Question about Toshiba Satellite U405D-S2848 Notebook
Need to turn off touch pad - Toshiba Satellite U405D-S2848 Notebook
    Brigadier General:
  • 5,158 Answers
Vista or xp ?? you can disable it in device manager... if you know how to get there then now you know what to do... if you don't know how to find your device manager let me know
Robert
Posted on Dec 18, 2008
How do I fix my acer aspire touch pad?
some touch pads have a tap to turn off, and a double tap to turn back on... also check you F keys.
Jun 03, 2014 | Acer Aspire Computers & Internet
Touch pad sony viao vpceb3j1e not working
Hey there. Often times this is a problem caused by accidentally turning it off. Look for a button on your keyboard or near the touch pad to turn the touch pad on/off. If you're using windows 7 and possible below, you won't need drivers to get the touch pad to work normally.
Jul 26, 2011 | Computers & Internet
THE TOUCHPAD MOUSE JUST QUITE WORKING DOES IT NEED REPLACE AND IS IT SEPARATE FRON THE KEYBOARD
It is hard to tell if the touch-pad needs replacing from the information you gave. However, I can tell you that the touch-pad is NOT part of the keyboard.
There are several things the can cause the touch-pad not to work. 1) It may have been turned off in the BIOS. 2) It may have been turned off by the operating system software or 3) You may have installed a usb mouse which in some cases will override the touch-pad. 4) The touch-pad may have a bad connection into the motherboard or into the touch-pad circuits.
I wouldn't go replacing the pad until I had tried all the other possible areas because this requires a complete screw removal from the bottom, removing the display and keyboard. Then removal of the upper case of the laptop. I do this as a last resort.
Apr 01, 2011 | Computers & Internet
My oven beeps sometimes after use there is no code showing when this happens. the beeping can last for 15 min. sometimes.
most likely you have a bad touch pad the unit has a faulty kep on the touch pad and is going to require a new touch pad...you may be able to turn the power off at the breaker for a few minutes and while off run your hand over the touch pad buttons firmly ..you may luck out and free the stuck one up but most likely you are going to need a new touch pad with the ribbon cable conection...
Jan 05, 2011 | Thermador CM302U Electric Double Oven
My toshiba satellite A355D touch pad is not working. my husband told me that probably my kid turned it off. if that is the case... how can i turn it on?
Sounds like your touch pad may need to be replaced.You can't really turn off the touch pad.Even if your child managed to uninstall the touch pad it would load back the drivers at next startup.Chances are the touch pad will have to be replaced.Its possible the touch pad may be disconnected from the motherboard but not very likely though.
Aug 24, 2010 | Computers & Internet
I have a Satellite L500, need help turning mouse off so I can use touch pad, I got the laptop used and they used a mouse and I would rather use touch pad and don't know how too turn mouse off.. when i...
If it is not a normal mouse then From the Control Panel->Add Remove programs remove the mouse drivers. and reboot the laptop. Else go to Control Panel->System->Hardware->Device manager. Remove the mouse that is installed there. DO NOT REMOVE THE TOUCH PAD. And compute happily ever after.
Nov 16, 2009 | Computers & Internet
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
Touch pad
If you have the drivers for the touchpad installed then you should be able to run your finger up or down the right hand side of the touch pad and have it scroll the page you are one.
If it doesn't work then you may need to either reinstall the drivers or find the program that handles the touch pad settings (usually found in program files) and turn the scrolling feature back on.
Hope that helps :)
Mar 13, 2009 | HP Compaq Presario 2200 Notebook
Touchpad
When the touch pad stops working it's one of three things. 1- A driver glitch, unistall the touch pad drivers from the device manager, then reboot. The machine will find the touch pad and reinstall the drivers automatically. 2- The touch pad connector has worked loose. Take the palm rest with the touch pad off, disconnect the cable, clean the connectors, and reseat the cable firmly. 3- the touch pad has failed and will need to be replaced. The driver glitch is the most common, I believe that it should take care of the problem. Let me know.
Aug 06, 2008 | Dell Inspiron E1705 Notebook
Toshiba Satellite U405D-S2848 Notebook Logo
75 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
