Question about Philips 60P8341 60" Rear Projection Television
Red convergence problem
I have a 60PP9202 65" Phillips Rear projection tv. I was told it was the two convergence chips that need replacement and it will cost about $350.00. Does it sound right and is it easy to repair and is it something that I can do myself. I tried the convergence and the blue is ok but the red is not adjustable. Will I need to change both so called chips or just the red? Was working find then instantly the letters had double exposure (above the other one) I took some didgital pictures if you want me to send them to you I can. Is that model worth puting that much money into it or should I look for another one? I apreciate your help.
    Sergeant:
  • 233 Answers
I believe your set uses STK392-120's You can change them if you have any electrical background. You will need to be able to solder to do this. You will also need to check the larger resistors around the stk's to see if they are burned, or out of spec... You will need a meter to check them, and you should pull one leg out of circuit to measure the resistance. If all the resistors are good, and you replace the convergence IC's, you should be able to re-adjust your convergence and have a great picture again... IF you CANT do these repairs yourself, 350.00 is a common price.
Posted on Dec 18, 2008
Yes my 60 in phillips rear projection tv model # 60p8341a the screen is a reddish orange color and wanted to know how to fix it
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Dec 19, 2010 | Philips 60P8341 60" Rear Projection...
I have a phillips 60 in rear projection tv model #60PP9401. and it is exhibiting the appearance of double vision, can this be fixed economically
Projection TV sets have two very common problems oulined below.
  • Screen looks 3D
  • No Audio/Video - TV Makes Chirping Sound
Dec 18, 2010 | Philips 60PP9401 60" Rear Projection...
I have a 55 inch phillips tv that is showing a red line and also a double figure. the red line is along the outline of persons, numbers, etc. etc.
Your TV most likely has a convergence failure. ( common problem )
  • Screen looks 3D
Here are some photos of convergence problems.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 15, 2009 | Philips 55P8341 55" Rear Projection...
Your TV most likely has one or more possible problems.
  • Screen looks 3D
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 07, 2009 | Philips 51PW9303 51" Rear Projection...
Convergence
  • Screen looks 3D
Feb 11, 2009 | Philips Magnavox 9P6034C 60" Rear...
Red "aura" in the middle of my 55" Phillips Magnavox
  • Screen looks 3D
Feb 01, 2009 | Philips Magnavox 9P6034C 60" Rear...
Can not line up red convergence
The convergence chips are toast. This is a common problem. Goto the site www.TvRepairKits.com to get a repair kit with instructions.
Dec 22, 2008 | Philips 60PP9202 60" Rear Projection...
Phillips model 51pw9363 Convergence Problem
lets see.
you have an up grade for this unit.
replace original ICs with STK 392-120
if you can soldier and clean heat sink of and replace heat sink you can replace thes parts no problem.
serch for them on line cost is from 14$ to 30 each.
hope this helps you
and please give me a godd rating for this advice.
i pay $160 a month for my info and this sigt pays nothing.
thanks.
daniel.
Nov 30, 2008 | Philips 51PW9363 51" Rear Projection...
Converge colors?
If the colors look 3D or if you can't adjust the blue or red convergence the convergence chips and resistors should be replaced. You can get a repair kit and photo instuction guide for this exact model from www.TvRepairKits.com. Hope this helps
Nov 15, 2008 | Philips 9P5034C 50" Rear Projection...
Philips 60P8341 60" Rear Projection Television Logo
64 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
