Question about Refrigerators
The line on the back of the fridge thats on the top and goes to the bottom got broke how can i fix it
  • Refrigerators Master
  • 8,220 Answers
All you need is a quarter inch plastic compression union. Get one at the hardware store. Just slide the provided compression nuts on each line make sure you have a good square cut on each hose end, push both ends up into the union and snug up the compression nuts. Do not over tighten! or I'll spank ya. :D
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 18, 2008
Need to know which wire attaches to the top and which one goes on the bottom. rear passanager brake abs attachment has broken off and need to temp fix.
An ohm meter may help or hold the broken pieces together, exactly as it broke, the two pieces should line up to original position and give you an idea.
Hope either helps!
Apr 15, 2015 | 2000 Cadillac DeVille
I can't put the door back on. The top has fixed bolt (and a corresponding hole t the top of the door. But no idea how to attach the bottom. no fixed bolt on the fridge at the bottom, (but there is
There should be a piece usually triangular that bolts to the bottom of the fridge with a post sticking out of the end of it. The door rests on the pin then you attach the top mounting bracket and the door should be on
Sep 06, 2012 | Sanyo SR-3770S Compact Refrigerator
Fridge is leaking water .... there's a place in the back of the fridge at the bottom (where the water line comes in from the in fridge filter and then goes to the icemaker).... there's two electrical...
yes these are the water valve solenoids and 1 is fir ice maker and the other is for cold water supply in the door,yes just replace it dont even try to fix it
Jan 01, 2011 | Jenn-Air JBL2086HES Bottom Freezer...
Water and ice dispenser not working
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | Refrigerators
Icemaker not making ice
Jun 06, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Will not dispense ice or water, beeps when lever is pushed, no interior light in frig part. both frig and freezer work, freezer light works
Jun 06, 2010 | Maytag MFI2569VE Bottom Freezer French...
No water going to ice maker
Jun 06, 2010 | Whirlpool GC5SHEXNS Side by Side...
Water in bottom of fridge
Thanks to all who spent money or shared their experience to have somebody do this repair, and I really mean it.
I have a Whirlpool TopLoad Fridge (not a side by side).
Things you'll need
30 minutes
Small socket for cardboard panel on lower back and panel inside freezer
Bicycle Pump
4 Towels
Hair Dryer
1. Take everything out of freezer
2. Turn dials off in fridge for both compartments
3. Pull fridge out so you can get behind it and unplug it
4. Be vigilant of ice maker line if installed
5. Pull cardboard panel off on back
On the left side you should see the back of the skinny drip pan and a small line. That line goes from the freezer and is most likely clogged.
6. Blow dry the back of the freezer enough so the ice is thawed at the bottom of the back panel.
7. Remove the two screws on the back panel. You may just be able to pull it toward you enough to get behind it. You'll see the coils and fan, and underneath these you may see some ice sheets and there should be a hole. That is the drain line that is clogged. I heated up some water and poured it over the drain to thaw the line. You may want to remove the crisper drawers and put some towels down there to catch the overflow. Once the ice is thawed enough at the drain. Go to the back of the fridge and place the end of the bicycle pump at the bottom of the drain hose. Apply pressure to get a good seal but keep pumping. You may have to go back and forth between pumping and thawing, but you'll know it is clear when you hear air going into the freezer and then the wonderful moment when water drips into the drip pan as advertised!
Keep those fridges less full so that the door stays sealed and keep the seal clean and also keep your doors from having too much stuff so the weight of the door doesn't pull away.
Okay, put it back together, turn everything on and be careful of your cord and lines when pushing the fridge back. Thank the Lord ours has wheels and man,was it cruddy underneath. Vacuum those coils underneath the fridge too for proper air circulation.
Blessings to you!
tay
Sep 15, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Water line broken for Kenmore refrigerator near compressor
Cut off a piece of line and go to a good hardware store, they can show you how to fix it. Need a coupling, and a nut and ferrel. House water line goes on one end of coupling, nut and ferrel on the broken water line on fridge. A good hardware store will be able to show you how to fix.
Jul 26, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
No water from dispenser
I could not locate any white tank where the water comes to/from. There is only a clear plastic water line behind the crisper drawers, that is coiled up and goes up to the water filter at the top on one end, and down through the bottom of the fridge on the other. The coiled line seemed like perhaps it was frozen, so I took a hair dryer to that but it didn't help. I also tried removing the cardboard cover in the bottom back of the fridge, to see if perhaps the white tank was back there, but it was only
more line, which goes towards the front of the fridge, where it goes up into the corner of the door.
Jan 05, 2008 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
53 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
