 05, 2010 | Philips Magnavox DVD/VCR Dual Player
Unit only displays "hello"
This is a faulty condition caused by lack of error control in the firmware. Try this:
Unplug machine from wall for 5 min. Hold "open/close" button in and then plug machine into mains whilst continuing to hold the open/close button. Keep holding open/close button for about a minute, as these machines are notoriouly slow to "boot". It that doesn't work, repeat the procedure, but hold down the power button instead of the open/close button in an attempt to reset the memory settings of the unit. Good luck.
Feb 08, 2009 | RCA DRC8320 DVD Recorder/VCR
DVD HO1 error, and tray is jammed - how do i change the mode to External Port (iPod)?
It means that there's a misaligned disk inside. You need to
1. Unplug it and shake it side-to-side.
2. Then turn it on and press the open/close.
3. If it doesn't open, goto step 1.
4. When it opens, get the disks out, use disk exchange to try to get them all out.
5. Turn it off, unplug it, shake it again and make sure that there isn't another loose disk, if there is, then open it and get it out.
This is a known flaw in certain Panasonic DVD changers. Good luck
-Senrich
Nov 01, 2008 | Panasonic SC-HT740 System
Disc error
when i press play on my dvd/cd player it says error
May 24, 2008 | Zenith DVB412 DVD Player
Jensen MVB85 A8.5 dvd player
Problem: All DVDs would not play in Jensen MVB85A overhead 8.5 DVD player. Error code: "Incorrect Region Code"
FIX:
1. Use the remote to power on DVD player
2. Ensure there are NO DVDs in the drive
3. When you see the DVD logo screen, press 9653 on the remote
4. A hidden menu will open stating the region code. My region code was set to 0 and my I was receiving the error.
5. Press the "OK" button to change the Region Code to "1".
Once the region code was set to 1 all DVDs were playing.
Key words: Jensen Audiovox MVB85 incorrect region code
Nov 13, 2007 | Jensen 8.5'' Overhead DVD Player Package...
Televison & Video Logo
140 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
