Question about Toshiba SD-2700 DVD Player
Disk Error When I load a copied dvd into a SD-2700 it tells me disk error How can I fix this problem?
    Genius:
  • 1,199 Answers
You can not fix this problem because the player does not read dvd recordable disks
Sorry!
Posted on Dec 18, 2008
Why is there an error message: Space Not Enough when trying to copy DVD?
There is some space reserved for dvd information, error information etc. So solution is make the file archive by right click on file ->proprties-> click archive. After that use winrar and compress. http://www.rarlab.com/download.htm
Aug 22, 2013 | EZ Dupe Computers & Internet
I get disk error using any dvd disk
Motor is noisy while spinning, disk error using any dvd or cd disk. Suppect motor control speed failure
Dec 14, 2009 | Toshiba SD-9200 DVD Player
My disk drive is not working i am trying to down load a new program and when i put the disk in it will read it and then error appears
Hi saratrought, if Windows XP runs and you have read problems in CD/DVD drive try to read another disk, if any other disk work fine then you need to copy your CD/DVD info (or program) in another new disk.
Or just use Windows Explorer to try copy all data from CD/DVD disk to a New Folder in your Hard Drive and then from that location you can try to install your program, if your data don´t copy well then again i tell you that it´s your disk not your CD/DVD drive.
Sorry by bad english.
Oct 16, 2009 | Dell Inspiron 6000 Notebook
I am coming up with error 10-fc12-0570 on the toshiba satellite a215-s7422 i used the both recovery disk and this was the error code
The error message is telling you that the recovery utility was not able to read the data from the disc correctly, or wasn't able to write it to the hard drive. The problem could be with the disc, the CD/DVD drive or the hard drive.
but usually error 10-FC12-0570 is pertaining to a bad HDD or memory
First, try copying the second disc using another system. If you can't copy it, order replacements from Toshiba Customer Assistance: 1-800-457-7777. If you can copy it, try using the copy to do the restore.
You can try using a third party disk checker to verify the problem is or is not with the hard drive. But since the system is under warranty, you're going to have to arrange to have it repaired anyhow, so it may not be worth the effort to verify whether it's the hard drive or CD/DVD drive. It's probably not the CD/DVD drive since you got all the way through the first disc. Contact a Premier (not regular) ASP for service from here: http://pcrepair.toshiba.com
The best way would be to load the Win Vista discs n format the pc...and reinstall...iam telling this because u have a tried the recovery disk as well....
I know most users will not have the Vista CD with you but the Vista Recovery Boot Cd is available free by Microsoft just google...
Download it burn the Image .iso and run that disc. Since that disc will not restore the OS all it does it lets u run diagnostics on ur HDD and allows u to install the OS. Once disk check is completed and repaired, proceed with the Recovery disks that you have.
thank you
have a nice day
Jul 08, 2009 | Toshiba Satellite A215-S7422 Notebook
Disc error
HI. if this error is coming up on every disc you insert, this will be a sign of a serious malfunction that is localized in the optical lens assembly. It could eb that the tracking rail motor is damaged or, the entire assembly is not functioning. replacing this failed assembly will fix this issue.
May 29, 2009 | Toshiba SD-2700 DVD Player
"disk error" occurs when disk is inserted
the drive cannot read data from the disk, follow these instutions:
if you are using vista, right click on "computer" then select "manage" then select "device manager". look down the list until you find CD/DVD and click on the + icon next to it, then right click on the CD/DVD and select un-install (make sure that there is a disk in the drive, preferably a movie or music CD) then restart the computer, when the computer restarts vista will detect the drive and install the drivers again, look in computer to see if the disk has been recognised
let us know how you get on
and please remember to rate us
regards
Nov 28, 2008 | Televison & Video
Finedrive 400 Error
write me at vince954@yahoo.com if this does not work. There is a zipped version of the map_sd folder on the disk also just in case the main unzipped copy has any issues. to use it, copy the directory to your pc, unzip it and then copy the contents to your sd card.
Aug 17, 2008 | Fine Digital FineDrive 400 GPS Receiver
Copying pictures from computer to memory card
i have seen this error and i dont know why it does that. you may want to try buying a micro disk setup that fits into a sd adapter that will fit in your camera.
then you can take out the micro disk when full and put it on a usb adapter and plug right into a usb port.
i know this sounds like more work but so far i havent had a lock up on that or error yet. go to tigerdirect.com if you want to see the different adapters for the sd disk and micro disk and usb etc....
maybe this might help
Jun 22, 2008 | Kodak EasyShare C330 Digital Camera
Error message
Basic DVD, CDrom Troubleshooting
wrong disk ,disk error,
First Clean the lens:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
wont open, wont close, makes clicking/grinding noises etc.
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Jan 28, 2008 | Symphonic WF803 DVD Player/VCR
Toshiba Sd2800
I have the same problem with my SD-2800 that Ruska has. Any suggestion how the unit can be fixed?
Dec 09, 2007 | Toshiba SD-2800 DVD Player
Toshiba SD-2700 DVD Player Logo
95 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
