Question about Black & Decker PI400AB Power Inverter
Cant find the fuse on a black and decker 400 watt power inverter
  • Anonymous Feb 08, 2009
    I have the same problem with my produce. upon disassembling the unit I discovered that two replaceable fuses are held inside. Unfortunately these 'replaceable' fuses are sautered to the main board. . . . . That was smart. . .
  • Anonymous Feb 20, 2009
    need to find the fuse
I've had this inverter for about two years now, bought it for a cross country road trip to power my laptop and a couple of other things. I've pretty much liked it. Yes, the fan is a little noisey, yes, you have to use the provided battery clips for heavy loads. But it powers my Dell Inspiron 8500 laptop just fine (and its an old powerhog).
Recently a I let a friend use it with his inflatable mattress air pump during a camping trip.
What I didn't know is his pump has insane wattage, and it fried/bricked the inverter instantly.
Agh! I thought it was a goner, but took the time to look inside the unit. (Which is a solid and sturdy metal case, not plastic as another reviewer indicated). I was thrilled to discover there were some internal fuses. And while the fuses are soldered to the circuit board, if you've done any soldering at all they really are a snap to replace.
If you remove the four screws that hold the end cover plate on the side with the fan. You can remove the end plate and have just about a half inch or so of clearance. The entire lower circuit board will then slide out with firm pressure about an inch and a half (don't try and go any further, components on the other side prevent it).
On the right side (positive/red terminal side), you will see two 25 amp mini-fuses that are directly soldered to the circuit board. If these are blown (you can see through the semi-transparent sides if they still connect), that is most likely your problem. They are easily available from most auto and big department stores (Walmart, Target, etc) in their automotive sections.
I used a 40 watt soldering iron (30 watt should work fine), and applied it to the bottom of the circuit board where the fuse legs poke out the bottom. Using a pair of pliers, I applied a firm steady pressure to the fuse, pulling up, while applying the soldering iron to each of the legs (alternately) of the fuse. The solder melted, and I was able to work the fuse out in a few seconds. I did this for both fuses.
The replacement fuses cost all of $2. I dipped the new fuse legs in flux, then put them in the place of the old fuses. Again I heated the circuit board solder from below, and pushed the new fuse in place. Repeat with the second fuse until it is in place. Flip the board over and add some more new solder until it is firmly in place. Put it back together, and you are back in business! And for a whole lot less than a new inverter.
I've got pics of this process if anyone would like them. Good luck, and happy inverting.
Posted on Sep 21, 2010
  • 1 more comment
  • Ian Persad
    Ian Persad Apr 22, 2011
    I would really like to see those pics, can't figure what on the board is the fuse for sure.
  • tmorosco Apr 22, 2011
    Here you go:
    http://waltony.homeip.net/Photos/2010/09...
    In picture 4065, you can see the white fuses (already replaced) in relation to the rest of the unit, and the blown fuse off to the side has been removed.
  • tmorosco Jun 20, 2014
    Sorry, had to take the server offline (a few months ago?), but will repost this when I am able to.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 31 Answers
I Have the Type 2 Model of this and you cant get to the fuzes without taking off the end plate with the receptacles. I cut my end plate across just at the top of where the AC receptacles slide into the plate. This way I didnt have to unsolder, resolder the AC receptacles. You will need de-soldering braid to remove the solder from the fuses. Pretty dumb design, having fuses soldered and inaccessible. If I blow mine again, Ill definitely install fuze plugs. Anyway thanks for the info. Got me going in the right direction.
Posted on Oct 27, 2012
    Problem Solver:
  • 10 Answers
I'd suggest (if you have the soldering skills that is) removing those "replaceable" fuses on the board and installing one in the housing that holds the wire nuts for hooking up the DC power. Pain in the A$$ but then you really WILL have a replaceable fuse. Make sure it's the same rating as the ones inside though ...
Posted on Mar 22, 2010
Manual for black and decker 1200 watt invertor
some idea for inverter, collect inverter circuit Books from market.
May 28, 2012 | Black & Decker Vector Cable Kit for 1200...
I just bought a power inverter for use with my pc.
There are two possibilites: the first is the over 400W power draw, the other is how you have the inverter connected. Do you have the inverter connected directly to the battery terminals (the clips) not the outlet plug (cigaretter lighter)? This is needed for any load over 80W and under 400W. (the inverter can handle a load demand over the 400W limit but only for short periods (800W).)
What is the load that your PC pulls (Is it a laptop or a desktop)? The laptop in my home has either a 65W or a 90W load (depending on the battery and the AC adapter we are using). Desktops take much more power (usually).
I hope this helps.
Jul 15, 2010 | Black & Decker Power Inverter PI400AB
How do you change the fuse?
Most devices like this have the fuse inside the plug that goes into the cigarette lighter. The knurled silver tip unscrews. Caution that you don't loose the spring inside.
May 19, 2010 | Black & Decker Black Decker PI100AB 100...
Can I connect vacum cleaner big one with Black & Decker 100 Watt power inveter
No,
You will need a much larger power inverter than that to run that vac...
heatman101
Apr 22, 2010 | Black & Decker 100 Watt Plug-In Power To...
How do i tell when the inverter is charged?
Question does not seem to match this inverters capability.
INFO:
This Power Inverter converts vehicle’s 12-volt DC power into household 115-volt AC power. AC and USB outlets power and/or recharge personal electronics.
We have owned one of these Power inverters for over a year now and have run a great deal with it, from TV to drill press PC and any thing that was small and that could run from my car. Very nice product.
SET UP: Connect wires. ensure correct polarity, push button on top. Plug in 110 volt appliance.
Hope this tip was of some use.
R/
David
Feb 12, 2010 | Black & Decker Power Inverter PI400AB
I have a black and decker inverter type 1 400
First, you should be aware that the exact inverter is available for under 40 dollars all over the US. Your model is sold under several names - check out http://search.harborfreight.com/cpisearch/web/search.do?keyword=inverter .
I suspect that your INPUT power level is not adequate for the inverter to put out the 200W that the 150W charger needs. If you have low current and low voltage - then the inverter can only put out a proportionally smaller AC wattage level. You may also have a faulty voltage sensor....at the input. Once the inverter sees a low level (even momentarily), it alarms and shuts down the output until the unit is reset (turned off/back on)
Dec 28, 2009 | Black & Decker 1000w Power Inverter
Describe your Black &
I have a black and decker 100 watt power inverter. When the led turns red you are ethier overloading it or it overheated. to fix it unplug it and let it sit for 5 minutes. Plug it in. Plug in an item rated for 100 watts or less. Or try to charge somthing on the usb port.
Aug 23, 2009 | Black & Decker 100 Watt Plug-In Power To...
How do I replace the fuses in a 750 watt black and decker power inverter
look for a cover to maybe flip up or slide (most inverters fuses are coverd)
Jul 05, 2009 | Black & Decker 750w Power Inverter
No AC power
Why does the AC indicator light constantly flash and I have no AC power on my Black and Decker Electormate 400
May 03, 2009 | Black & Decker 400 Watt Electromate With...
Black & Decker PI400AB Power Inverter Logo
980 people viewed this question
Top Black & Decker Electronics - Others Experts
PNiss
Are you a Black & Decker Electronics - Other Expert? Answer questions, earn points and help others
