Question about Lexmark X3470 All-In-One InkJet Printer
Carrier jam When you turn on the printer it says there is a carrier jam. When I open it I don't see anything in there. Also when it turns on the ink cartage slams back and forth. How can I fix this?
    Sergeant:
  • 320 Answers
  1. Disconnect the power supply from the back of the printer.
  2. Open the front cover of the printer where the cartridges are located.
  3. Look for two black bands that span from left to right (they should have one serrated side and one smooth side). Just above the black bands there is a transparent strip; this strip is called the Encoder strip.
  4. Flick this strip lightly with your finger to make sure that it is running smoothly from left to right. You may need to do this two or three times. CAUTION: Do not pull the strip!
  5. Close the front cover of the printer and reconnect the power supply.
Good luck....
Posted on Jan 22, 2009
My printer will not print, keeps displaying ( clear carrier jam! ). How can I fix it?? Do I need to buy a new printer or is this an easy fix. I 've unplugged the printer and checked ink cartridges...
Turn the printer off and unplug it from the wall. Press and hold the power button for sixty seconds. Open the top of the printer to make the ink cartridge carrier accessible. Grab the ink cartridge carrier with your hand and slowly move it back and forth until it moves freely. Then plug the printer back in and turn it on. That should solve your issue.
Sep 25, 2011 | Dell V305 All-In-One InkJet Printer
Pen gartridge jam
Is it an ink cartridge jam
Please follow steps below : STEP: Disconnect and Reconnect the Printer Power Supply
Unplug the power cord from the wall socket. Disconnect the power supply from the back of the printer.
Wait 15 seconds.
Reconnect the power supply to the back of the printer.
Plug the power cord back into the wall socket
STEP: Raise and Lower the Scanner Assembly on the Printer
Lift the lid of the scanner until the locking bar catches to move the ink cartridge carrier to the center position.
Release the locking bar and close the scanner assembly.
If the ink cartridge carrier fails to center, repeat steps 1 and 2
Scanner Assembly Open but Without the Cartridge Carrier Centering
STEP: Check to See if the Ink Carrier Latches Are Open
Open the printer.
Check inside the printer to see if the cartridge carrier latches that hold the ink cartridges down have popped open.
Close the carrier latches
STEP: Remove any Torn or Stuck Pieces of Paper from the Input Tray and Output Tray
Disconnect the power brick from the back of the printer.
Lift the scanner unit.
Look down inside the printer and remove any torn or stuck paper from the input or output tray by pulling firmly.
Close the scanner unit.
Reconnect the power brick to the back of the printer
STEP: Clear Obstructions From the Input Tray
STEP: Fan the Paper
Grasp the **** of paper at one end (Figure 1).
Place your thumb on top of the opposite end of the paper and fan the paper like a deck of cards.
Flex the paper back and forth, and then fan it.
Straighten the edges of the stack on a level surface.
Top of Form 1
Bottom of Form 1
Additional Information
It is quite possible for objects such as pens, pencils, paperclips, and other small items to fall into the paper input tray causing paper jams to occur. Follow the below steps to try and clear any obstructions that may have fallen into the printer.
Caution:
The next steps involve lifting the printer and turning it upside down. Only perform these steps if you are willing and able to do so.
Remove all paper from the input tray.
Unplug the power brick from the back of the printer.
Unplug the USB cable from the back of the printer.
Lift the printer up and turn it upside down.
Caution:
Make sure that you are holding onto the scan bed to prevent it from falling open when the printer is turned upside down.
Tilt the printer from side to side while it is upside down to see if any obstructions fall from the input tray.
Jul 19, 2010 | HP OfficeJet t65 All-In-One InkJet Printer
The carrier tray does not move when I open the top
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 25, 2010 | Dell V305w All-In-One R840635AU InkJet...
Ink Cartage CYAN for Brother Printer Model MFG 440 CN replaced
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Dec 07, 2008 | Brother MultiFunction Center MFC-440CN...
Carrier jam on printer
There could be 4 possibilities.
1. Ink cartridges lids are open which is not allowing cartridges to move freely.
2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
3. Encoder strip is Dirty.
4. Encoder strip is Out of position.
Solution:
1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
4. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Oct 28, 2008 | Dell 924 All-in-One InkJet Printer
Dell phto 924 clear the carrier jam
Solution:
Oct 10, 2008 | Dell 924 All-in-One InkJet Printer
Print cartages won't move when I open to change.
You can manually move a printhead( the one that holds the cartridges) to the center. Open the door at the back, turn the wheels clockwise, and while turning, manually move the printhead to the center..
Apr 14, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Dell 942 carrier jam
This morning I replaced the cartridges in the Dell 942 printer, they jammed to the left which made a loud grinding noise and the cartridge jam error came on.
I solved the problem by turning the printer on with the top up which moved the cartridges to the right a little so I could reach back, push one down a little manually which freed them to move over to the middle.
Feb 28, 2008 | Dell 942 All-In-One InkJet Printer
Ink cartridge jam
ink cartridge jam
Wait 15 seconds.
Open the printer.
STEP: Fan the Paper
Grasp the ream of paper at one end (Figure 1).
Top of Form 1
Bottom of Form 1
Caution:
Caution:
Feb 02, 2008 | Dell 810 All-In-One InkJet Printer
Lexmark X3470 All-In-One InkJet Printer Logo
78 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
