Question about Magellan Roadmate 760 GPS Receiver
Frozen up I can boot up my system but it goes to temperature below safe mode. This has happened in the past 3 or 4 times and it has corrected its self. Now it has been in this mode for a week. I can recycle it by the charger cord but when it boots up, no controls work.
    Problem Solver:
  • 17 Answers
Could be the above...but in my case I just opened up the unit and tightened up the connections from the "hard drive" to the circuit board [these "straps" just push in] they shake loose after many miles and just need to be snugged up every once in a while....IT WORKED FOR ME!!!!
Posted on Jul 07, 2007
    Novelist:
    Scholar:
  • 86 Answers
This problem comes up quite often and normally I'd swap out the PCB Keypad, or the circuit board behind the keypad. This problem never was clearly defined to me so I don't have any ez fixes that wouldn't involve scavenging off of another unit. If you can do this, then take the hard drive and that PCB board that I'm talking about. good luck -Daniel
Posted on Mar 28, 2007
SOURCE:
Why my windows wont boot up past the wallpaper no icons nothin
Could be any number of issues, try booting up in safe mode. If it boots up in safe mode, shut it down by selecting the shut-down option, then try rebooting. If it still does the same go back to safe "mode with networking." Update your anti virus and scan. Then update and scan for malware. Reboot again. If still not going go safe mode again, run fixdisk, if that does not fix it, try system restore to an earlier time and see what happens.if that doesn't work download a program called HDD Regenerator and run it from a CD or USB, it may fix it.
Feb 20, 2015 | Microsoft Windows XP Home Edition
IBM ThinkPad
this can be solved...can you boot to safe mode, through F8?
Mar 07, 2008 | IBM ThinkPad T41 Notebook
When i turn on the computer it goes to the windows loading screen and wont go past that, ive reset it, unplugged it , and it wont go past that screen The computer is a acer E2200 desktop and it runs on...
Have you tried booting into Safe Mode? You can do this by pressing/tapping the 'F8' key after the bios screen (Acer Screen) comes up. If it does you boot correctly then, you can try to restore the system to an earlier date using System Restore. That's located in the start menu/windows orb at All Programs->Accessories->System Tools->System Restore
Feb 28, 2011 | Acer Aspire M3641 Dual Core E2200 PC...
I have s dell inspiron 6000 that is stuck in safe mode
This happens when set you PC on Safeboot Option.
Follow the steps mentioned below to boot in normal mode.
1: Once you are in the Safe Mode, Click on Start and then Click on Run.
2: Type msconfig (you will see system configuration utility).
3: Click on Boot.ini tab and check for the Boot Options.
4: You will see Safe boot options check.
5: Uncheck it then click on apply and then then ok.
6: Now your computer will boot in Normal mode.
Once you reach the desktop you will again see the system configuration utility screen. Just check the option don
Dec 16, 2010 | Computers & Internet
I set the normal mode to safe mode,but i dont know how to change back now
Once you reach the desktop you will again see the system configuration utility screen. Just check the option don't show this message again. You are all set.
Dec 15, 2010 | Computers & Internet
I cant' get out of safe mode. I press f8 and tell it to start windows normally but it goes to safe mode automatically
5: Uncheck it then click on apply and then ok.
Dec 11, 2010 | ASUS 90-A4C1K1000 Keyboard
After booting up samsung NC10 error message saying windows could not start because following file missing/corrupt \windows\system\vgaoem.fon
OK, try, Boot Up in SAFE MODE, press F8 At Boot up, quickly, select, Boot to safe Mode desktop, with networking... simply copy vgaoem.fon file from xp disc or from net, paste file into windows system folder, done.
OR You could simply perform a system restore back to another time BEFORE you had a problem, again start up in Safe mode, F8. but this time when the choice is given to choose safe mode desktop or system restore, choose system restore, when a calendar like thing is displayed choose a time PRIOR to this problem happening, follow instructions and before you know it your PC will be back.
Oct 15, 2010 | Samsung Computers & Internet
Screen goes blank at start up
Its failing to go through the full boot process. Try pressing F8 on boot until the boot option screen comes up and then select safe mode. Follow this though until you are given the option of using system restore instead of safe mode. take that option by clicking on the NO button. Restore the machine to a date some time a few days previous to the fault developing.
If that fails then put in any OS disc and boot from it. select R at the first options screen, follow it through and then select the C drive option. Just hit enter when asked for admin password.
now type chkdsk /r (copy and paste this to be sure). let it run and then reboot and see what happens
Dec 15, 2008 | Dell Latitude D600 Notebook
My hp lap top keeps going into option safe mode then shows me the first screen windows xp then goes back to option safe mode and other options
It is possible that your system boot was setup to safe mode everytime it boots up. You may try the steps below.
1. Boot your system to safe mode.
2. Go to Start then Run
3. On the run box type msconfig
4. Look for the tab boot.ini , under this tab uncheck the box that says safeboot then click apply
5. Restart the computer.
Keep me posted.
Thanks.
Nov 20, 2008 | HP Computers & Internet
System passes the logon screen
Keep tapping the F8 key while you boot your machine, hopefully you will get a black screen with some white writting on it.
Using the up and down arrows select Boot Safe Mode without Networking.
Once you boot into safe mode go to programs>accessories>system tools>system restore and follow the wizard to restore your machine back to a time and date before you installed the modem software.
Aug 30, 2008 | E-Machines eMachines Desktop PC
Magellan Roadmate 760 GPS Receiver Logo
48 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Damen Wong
Damen Wong
Are you a Magellan GPS Expert? Answer questions, earn points and help others
