Question about Toshiba Satellite A75-S226 Notebook
Hi, I have Toshiba Satellite P35-S611. I am having some power problems. It has 3 lights 1 which shows plug, 2 power, 3 bettery. The plug and power light always stays green. The bettery light when it is charging is orange ones the bettery is charged it turns to green and it stays like this for a while (10-max15min) and it shuts off so my laptop starts working on bettery power. Then when it dies it shuts off computer. I have to pull out bettery, put it back and then charging light comes on and I can turn on my laptop again. So, then it does the same procedure all the time. If you have a solution for this I would really appresiate your help. Thanks, Andrey
  • thenewjlo Mar 23, 2009
    It is the motherboard. When the right light is orange the battery is charging, grean means it is plugged in but not charging. When the light turns off that means there is no connection. You can fix the problem by jiggling the powercord till the light comes on and then holding it there for a while, but eventually there is no connection at all. I got it fixed two years ago and they did it for free because of a class action law suit, but I do not know if these are still on warrantee. When I did bring it in the motherboard was on backorder for two months because there were so many that had the same problem.
How do I start over with my computer toshiba p35 s611 do I have a restore on this model or do I need to format HD and reload XP? I dont have any restore disks.
if you go to "computer" and there is a partition or hard drive showing as "recovery" then you should be able to take your lappy back to its original state.
if not then you will need to format, depending on how old your system is anyway, a format might do some good.
Jan 02, 2010 | Toshiba Satellite P35-S611 Notebook
Toshiba satellite p35-2611 2 inch(1
the worse thing it could be is the lcd going out in a very bad way. Yes likely to get wrose over time, No not the video card because it happends on every screen, boot,preboot,and windows so guess what? If you have the lcd replaced you will be looking at a good laptop once again. Price aroung $75-100 bucks where? Ebay of all sources. Thanks I hope this was Very Helpful to you if so lay ing your ratings.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Dec 13, 2009 | Toshiba Satellite P35-S611 Notebook
Toshiba Satellite P35-S611, power up failure.
Open the processor area located under your laptop. You can detached and re attached the processor, some sort of lose contact on pins. If same problem occur, your processor may burnt out. pm me caligayanstep@yahoo.com i will assist you remotely.
Oct 21, 2009 | Toshiba Satellite P35-S611 Notebook
Satellite P35-S611 has trouble charging
If you have to wiggle the power cord it is most likely the DC jack on the motherboard. It is usually the center pin in the the jack that breaks the solder point and the small tension band inside the jack housing weakens.
Sep 26, 2009 | Toshiba Satellite P35-S611 Notebook
Slow Hard drive
That model is only IDE capable and has no SATA ports on the motherboard. You should get a faster IDE harddrive OR an external USB harddrive .
May 08, 2009 | Toshiba Satellite P35-S611 Notebook
Lines on screen
usually when you have lines on your screen then you have to buy a new one
Apr 22, 2009 | Toshiba Satellite P35-S611 Notebook
Black screen only.
1. Windows reinstall thru CD ( crashed graphic drivers )
2. screen itself faulty
Jun 07, 2008 | Toshiba Satellite P35-S611 Notebook
My Satellite P35-S611 will not run on ac power nor will it charge the battery
this happened to me also after window update ..i think it was updating with sp3
Feb 02, 2008 | Toshiba Satellite P35-S611 Notebook
My satellite P35-S611 will not run on AC power nor will it charge the battery
I have just fixed the same problem on my Toshiba p35 s611.
The power jack inside the laptop had been damaged. To reach the problem you must take apart the entire laptop (there are a few guides for doing this online). Next I simply found the positive connection coming from the jack (it is the wire coming out of the back of the jack) and followed it to where it enters the motherboard. I simply flipped it around and re-soldered that one spot. Other sites recommended I remove the jack but I couldn't melt the solder enough to do so, however just trying and adding some fresh solder was enough to fix the problem. I no longer need to jiggle the power connector to the right angle just to get power.
Toshiba Satellite A75-S226 Notebook Logo
214 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
