Question about Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW)
Too cold - is there a control somewhere? janie
    Guru:
  • 449 Answers
When a non-electronically controlled domestic frost free refrigerator is too cold, it's one of three things. Either the controls are set wrong, the cold control is insensitive, or in rare cases and only on certain designs, if the compressor is weak. In this case the evaporator temperature is not cold enough to operate the control properly. Also, on manual defrost or semi automatic defrost designs, sometimes it can just be that the clip that holds the controls sensing tube is loose or has come off. good luck
Posted on Dec 19, 2008
Kelvinator opal upright freezer is over freezing..is there a temperature control somewhere or what could be the problem?
the problem could be the heater element, bimetal, thermostat, fuse.must open freezer cover and check.
Nov 14, 2016 | Kelvinator Freezers
Help with Light for Fridge RS265TD RS
Most refrigerators have a switch somewhere. look for a little white triangle either at the top or bottom. there may be a push button style somewhere along the upper hinge cover.
Nov 05, 2013 | Samsung RS265TD 26 cu. ft. Side by Side...
I have a Kenmore Elite 51374. The refrigerator is not getting cold enough but freezer is too cold. Technician said that it was an electrical problem to call a electrician that I needed a new outlet. I...
That is the dumbest answer I've ever heard from a technician.
The cold control on most boxes controls the freezer temperature. You want the freezer temp to be around zero degrees.
Somewhere (usually in the refrigerator section) there's another control that actually sets a damper, letting some cold air from the freezer into the refrigerator. Higher numbers equal lower temperature. Find that second control knob and turn it up by 1 or 2 numbers, let an hour or so pass and check your refrigerator temp. You want about 40 degrees in the fridge.
Aug 02, 2017 | Kenmore 23.3 cu. ft. Side-by-Side...
Botttom will not cool but top cools
Do you see frost built up on back wall of freezer if so it is not defrosting and this is what needs to be checked, remove back wall of freezer and check these;
Defrost heater-- it usually is at bottom of the evap. coil, to check it remove wires to it ,use a meter set to the lowest ohms setting and check for somewhere between 10-50 ohms if that is what yours is its good if meter reads OL replace defrost heater
Defrost thermostat-- if clips to the top of the evap. coil and is metallic,round , about the diameter of a quarter with a plastic side with 2 wires coming from it(do not confuse it w.thermister),remove wires and check for ZERO ohms WHEN TESTING IT MUST BE COLD so check it when frost is built up,IF meter reading is OL (WHEN COLD) its the problem
Defrost timer or defrost control if has digital display to show tempature
check timer(it could be anywhere except in freezer) by turning till you hear a click,the defrost heater should come on within 5 minutes if the heater does come on the timer is the problem and needs to be replaced,if the heater does not come on the above mentions parts (heater/t-stat) will be the problem.
defrost control is hard for unskilled lay persons to check SO IF heater and defrost t-stat are good replace control
Hope this helps,
Gene
Aug 03, 2011 | Frigidaire Freezer GLRT183TD
Kenmore freezer deforsted suddenly. Comes on
compressor relay is probably going out...also check the plug in to the wall. A intermittant contact is a matter of following the source to the compressor. start at the plug and through the temp sensor/ t-stat defrost control and down to the compressor. but ususlly the compressor relay is the culprit.
Oct 25, 2009 | Freezers
Fridge walls very warm around freezer door, fridgidaire
you may have a restriction somewhere, but i would definitely try to clean your coils, it is probably full of lint
Sep 26, 2009 | Frigidaire 20.3 cu. ft. / 575 liter...
Kenmore upright freezer no digtal light no motor running
if it is an electronic control freezer then the electronic control sounds as though it has failed if there is no digital read out
May 02, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frost free freezer leaking water everyday. the door and seals are fine. only 3 years old. ice appears in lower compartment.
When the freezer defrosts the water has to go somewhere. The defrost drain is stopped up. Blow it out.
Jan 26, 2009 | Freezers
Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW) Logo
163 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
