Question about Cobra 29 LTD CB Radio
No receive cobra 29 ltd classic
Radio transmits and has modulation. the IC # 4 is blown. It has a short on # 1 pin .Which components feed power to the # 1 pin?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls confirm that there is modulation (transmit audio). The reason I asked is if IC4 (TA7222P) is blown, then the radio would have no audio amplifier which would explain no receive audio. Additionally, the final and pre-final (TR15 & 15) gets is modulated TX+12 through D8 from T1 which in turn is the output of IC4 through C48.
Perhaps a schematic diagram may be of further help.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 18, 2008
Lx29 blue tut. Locked in 9/10 mode. How do I reset it?
PDF]EIi?tr,iitts - American Radio History
www.americanradiohistory.com/Archive-Radio.../90s/.../EN-1993-11.pdf
Nov 5, 1993 - 64 AUTOPATCH SELECTOR FOR RADIO AMATEURS ..... Memorymodes can store readings while ..... est way to do it is to base the circuit .... width (with increasing values of CB), .... Electronics Engineers' Book Club, Blue Ridge Summit, PA 17294- ...... lock onto the 19 -kHz pilot sub- ...... manually reset.using fgets to read one line at a time - Experts Exchange www.experts-exchange.com > Questions
Nov 11, 2008 - 1: 2: 3: 4: 5: 6: 7: 8: 9: 10: 11: 12: 13: 14: 15: 16: 17: 18: 19: 20: 21: 22: 23: ..... helium viceroy Audrey Isaac provision grammar cobra adrift died Liverpool .....wriggle do carbuncle firebug Elsinore Connally annotate anaconda could ..... pretend quadratic Euphrates RCA amuse CB
Cobra 29 LTD Classic CB Radio - YouTube? 5:42https://www.youtube.com/watch?v=vJle8vlsWLcAug 20, 2013 - Uploaded by C B WorldIn this product review we look at the Cobra 29 LTD Classic CB radio and ... Just like in the manual. most channels are below 3. a few are not.Cobra 29 LTD Classic Troubleshooting - iFixithttps://www.ifixit.com/.../Cobra_29_LTD_Classic_TroubleshootingiFixitCobra 29 LTD Classic is not transmitting or receiving. The Antenna is not tuned correctly; The Radio is not in CB mode; The Radio is on the wrong channel; The ...Marine Radios ' Cobra Electronics Corporation
Jan 07, 2016 | Cobra Radio Communications
I can recieve but i cant transmit have new antenna and new mic
Check that your mic gain or dynamike knob is turn clockwise if it is full counter clockwise you will have no modulation with your tx power.
I would like to help but one sentence describing your problem can lead to a vague solution.
Be aware that not all 4 pin mikes are wired the same.
Stock
1- Shield
2- Audio
3- Transmit
4- Receive
Aug 28, 2011 | Cobra 29 LTD CB Radio
I have a bare wire (shield),white,red,and blue from mic. What is the correct pin configuration for a cobra 29 night watch
  • Pin 1 = Shield = Shield
  • Pin 2 = White = Audio
  • Pin 3 = Red = Transmit
  • Pin 4 = Blue = Receive
Regards, Tony
May 05, 2011 | Cobra 29 LTD CB Radio
Radio 29 ltd no modulation, no receive and good carrier, no capacitor shorted or blowm,changed ic audio by a new one and get still the same problem
did you change IC4=TA7222AP ?
check input ic4 pin1 is it supply voltage?=12vdc.
check C48 couple cap,also check C39 replace
with a 25 watt and C42 also C45.
check R130 1.1 ohm. also R121 180 ohm.
if pin 1 on ic4 is low volt or missing,check TR23
and D22,C119
maybe this will help some
Sep 28, 2009 | Cobra 29 LTD CB Radio
I have a cobra 29 ltd cb radio> when i click the mic i dont get transmission> do i need to tune my antenna or do i have a problem with the mic or radio?
It's the mic or radio like you said try this
unplug the mic the RX (receive) will stop
working there are 4 pins take a small screwdriver short one pin at a time to the
side of the plug an watch the meter if you
find one that makes the meter jump over
then your mic is bad.last if that don't work
then short 2 pins together and not to the side
of the plug. there is nothing that will hurt you
or the radio.hope this helps.I have worked
with radios and outher electronics for over
22 years. Good Luck
Sep 08, 2009 | Cobra 29 LTD CB Radio
When i click the mic i get no transmit
If the receive works ok,sounds like a mic
problem,try another mic if you can find a
buddy who has a Cobra that may let you
try it most all Cobra mic will work but not all.
Good Luck
Have Cobra 29 LTD CB Radio w/ bluetooth. Power comes on. Does not receive or transmit. What's wrong?
Sounds like the PLL circuit....... no channel synthesizer will kill the transmit and receive...... bad crystal or IC could be at fault or if someone has attempted to add more channels could also be cause.
Dec 20, 2008 | Cobra 29 LTD CB Radio
Cobra 29 LTD Classic not transmitting or receiving
ant. light should only come on if you have a high vswr a bad thing did you check that cb/pa switch is set to cb check your swr this is not a good place to mount ant. as it is close to metal of back of cab
As I understand from a tech friend of mine, most truck beds are not grounded well enough. Perhaps you could borrow/purchase a magnet mount antenna and locate it on the roof, for testing. Then you would have it narrowed down to the location.
Dec 05, 2008 | Cobra 29 LTD CB Radio
My Cobra 29 ltd classic
Hello MyPete,
You have some form of short circuit in your CB, most likley I would suspect the Power supply or the RF Power Output Amplifier. Here are some basic instruction on how to tell wher the smoke is coming from.
1) disconnect and remove your CB from your vehicle and put it on a workbench
2) remove the cover from your CB and expose the circuit board to view
3) connect your CB to an external 12 volt power source and antenna or a dummy load
4) power up the CB and determine where the smoke is coming from then turn off the power supply to the CB
5) At this point you will need a schematic of your CB (get one from www.servicemanuals.com)
6) find the point on the schematic that relates to the point where the smoke is coming from
7) using a ohmmeter determine which component and or components are shorted
8) replace the shorted and or malfunctioning components.
9) test the system (power on, transmit and receive)
10) close the unit back up
11) reinstall into vehicle
12) run tests again.
This should help
Thank you
Shutle832
Nov 01, 2008 | Cobra 29 LTD CB Radio
Cobra 29 LTD CB Radio Logo
674 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
