Question about Panasonic KX-FP80 Plain Paper Thermal transfer Fax
Fax problem Problems with printing. I've changed the ink roll but still not printing on the right side
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
Left side is printing and right is not printing.first clean thermal head after this check cover locks may bi right side cover lock is broken .just press from right side and make a copy .otherwise replace thermal head .MIAN AKHLAQ
Posted on Dec 29, 2008
Even with new ink cartridge printer prints light
Double click Control Panel.
Double click Printers and Faxes.
Right click your printer and select properties. Now on General tab select "Printing Preferences".
Now select the basics tab and click "Advanced features" found on the right of the page.
Here you will be able to adjust the amount of ink that is used to print a page. Side the bar to the right to increase/darken the print.
Now click OK, followed by Apply.
Take care!
damnor01
Jun 07, 2012 | Office Equipment & Supplies
Fax problems
ok..let's start with this step
go here, get a fresh set of drivers, and remove old s/w, then install the new set
Jun 18, 2008 | HP 1010 Plain Paper Inkjet Fax
When we receive faxes, Only the very right side prints out. WE have a new ink cartridge and drum unit. It did it before we changed it and it is doing the same thing. Is there anything that we can do?
don't know if this will fix prob, but pull drum unit out and locate the piece of glass that runs right to left inside of fax right over top of where drum would be sitting. clean that off. if theres toner coating that glass, that will cause light prints or blanks. this is of course, assuming that you are getting these kind of prints from more that one fax.
hth,
razors
Jun 15, 2011 | Brother IntelliFAX 4750 Plain Paper Laser...
Installing ink cartrage in a royal 435dx cash register
1. Open the printer compartment by lifting the black, plastic printer cover.
2. The ink roll is found in the front of the printer compartment, just behind the print
head, and is mounted in a plastic cartridge.
To remove, grasp the small clip on the left of the ink roll (where the words "PULL UP" may
be printed on the ink roll cartridge) and pull up.
The ink roll will easily pull up and away from the print head.
3. To replace a new ink roll, insert the ink roll according to markings "L" (Left) and "R"
(Right) by pressing downward to lock it into position, then close the printer cover. No tools
are necessary.
For best performance, store unopened ink roll package in a cool, dry place until installed.
NOTE: Replace with ROYAL Ink Roll, Part #013109.
Nov 16, 2010 | Office Equipment & Supplies
Panasonic kx-fp155 not printing
problem is not clear.u change fax roll when it was finished.if fax was printing before ending roll .i think u have installed roll with wrong side .thermal roll only prints with one side which is coated .just see inside machine there will bi a paper for installing roll direction.if not just check thermal head .clean it check its supply.or just replace.it mian jee
Jan 13, 2009 | Panasonic KX-FP155 Plain Paper Thermal...
How do I replace the ink in Panasonic Fax, KX FHD331
First of all make sure why cover is not closing .check its locks.for to change roll just see iside the machine i am sure there will bi a printed paper from manufactrer with picture how to change a roll .it will tell u the direction of roll.by following the picture just change it MIAN AKHLAQ
Dec 18, 2008 | Panasonic KX-FHD331 Plain Paper Thermal...
New ink roll in Philips fax Magic 2
Have just tec support (10p per min robbers !!)
Here is what you do
OPEN MACHINE
WITH THE NEW INK FILM IN, ROLL THE INK FILM ON ROLLER NEAREST TO YOU FORWARD UNTIL ALL THE SILVER STRIPS TO THE RIGHT ARE NO LONGER VISIBLE (THIS IS THE BAR CODE ON THE INK ROLL IT'S SELF)
REMOVE INK FILM FROM MACHINE
CLOSE MACHINE
TYPE IN OK 45 OK 7117 OK (THEN IT WILL ASK IF YOU ARE SURE) YES (CHANGE WITH < > BUTTONS BETWEEN OK BUTTON )
SET TIME AND DATE
OK
OPEN MACHINE
PUT INK FILM BACK IN
CLOSE MACHINE
YOUR DONE LOVERLY JUBBERLY !!!
HOPE THIS HELPS AS IT DROVE ME MAD Rob
Apr 04, 2008 | Philips PPF-531 Plain Paper Thermal...
Light print of incoming faxes, cannot read
are copies light too? if not then it is sending fax, but most times it is inferior ink or drum causing the problem sometimes damp paper (try printing on reverse side as well)
Oct 31, 2007 | Brother IntelliFAX 2600 Fax
Panasonic KX-FP80 Plain Paper Thermal transfer Fax Logo
79 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
